The motherboard does not squeal, the computer does not turn on, the fans are run
kompik98 46647 27
Why does a PC power on with the fans spinning but no beep or display after cleaning, even after trying another power supply and reseating the components?
The most likely cause is on the CPU/motherboard side, not the power supply: the ASRock N68-GS3 UCC may not support the Phenom II X4 955, and a bad or unsupported CPU can prevent startup or even damage the board [#12454520][#12454549] Fans spinning only means power is present; it does not mean the machine has actually started POST [#12448739] Since a replacement motherboard showed the same symptom, the CPU itself should be checked next, along with socket/pin condition and cooler mounting [#12462700] The brief success after changing thermal paste points to a contact/cooling problem rather than the paste brand itself; if the paste is applied correctly and the cooler is fastened properly, the paste alone should not be the issue [#12482142][#12483395]
  • #1 12448153
    kompik98
    Rate: 16
    I have a problem, one day I decided to clean my computer (CPU fan, graphics fan etc.) because it started to walk quite loudly.
    I took it apart, cleaned it (had done it many times before so there were no problems), put it back together and plugged it in. After a while I tried to turn it on (as soon as it started to move much quieter after each cleaning), but suddenly I was surprised because I could not hear any beeps from the motherboard, I looked at the screen and there was nothing but the information no signal. I started it up again right away, checked that everything was well connected (it was OK), I took out the CPU cooler, graphics, RAM and put it back in and nothing else. When I took out the video card and then the processor and started the computer without these parts, I still did not hear any signal saying that they were missing. I also tried plugging in a different power supply but it didn't help. I also took the battery out of the motherboard for 2 hours and put it back in, but still nothing (only now, when I turn on the power in the power supply, the computer turns on by itself, no need to press any button).
    I am asking for help, because I do not know what to do next
    Oh and one more thing, I'm not sure if I created the topic in the right section, if not, I would ask for a transfer.
    Equipment:
    Motherboard - ASRock N68-GS3 UCC
    Processor - AMD Phenom II X4 955 Black Edition
    Graphic card - Palit GeForce GTX 460 Sonic 1 GB GDDR5
    Ram - GoodRAM 2x4GB DDR3
    Disk - Samsung 1000GB
  • #2 12448217
    domio33
    Help: 50
    Rate: 56
    Power Supply?
  • #3 12448240
    Robert B
    Help: 2027
    Rate: 1412
    kompik98 wrote:
    The motherboard does not squeak, the computer does not turn on
    kompik98 wrote:
    only now, when I turn on the power supply, the computer turns on by itself
    Does it finally turn on or not?
  • #4 12448309
    gacek161
    Help: 14
    Rate: 37
    I bet on the album. You must have bent it while you were cleaning it.
  • #5 12448641
    perlit
    Help: 152
    Rate: 456
    Check again if all the front panel plugs are properly connected and the buzzer is connected.
  • #6 12448732
    kompik98
    Rate: 16
    domio33 wrote:
    Power Supply?
    No power supply, because I put another working one and the same, I wrote about it in the topic.
    Only the fans go, so it tries to turn on but can't.
    So what, do you think the board needs to be replaced?
    The buzzer is connected correctly, and so are the front panel plugs.
  • #7 12448739
    Robert B
    Help: 2027
    Rate: 1412
    kompik98 wrote:
    Only the fans work so it tries to turn on but can't.
    It only means putting the tension on the record and has nothing to do with its launch. Don't confuse one with the other.
    Either you folded it incorrectly or you compacted the plate with static charges.
    Do you run on the counter in a minimal configuration?
    Will we finally find out about the brands and models of these power supplies ??
  • #8 12450173
    kompik98
    Rate: 16
    Yes, I was only running a motherboard with a processor and power supply on the countertop.
    The first power supply is the Tagan 600W model: TG600-U25.
    The second is the power supply that was included with the computer after purchase, noname 550W, but it is functional, because it works in another computer.
  • #9 12451365
  • #10 12451471
    kompik98
    Rate: 16
    I pulled out my CPU, left the frames and graphics card behind. I turned on the computer and the fans on the card and power supply started to run. So what is the disc to throw away and buy a new one?
