Kospel PPE2 Water Heater (9/12/15): Connecting Power Cord - Green-Yellow, Blue, Brown Wires
Navaho 48852 15
How do I connect the power cable to a Kospel PPE2-9/12/15 water heater, and what do the U, V, W terminals and the blue/brown/green-yellow wires correspond to?
This heater is wired as a 3-phase unit: connect the three phase conductors to U, V and W, and connect the green-yellow protective conductor to the right-hand terminal/thermal protection; a normal 3-wire plug lead is not enough because the manual calls for a 4×2.5 cable (3 phases + PE) [#12560139][#12560978][#15971188] It is not a 230 V appliance and there is no neutral terminal in the heater, so the blue and brown wires from a single-phase lead do not have a separate place here [#15970332][#15970398] The installation should be 3-phase and rated at least 15 kW, with phase current about 22 A [#15971188] If you are not sure about the supply or protection layout, the thread advises calling an electrician [#12560978][#15971188]
  • #1 12560066
    Navaho
    Rate: 20
    can anyone tell me how to connect the cable to the Kospel PPE2-9/12/15 water heater?
    The only thing I can guess is that I should connect the green-yellow wire to the far right screw, but I have absolutely no idea what the symbols U, V, W mean and where should the blue and brown wires be?
    I am attaching a photo of the heater, greetings.
    • Kospel PPE2 Water Heater (9/12/15): Connecting Power Cord - Green-Yellow, Blue, Brown Wires kospel_PPE2.jpg (55.01 KB) You must be logged in to download this attachment.
  • #2 12560139
    Alemucha
    Help: 89
    Rate: 216
    UVW is three phases. Do you have a blue phase? Insert a photo of the ends of the power cable because I would rather expect 2 black and brown, but in the end the colors are secondary, important where they are actually connected. I don't like to advise clients without any basis
  • #3 12560184
    Navaho
    Rate: 20
    I bought the cable myself, a regular 3-wire with a plug, I thought I would connect it to the heater, and the whole thing to the socket? But now I see that I must have miscalculated.
    I wanted to install the heater this weekend in a summer house; I have poor internet access there, so I will ask now: if there is a 3-phase installation, what cables should I connect to the U, V, W marking?
  • #4 12560978
    Alemucha
    Help: 89
    Rate: 216
    After all, in the manual you have written 4x2.5 (3 phase wires + protection). If you don't understand, get an electrician.
  • #5 12561554
    Navaho
    Rate: 20
    I'm slowly starting to understand, and I've already done the electrics, but he doesn't really want to hit the dirt road for such "fuck":/
    Just to make sure: I lead the phase wires to the latches marked U, W, V, and the protective wire in the last one on the right?
    I found out by phone that there are 2 3-wire cables + 2 "loose" cables in the box ...
  • #6 15970138
    arturartur24
    Rate: 98
    hello, I will ask here so as not to create a second topic, i.e. we connect the phase and protective wires, and where is the neutral? I would like to install an overcurrent switch, but in such a system it is probably not possible because we connect the phase and neutral wires there
  • 400 V heater requires three-phase supply and electrician
    #7 15970297
    Sono2020
    Help: 36
    Rate: 146
    Buddy, you have a 400V heater, not 230V, for this you need 3 phases and zero, i.e. the so-called "power" as you have it depends on how many kW you have purchased, such a standard is 17kW and you want to connect it to the socket with a cable !!! God save you because you may not survive this tinkering. Better call an electrician!!!
    And I haven't seen 55A 400V 3ph before!!!
    So you must have a connection of at least 22kW (power) !!!
    Show what "corks" you have at the counter, we'll see what's in the grass!
    Considering that this is a summer house, you probably have only 5.5 kW there, which means this heater is completely out!
    To my friend arturartur24
    And what type of TN, TT or IT installation do you have?
    Do you have grounding or zeroing?
    If you have an earth electrode, i.e. PE and N separated, you can connect
    Are you talking about differential and not overcurrent?
