[Solved] AEG HK6542HPFB Hob: 400V Connection, Wiring Diagram, Green-Yellow Protection & Bridging Phases
piomon1 9987 4
  • #1 16897278
    piomon1
    I warmly welcome.
    I bought a hob, the manual does not have any information or diagram how to connect to the network. The only information is the one on the back of the device.
    Should I connect green-yellow under protection under 400V, blue under neutral and the other two brown and black under two separate phases, should I bridge them AE ? In my opinion, rather not bridged AE because the bridge is at 230V.
    Maybe someone has some other experience with AEG discs, because when I watch net, everyone has bridge AE two feeding wires?
    Thank you for the information.
    • IMG_20171217_175639.jpg (1.98 MB) You must be logged in to download this attachment.
    • IMG_20171217_175626.jpg (1.94 MB) You must be logged in to download this attachment.
  • #2 16897291
    bearq
    Help: 414
    Rate: 1612
    After all, the diagram is all drawn ... If the disc is new, connecting it yourself loses your warranty automatically. To keep the warranty, the hob must be connected by an electrician who will then insert it into the warranty card.
  • #3 16897611
    piomon1
    Thanks for the answer.
    I just want confirmation from more experienced if my reasoning is correct or not.
    The issue of warranty is obvious.
    Thanks
  • #4 16897744
    zhudomel
    Home appliances specialist
    Help: 1280
    Rate: 3373
    Yes.
  • #5 17077188
    piomon1
    As I thought, everything is ok, we don't combine anything, at least in this type of disc.