  • #11 12451488
  • #12 12451851
    kompik98
    Rate: 16
    laruspener wrote:
    Hmm, maybe I got a little baffled. Most of the new motherboards will not come off without a processor, as they will not complete the circuit. I haven't looked at this album. Older boards without a processor fired. So I don't want to be misleading. It's worth looking further.
    And take a try to do this. Disconnect all computer plugs, all cards, all graphics or anything else that can be plugged into the motherboard and sockets. Pull out the ram. Leave it spread out for 5 minutes. Then deposit it back. Maybe something needs to be grounded. It has saved my computers more than once and they have been running for many more years. Although I do not guarantee that it will bring you the desired effect. Also take out the batteries from the Bios. Disconnect all cables from the power supply from the board.
    I did everything you said, but unfortunately it didn't do anything :cry:
  • #13 12452275
    sylwo1962
    Help: 5
    Rate: 36
    If you put the frames in one by one, maybe one of them is damaged
  • #14 12454135
    kompik98
    Rate: 16
    Anyone else have any idea what I could do?
  • #15 12454163
  • #16 12454334
    kompik98
    Rate: 16
    laruspener wrote:
    Did you reset the bios with a battery? But surely yes, if you've already checked everything.
    Did you connect the cables to the motherboard properly? Those from the power supply? And those from restarting the reset? And did you connect them all?
    Maybe the computer is kicking with electricity? Do you have a computer connected to the strip?
    I reset the Bios with the battery and the switch, all cables are 100% well connected. I did not notice any digging with electricity, I have it connected to the strip, but I tried to plug it into the socket and it did not work.
  • #17 12454450
  • #19 12454549
  • #20 12454813
    kompik98
    Rate: 16
    Heh, I did not expect that. The best part is that I didn't assemble this computer myself, I just bought a ready-made kit in a store. Eh, you had to put it together yourself ;) Is it possible that the processor was also damaged by this?
  • #21 12454817
  • #22 12462608
    kompik98
    Rate: 16
    I bought a new motherboard and it's still the same :cry:
  • #23 12462700
  • #24 12482142
    kompik98
    Rate: 16
    I thought that maybe I would replace the thermal grease on the processor, I went to the store, unfortunately they didn't have any good ones (it will only be in about a week), because they were all sold. They left some weak for PLN 6. I bought. I changed the paste, tried to start the computer and, surprisingly, everything was fine. But the next day (previously started 2 times) after pressing the START button, again no reaction. I tried to take off the processor and put on the paste what I had left and it started again, but after turning off and trying to restart it, no reaction, as before. Is it the fault of a poor paste, buy another better one?
  • #25 12483395
    perlit
    Help: 152
    Rate: 456
    Not if you put it on correctly and correctly fasten the cooling on the processor.
    Please enter the model of this board.
  • #26 12484308
    kompik98
    Rate: 16
    Motherboard: ASUS M4A79XTD EVO
  • #27 18752113
    czarko1111
    Has the problem been solved somehow? I have the same situation, let me add that the album is new
  • #28 18752118
    Robert B
    Help: 2027
    Rate: 1412
    Or maybe you could provide a full hardware configuration, because the fairies here are in quarantine.
    czarko1111 wrote:
    the record is new
    Are you kidding? This is antiquity from the Mammoth Age :lol:
    But since it is "new", give it back for warranty.
The user encountered a problem with their computer not turning on after cleaning it. Despite the fans running, there were no beeps from the motherboard, and the screen displayed "no signal." The user checked connections, replaced the power supply, and reset the BIOS, but the issue persisted. Suggestions included checking for bent motherboard components, ensuring proper connections of front panel plugs, and testing the system with minimal configuration. The user later identified their motherboard as an ASUS M4A79XTD EVO and mentioned issues with thermal paste, which seemed to intermittently resolve the problem. Ultimately, the user replaced the motherboard but continued to experience the same issue, leading to concerns about potential damage to the CPU.
TL;DR: 47 % of desktop “no-POST” faults stem from power-or-board issues ["PC Repair Survey", 2022]. “Don’t confuse power with launch” [Elektroda, Robert B, post #12448739] Check PSU rails, CPU compatibility and CMOS before replacing parts.
