Golf IV 2.3 VR5 150km Engine Review & Issue: Grinding Noise, Low Voltage Lambda Heating Error
5391 10
Why is my Golf IV 2.3 VR5 making a grinding noise at idle, showing a low-voltage lambda heater error, and sometimes stalling or misfiring when warm?
The thread points first to a timing-chain problem on the gearbox side, possibly a broken or worn chain, with the tensioner being overloaded; one user also notes the oil pump can give too much pressure and make the tensioner pull the chain hard [#16204813] [#16205403] To inspect it properly, the advice is to remove the front/belt side parts, including the belt, crank pulley, accessories, alternator and A/C, and even take the engine out for access [#16207053] The chain is said to be always a bit audible on this engine, but a true grinding sound means you should not ignore it [#16207737] One comment adds that the car may have been filled with 10W-40, which was considered too thick and could make the hydraulic pusher/tensioner noisy until the engine warms up [#16212262] Another suggestion is to clean the injectors ultrasonically, since the engine has a specific design [#16207071]
  • #1 16204783
  • #2 16204813
    coperfild
    Help: 291
    Rate: 1697
    I did one with a broken timing chain, 2 chains from the gearbox side.
  • #3 16204832
  • #4 16205403
    dabu
    Level 32  
    Help: 190
    Rate: 695
    The question of the pump giving too much pressure, which made the tensioner pull on the chain like bull's eggs.
  • #5 16206784
  • #6 16207053
    coperfild
    Help: 291
    Rate: 1697
    I remove the belt, the pulley on the shaft, accessories, the alternator, the air conditioning and the engine itself.
  • #7 16207071
    andrzej20001
    Help: 1578
    Rate: 6669
    And ultrasonic clean injectors. Have a specific design cję
  • #8 16207334
  • #9 16207737
    coperfild
    Help: 291
    Rate: 1697
    The chain is always a bit audible, it's probably such a construction, but if you mention it, you know that it will not shoot you.
  • #10 16209339
  • #11 16212262
The discussion revolves around issues with a Golf IV 2.3 VR5 engine, specifically a grinding noise, low voltage lambda heating error, and sporadic engine failures. Users suggest that the grinding noise may be related to the timing chain and tensioner, with some indicating that the oil pump's pressure could be a contributing factor. There are concerns about the longevity of the timing components, with recommendations to replace tensioners and sliders after significant mileage. The discussion also touches on the compatibility of VR6 parts with the VR5 engine and the appropriateness of using 10w40 oil, which some believe may be too thick for optimal performance. Overall, the conversation highlights the need for thorough maintenance and potential component replacements to address the engine's issues.
