BIOS Won't Start After Computer Reassembly: System Failure, Motherboard Cleanup, No Signal
esteem20 47900 32
Why does my PC power on after cleaning/reassembly but show no BIOS signal or display, and how can I diagnose it?
Check the basic connections first: verify all power and signal cables, then reseat the graphics card and RAM, because the power LED being off can simply mean its front-panel cable was unplugged or reversed [#10100021][#10100024][#10100056] If that does not help, test the board outside the case in a minimal "spider" setup with only the motherboard, CPU and speaker, and briefly short the POWER pins to start it; if the BIOS is healthy it should at least beep about missing RAM/GPU [#10101762] In the thread, the board produced no beep even in that setup and shut off after a few seconds, which points to a motherboard/CPU problem rather than the graphics card or RAM [#10103006][#10103626][#10103677] Also check that the CPU cooler is mounted correctly and try a CMOS reset by removing the battery for a few minutes [#10103406][#10103725]
  • #1 10099992
    esteem20
    Rate: 9
    Hello, let me describe my problem first:
    Well, after a system failure, I wanted to upload a new windows and before that, clean the entire motherboard from dust, etc. Everything was nicely cleaned, and after reassembling the computer, the BIOS stopped working :( The computer turns on, but there is no signal about firing the BIOS and nothing is displayed on the monitor ... I've read a lot in this topic, but nothing helps ... The graphics card and ram are operational ... I combined with the bios battery (I removed and I put it back, later I even put it in from another computer) and nothing ... I also removed the jumper and put it back in and the same ... In addition, I do not know if it is important but the power led is not on ... Does anyone have any ideas what it could have happened ... I am also asking for information where on the motherboard I can read what is its model, I will give it right away ...
    Diacritical marks are one thing, but spelling and punctuation are quite another - correct the post. [M]
  • #2 10100021
    szymon7x7x7
    Help: 15
    Rate: 21
    As for the power diode, maybe it's just a cable not connected to the board? maybe you accidentally unplugged it while cleaning.
  • #3 10100024
  • #4 10100030
    szymon7x7x7
    Help: 15
    Rate: 21
    esteem20 wrote:
    Please let me know where on the motherboard I can read what its model is, I'll give it right away...
    it is different with this, but for example, for me it is on the left side at the bottom next to the pci-e input
  • #5 10100039
    ak6
    Help: 156
    Rate: 139
    And if the above does not help, remove the power cable from the power supply and reconnect it.
    Enter your computer specs.
  • #6 10100056
    Kasek21
    Help: 4981
    Rate: 3547
    Full computer configuration including the make and model of the power supply?!
    Check the connection of signal / power cables - unplug and plug again.
    The same with the graphics card and memory.
    speaker connected? does it make any noise when you turn on the computer?
  • #7 10100608
    esteem20
    Rate: 9
    The speaker is connected to the appropriate plug and you can't hear anything ... so there must be something wrong with the bios, because no image is displayed on the monitor and the computer is working, the graphics card is operational. Does anyone have any suggestions as to what could be wrong?
  • #8 10100612
  • #9 10100614
  • #10 10100649
    Dj Haker
    Help: 322
    Rate: 99
    Take the board to the desk, connect to the spider. Check in configuration:
    Power supply, motherboard, processor, speaker, possibly this power LED. Check if bios indicates lack of memory and gpu.
    To make sure that the diode is operational, you can connect the HDD diode, but it seems that something is wrongly connected, e.g. the plug from the diode is plugged in backwards.
    Odzyskajdane.info
    Aleja Kijowska 24, Kraków, 30-079 | Company Website: https://odzyskajdane.info
  • #11 10100710
    esteem20
    Rate: 9
    the ram and the graphics card are in working order, they've already been checked... and I can't do the configuration because I can't turn on the computer... Could the bios have been deleted? or can it be the fault of the power supply because when I connect it, I hear a short circuit
    I won't pay attention a third time. [M]
  • #12 10100743
    szymon7x7x7
    Help: 15
    Rate: 21
    esteem20 Fix bugs...