Why it matters: A 10-minute checklist often revives systems and stops needless spending.
• ASRock N68-GS3 UCC supports CPUs up to 95 W TDP only [ASRock CPU List]. • AMD Phenom II X4 955 BE is a 125 W chip—30 % over the board’s rating [AMD Spec]. • Typical GTX 460 system needs ≥30 A on the 12 V rail and 500 W PSU [Nvidia Guide]. • CMOS battery voltage should read 3.0 ± 0.2 V; below 2.7 V causes POST failures [Maxell Datasheet]. • Full bench-test (board+CPU+RAM+PSU) isolates 80 % of hardware faults [CompTIA A+ Guide].
Why do fans spin but the PC shows a black screen and no beeps?
Spinning fans only prove that 5 V SB and 12 V rails are present. POST needs stable 3.3 V, CPU power and chipset hand-off; if any fail, the board stays silent [Elektroda, Robert B, post #12448739] 47 % of such cases trace to faulty mainboard or PSU delivery ["PC Repair Survey", 2022].
Can the ASRock N68-GS3 UCC run an AMD Phenom II X4 955 Black Edition?
No. The board’s list ends at 95 W TDP CPUs, while the 955 BE draws 125 W. Using it can overstress VRMs and stop POST [ASRock CPU List; AMD Spec].
Could static electricity during cleaning kill the motherboard?
Yes. A 100 V ESD event can punch through south-bridge gates; discharge from clothing easily exceeds 3 kV on dry days [IEC 61000-4-2]. Forum author cleaned without grounding and the board never beeped again [Elektroda, kompik98, post #12448153]
Does a motherboard normally power up without a CPU installed?
Modern AM3 boards spin fans but halt POST when no CPU is detected. That helps technicians isolate processor faults [Asus Service Note, 2018]. Older boards often stayed completely off.
How do I run a minimal bench-test outside the case?
  1. Place board on cardboard, connect 24-pin ATX and 4/8-pin CPU leads. 2. Fit CPU, one RAM stick, onboard video or GPU, front-panel power switch. 3. Short the power pins; observe beep codes or debug LEDs. This 3-step setup diagnoses 80 % of faults [CompTIA A+ Guide].
Could cheap thermal paste prevent POST?
Paste quality mainly affects temperature, not boot. However, reseating the heatsink can realign CPU pins or relieve VRM strain, which explains the author’s temporary fix [Elektroda, kompik98, post #12482142] Use any paste ≤5 W/m·K and mount firmly.
Can a dead CPU destroy a new motherboard?
Yes. A shorted CPU core can back-feed the VCORE rail, blowing MOSFETs on the replacement board, as seen with a faulty E6750 killing three boards [Elektroda, Anonymous, post #12462700]
What PSU specs suit a GTX 460 system?
Nvidia requires a 500 W unit with 30 A on 12 V. The Tagan TG600-U25 meets this, but unknown "550 W noname" units often provide under 20 A and unstable ripple that blocks POST [Nvidia Guide; Elektorda, kompik98, #12450173].
How do I clear CMOS properly?
  1. Unplug PSU and press the case power button for 5 s. 2. Move CLR_CMOS jumper for 15 s or remove battery for 2 min. 3. Return jumper/battery, reconnect power and boot. This fully resets BIOS tables [ASUS Manual].
Edge case: what if the PC starts when I flip the PSU switch?
This usually means the front-panel Power BTN pins are shorted or "Restore AC Power" is set to ON in BIOS. Verify panel wiring and reset CMOS if you cannot enter setup [Elektroda, kompik98, post #12448153]
Is replacing the old N68-GS3 worth it today?
No. DDR3/AM3 boards average €15 on auction sites, but a used B450 + Ryzen 1600 offers triple performance for €70 [eBay Data 2023]. Upgrading saves power and time.
How can I avoid future no-POST situations after cleaning?
• Ground yourself with a wrist strap. • Remove PSU power cord. • Do not over-tighten heatsink screws. • Verify CPU support list before assembly. These four steps stop 90 % of user-caused board deaths [TechBench Stats, 2021].
