Replacing the drain hose in the BOSCH WLX2048 washing machine
kazo.m 31740 18
Can I replace the BOSCH WLX2048 drain hose with a longer one-piece hose, and how do I access it for replacement?
Yes, the drain hose is replaceable, so a longer one-piece factory hose can be fitted instead of the short original hose [#12319460] One user confirmed they had already run the machine successfully with a 4 m hose, replacing a two-piece setup, so the pump should cope with a longer hose, although the extra length increases resistance and means the filter should be checked more often [#12327196] [#12326202] For access, forum advice was to use a Torx 20 and remove the front wall and top cover to reach the pump and hose, or alternatively tilt the machine carefully and work from underneath after draining the filter first [#12325657] [#12326202]
  • #1 12318533
    kazo.m
    Help: 16
    Rate: 96
    I need to replace the drain hose in the BOSH WLX2048KPL washing machine.
    So far I had two hoses connected using a piece of copper pipe, self-amalgamating tape and metal clamps.
    So far!. Today, water leaked from the washing machine, (probably) because it was very warm for two days and the hoses slipped off the tube.
    My question is: is it possible to install a longer drain hose to this model? The washing machine is already 1.5 months out of warranty, so I can interfere with it.
    I would like to ask for quick answers, because the problem is quite urgent.
    An angry woman is the worst thing. :bad-words: :lol:
    I would like to thank my colleagues in advance for their understanding and quick responses.
    stanislaw1954
    Help: 2013
    Rate: 4673
    If so far the washing machine has been pumping out water using a manufactured hose, i.e. a longer one, why wouldn`t it want (could) work with a longer, factory-made hose?
  • #3 12319376
    kazo.m
    Help: 16
    Rate: 96
    It will definitely work on a longer (one-piece)
    My question is the following. Is it possible to dismantle the short hose in the washing machine and install a longer one?
    Isn`t the original hose permanently installed?
  • #4 12319460
    stanislaw1954
    Help: 2013
    Rate: 4673
    All hoses are replaceable, as there is always a possibility of damage.
    mrhari
    Help: 835
    Rate: 3239
    kazo.m wrote:
    and the snakes slid off the tube.
    Because they were probably too tight. Two such clamps on hoses mounted on a metal pipe and they cannot come apart.
  • #6 12319625
    kazo.m
    Help: 16
    Rate: 96
    They slipped off because there was self-amalgamating tape that melted.
  • #7 12322562
    kazo.m
    Help: 16
    Rate: 96
    In that case, I need to get a "French star" and unscrew the washing machine.
  • #8 12325422
    agdrtv
    Help: 7
    Rate: 59
    Buddy, why do you want to disassemble the pump, you can`t reach it from the back or from the top, only from the bottom, you have to turn the washing machine on its side - don`t try anything, just give us 2 metal bands and the problem will be solved - otherwise you will accidentally flood the module with the leftover water from the drawer. powder or something else will happen to you, cheers
  • #9 12325520
    movzx
    Level 40  
    Help: 731
    Rate: 1269
    Is the "French star" some kind of confectionery decoration?
    It`s better to leave your guts alone, put them on bandages as advised above and you`ll be fine.
  • #10 12325657
    Stefciu_B
    Home appliances specialist
    Help: 312
    Rate: 1222
    Get a Torx 20 key, unscrew the front wall and the top of the washing machine, you will have great access to the pump and the hose that comes out of the housing at the height of half the washing machine.
    Under no circumstances should you turn the washing machine on its side.
  • #11 12325956
    kazo.m
    Help: 16
    Rate: 96
    The pump is at the very bottom, next to the filter, so I can only access it from the bottom. (it is necessary to place the washing machine on its side)
    And the hose comes out of the housing in the upper left corner.
  • #12 12326039
    Stefciu_B
    Help: 312
    Rate: 1222
    I know that very well.
    I wrote, do not turn the washing machine on its side (if you do not want to damage the washing machine ;) )
    Maybe I didn`t express myself clearly enough in the previous post:?
    If you do not want to dismantle the front wall (it can be removed) or you are afraid, tilt the washing machine slightly on its back and you should also have access to the pump from the bottom. Take a photo of the top cover so you have access to the hose to remove it from the housing.
  • #13 12326122
    kazo.m
    Help: 16
    Rate: 96
    Ok, thanks for the valuable advice. I`ll keep her in mind.
    I prefer not to remove the front wall because I don`t know if I can put on the drum rubber.
  • #14 12326202
    agdrtv
    Help: 7
    Rate: 59
    Hello, of course I didn`t mean literally tipping the washing machine over, but gently laying it on its side on something soft so as not to scratch the sheet metal, be sure to drain all the water from the filter first by tilting the washing machine forward and with the drain hose up, so as to empty the washing machine of water as thoroughly as possible, also pull out the powder drawer, or put the washing machine on its side on the drawer side, the longer the hose, the greater the resistance to the pump and the greater the risk of clogging the system, you need to check the filter more often, best regards
  • #15 12327196
    kazo.m
    Help: 16
    Rate: 96
    Yes, I realize that a longer hose means a greater load on the pump, but so far it has worked without problems with a 4-meter - 2-piece hose, and I want to replace it with a 4-meter - 1-piece hose.
    The pump (I think) must have some reserve in terms of hose length.
    Thank you all for your replies, now I can get back to work. :spoko:
  • #16 12327424
    Volt-rom
    Help: 5
    Rate: 42
    Instead of a pipe and metal clamps, you can use a connector of the type used to connect garden hoses (for watering)
  • #17 12329310
    kazo.m
    Help: 16
    Rate: 96
    I tried, but the drain hoses have too large a diameter compared to garden hoses and the connection was leaky.
  • #18 12329597
    Volt-rom
    Help: 5
    Rate: 42
    you need to try on a 3/4 inch hose
  • #19 12330398
    kazo.m
    Help: 16
    Rate: 96
    I tried to install just such a connector
The discussion revolves around replacing the drain hose of a BOSCH WLX2048 washing machine. The user experienced water leakage due to the existing hoses slipping off, likely caused by overheating. Participants confirm that a longer drain hose can be installed, emphasizing that all hoses are replaceable. There are suggestions on how to access the pump and hose connections, with advice against disassembling the machine unnecessarily. Users recommend using a one-piece hose for better reliability and discuss the importance of ensuring proper connections to prevent leaks. The conversation also touches on the potential challenges of using connectors and the need for appropriate hose diameters.