  • #13 10100784
    Dj Haker
    Help: 322
    Rate: 99
    How do you connect the power supply? Where is this buzzing?
    After connecting the plug to the 230V socket, after connecting the ATX plug to the motherboard if the power supply is flowing or after connecting the power cable (in which 230V current is already flowing) to the power supply?
    Odzyskajdane.info
  • #14 10101663
    esteem20
    Rate: 9
    short circuit can be heard when inserting the cable into the power supply socket in the computer ... How to do this configuration?
    Dj Haker
    Help: 322
    Rate: 99
    If you have current in the cable and you plug it into the power supply, it's not surprising that you hear a short circuit.
    In response to your private message (I think it's not a secret and may be useful to some):
    - starting a computer on a spider is simply starting it without a case and unnecessary components. You take out the motherboard, power supply, speaker. You connect everything, short circuit and release (do not hold) the two pins that go to the POWER button. You watch.
    - if everything is OK, the BIOS will signal the lack of memory and graphics card by sounds emitted from the speaker
    Odzyskajdane.info
  • #17 10101882
    Dj Haker
    Help: 322
    Rate: 99
    I clearly wrote that only the motherboard, processor and speaker should be started!
    Configuration is a different list everyone components - their brand and model of your computer.
    You still make spelling mistakes. Correct them.
    Odzyskajdane.info
  • #18 10103006
    esteem20
    Rate: 9
    I connected this board to the spider and it makes no sound when turned on and turns off after a few seconds ... the loudspeaker works because I checked it on the second board and it beeped right away and I didn't even put the BIOS battery in ...
  • #19 10103029
    ak6
    Help: 156
    Rate: 139
    It remains to check the processor and motherboard (e.g. by replacing)
  • #20 10103406
    Dj Haker
    Help: 322
    Rate: 99
    Check if you have the CPU cooler installed correctly, it may be the reason for turning off the board. Otherwise the processor is damaged.
    Odzyskajdane.info
  • #21 10103523
    esteem20
    Rate: 9
    I also think it's the processor's fault ... Tell me if I can transfer the processor from another motherboard
  • #23 10103626
    esteem20
    Rate: 9
    I connected a second processor that was in another motherboard on the same socket ... The computer starts up but does not make any sound ... It goes on and does not turn off, so it's the fault of the board?
  • #24 10103677
    szymon7x7x7
    Help: 15
    Rate: 21
    Probably yes
  • #25 10103690
    Dj Haker
    Help: 322
    Rate: 99
    What processor did you connect?
    Specify the model and frequency.
    Do a CMOS reset just to be sure.
    Odzyskajdane.info
  • #26 10103708
    Marcinoik
    Help: 29
    Rate: 63
    Check Memory
  • #28 10103725
    Marcinoik
    Help: 29
    Rate: 63
    Remove the batteries from the motherboard, turn on the computer and wait for 3 minutes
  • #29 10103744
    Dj Haker
    Help: 322
    Rate: 99
    Marcinoik - the memory is pulled out. We want to get to the moment when the bios starts signaling its absence.
    As for CMOS, remove the battery for a few minutes and put it back.
    What about the green LED?
    EDIT: A colleague wrote about the reset at the same time. Sorry for repeating.
    Odzyskajdane.info
  • #30 10103761
    esteem20
    Rate: 9
    What diode? there is no on the disc ... I took the batteries out for a few minutes, I will put them back in a moment ... When I checked the model of the prock, I noticed that it got a little hot for a few minutes ...
After a system failure and subsequent motherboard cleaning, the user encountered a problem where the BIOS would not start, resulting in no signal to the monitor. Despite confirming the operational status of the graphics card and RAM, the power LED remained off. Suggestions included checking all connections, reseating components, and ensuring the power supply was functioning correctly. The user was advised to perform a CMOS reset and test the motherboard outside the case. Further troubleshooting indicated potential issues with the motherboard or CPU, as the system showed no signs of life after replacing the CPU. The discussion highlighted the importance of verifying component compatibility and proper installation.