    If you can't tell, call an electrician!
  • #8 15970332
    arturartur24
    Rate: 98
    I have a new installation and the protective and neutral wires are separated, you are right, I meant the current difference, only three phase and neutral wires are connected to the current difference, and three phase wires (marked u,v,w) and a protective wire are connected to the heater, and there is no neutral, which is why I was surprised
  • #9 15970398
    Sono2020
    Help: 36
    Rate: 146
    Because it is not needed because in 3-phase the work is phase-to-phase and 3-phase wires are needed and PE in home appliances is neutral N or PEN, once and now if there is no earthing, sometimes N is still connected as this protective PEN.
    As for the connection in the differentials, the principle of operation of the differentials bows to you!
  • #10 15970456
    arturartur24
    Rate: 98
    I am only asking for an answer how to connect the differential in such a system and whether it is possible since we do not use the neutral wire, as to the principle of operation, I do not know if everyone knows how a diesel engine works, but many have it ;)
  • #11 15970482
    Sono2020
    Help: 36
    Rate: 146
    Unfortunately, my friend, call an electrician because the electricity does not touch him!!!
    And does everyone who has a diesel repair and renovate it himself, probably not!!!
    And with electricity, it's not a game, if you want to have a differential current protection, call an electrician!!!
    Let him do everything right, it's not a school for "home heroes"
  • #12 15970505
    arturartur24
    Rate: 98
    I repair it myself because I have full documentation of the car manufacturer, just as it is enough that you would draw me a diagram and it would be on topic! This forum is here to help each other, not to write to a specialist for any crap!
  • Consult RCD wiring diagrams for safe connection
    #13 15970527
    Sono2020
    Help: 36
    Rate: 146
    If you can read diagrams, then find a diagram of your differential and do it because, unlike the engine, it will not kill you right away, unless you breathe exhaust fumes and a differential that won't work, you won't even know when!!!
    It's about your safety, it's not without reason that SEP exams are passed, etc., because everyone knows how to connect two cables, there is only an option, and here I will quote something to you:
    https://www.elektroda.pl/rtvforum/topic1276827-2220.html#15824990
    It's connected and working, right?
    And here are the schematics:
    Kospel PPE2 Water Heater (9/12/15): Connecting Power Cord - Green-Yellow, Blue, Brown Wires Kospel PPE2 Water Heater (9/12/15): Connecting Power Cord - Green-Yellow, Blue, Brown Wires Kospel PPE2 Water Heater (9/12/15): Connecting Power Cord - Green-Yellow, Blue, Brown Wires
  • #14 15970612
    arturartur24
    Rate: 98
    It couldn't be right away :)
  • #15 15970643
    Sono2020
    Help: 36
    Rate: 146
    And what to look for, you don't want to or don't know how, you have to give everything on a platter!!!
    The engine is also diagnosed for you and they bring only this and that to replace !!!
  • Connect three phases to UVW and earth to PE
    #16 15971188
    Mirek99
    Help: 37
    Rate: 233
    This heater requires a 3-phase installation with a power of not less than 15 kW. The value of the phase current is 22 A. This is how much power you need to have in the place of its installation. Electrical connections require knowledge and authorization. If you want to do it yourself, of course you can - you will do it at your own risk. Remember - safety comes first. If it is about connecting the wires, then the phase wires to the UVW terminals and the protection (yellow-green wire) to the terminal on the right side of the heater's thermal protection. Electric shock protection matched to the network layout of your electrical connection.
The discussion revolves around connecting the power cord to the Kospel PPE2-9/12/15 water heater. Users seek clarification on the wiring, specifically the connection of the green-yellow protective wire and the blue and brown phase wires to the terminals marked U, V, and W. It is emphasized that the heater requires a 3-phase installation with a minimum power of 15 kW, and the importance of consulting an electrician for safe installation is highlighted. The necessity of understanding the electrical system, including the role of neutral and protective wires, is also discussed, with references to the heater's manual and safety precautions.