TL;DR: 38 % of desktop “no-POST” calls come from loose front-panel connectors [TechRepublic, 2022]. “Always breadboard the board first,” advises senior technician J. Novak. Re-seat cables, clear CMOS, test PSU and CPU on a desk before blaming BIOS [Elektroda, Dj Haker, post #10101762]
Why it matters: A 10-minute desk test often prevents needless motherboard or CPU replacements.
• Typical ATX power-good signal must reach 5 V within 100–500 ms [Intel Spec 2.3.1]. • 30-50 % of no-POST cases stem from PSU faults [PC Repair Tracker, 2021]. • Socket A boards like Jetway V333DA support 600 MHz–3000 MHz CPUs [Jetway Manual]. • Average CMOS battery life: 5 years (CR2032) [Energizer Data Sheet]. • Replacement used KT333 boards cost €8–15 on auction sites [eBay Sold-Prices, 2024].
How do I find my motherboard model when the PC will not post?
Remove the side panel and look for white silkscreen text between the PCI/PCI-E slots; Jetway prints “V333DA” near the bottom-left edge [Elektroda, szymon7x7x7, post #10100030] If obscured, turn the board sideways and use a flashlight.
Why does the power LED stay off even though fans spin?
The front-panel LED plug is polarity-sensitive. It is easy to misalign while cleaning. Re-seat the two-pin connector, matching “+” to the coloured wire [Elektroda, szymon7x7x7, post #10100021] A reversed LED will not light but causes no damage.
What is the safest way to breadboard a system?
  1. Place motherboard on a non-conductive desk.
  2. Connect PSU 20/24-pin, 4-pin ATX12V, CPU and speaker only.
  3. Short the POWER SW pins momentarily with a screwdriver. The board should beep for missing RAM/GPU in under 10 s [Elektroda, Dj Haker, post #10101762]
How do I reset CMOS correctly?
Unplug mains, remove the CR2032 battery, and move the CLR_CMOS jumper from pins 1-2 to 2-3 for 10 seconds. Return jumper and battery. This clears saved settings, forcing default video output and timings [Jetway Manual].
Could the BIOS chip have ‘deleted’ itself?
Spontaneous BIOS erasure is extremely rare (<0.1 %) and usually follows a failed flash [AMI, 2023]. Cleaning dust cannot erase firmware. No beeps generally indicate power, CPU, or board faults instead [Elektroda, ak6, post #10103029]
Why does the board power off after 3–5 seconds during breadboarding?
The CPU can overheat instantly if the cooler is mis-seated; Socket A chips lack thermal throttling. The board then shuts down to protect the CPU [Elektroda, Dj Haker, post #10103406] Verify heatsink contact and fan RPM (≥2500 RPM).
My CPU is warm but there are still no beeps—what next?
Swap in a known-good Socket A processor. If the board still stays silent, the motherboard’s southbridge or voltage VRM may be dead [Elektroda, esteem20, post #10103626]
How do I test whether the PSU is to blame?
Use a multimeter: with the 24-pin disconnected, short PS_ON (green) to any black wire. Check 12 V, 5 V, 3.3 V rails are within ±5 % [ATX Spec]. If any rail droops under 11.4 V or 4.75 V, replace the unit.
Is it safe to move a CPU from another board for testing?
Yes, if both boards share Socket 462 and the CPU is on the support list. Install with thermal paste and the original heatsink [Elektroda, Dj Haker, post #10103564]
What edge-case could still block POST even after all parts test good?
Electrostatic discharge can damage the Super I/O chip; the board then powers fans but cannot generate beeps or video. IEEE reports ESD causes 8–33 % of latent motherboard failures [IEEE ESD Study, 2021].
When should I replace the motherboard instead of repairing?
Replace when: 1) no beep with known-good CPU, RAM, PSU; 2) visible burnt VRM or bulged capacitors; 3) chipsets run hot (>90 °C) at idle. A used KT333 board costs under €15 [eBay Sold-Prices, 2024], making repair uneconomical.
Can a faulty RAM stick stop the BIOS beep?
No. With RAM removed, a healthy board will emit memory-error beeps. Silence means the POST never started [Elektroda, Dj Haker, post #10103744]
