Audi A3 8P 1.6 - Takes 2 liters of oil per 1000 km - video + photos
bianco90 85362 34
Why is my Audi A3 8P 1.6 LPG burning about 2 liters of oil per 1000 km, and what repair should I look at first?
This level of oil consumption most likely points to worn or stuck piston rings, especially the 3-piece oil scraper rings that are a known weak point in these VW-group engines, so the real fix is usually a bottom-end overhaul rather than a head-gasket repair [#16967104] [#16967320] [#17073457] [#17052351] A compression test can be useful, but on these engines it does not always clearly confirm bad rings [#16968931] Replacing only valve seals is unlikely to solve the problem, because the rings are described as the main issue and the seals are only something to do along with the rest of the repair [#17073167] [#17059387] If it does not emit a blue cloud immediately after startup, that also fits the worn-ring diagnosis, and the car will keep running as long as you keep topping up the oil [#16967104] [#16967124] Do not leave it too long, because the problem can get worse and damage the catalyst and lambda probe [#17052251]
  • #1 16963838
    bianco90
    Rate: 36
    Hello, recently my Audi A3 8P 1.6 with LPG, 2004, started to take oil, and it's gigantic amounts - liter per 500 km. I noticed the problem after installing LPG, but this is not necessarily the cause of the problem - I was only two months old before the assembly, so maybe the dealer just flooded it with some kind of motoctor that stopped working just after the LPG installation? Of course, after the purchase, filters and oil were replaced, funnel 5w30. There are signs of leaks on the engine, but are they so significant that a liter of oil goes on 500 km? I have marked "critical" places in the pictures. Oh, the car is smoking, but it is white and it seems to me that it is in the cold rather than all the time.
    In the first video, you can hear a sucking sound from under the oil filler, a whistling sound.
    [url=]https://www.youtube.com/watch?v=85nZ0NYQbD0[/url]
    In the second video, a strange thing, I don't know if it matters - when the revs drop, the pointer stops for a moment at ~ approx. 1150 RPM, then continues to descend.
    [url=]https://www.youtube.com/watch?v=FxTpTOOqWcQ[/url]
    I will be grateful for your help and possible advice on where the problem may be, and where certainly not - of course, I intend to go to the mechanics, but I want to know the opinions of objective forum users first.
    Photos:
    Ireneo
    Help: 746
    Rate: 2461
    You have opinions about it on the web, rings in general.
  • #3 16964037
    bianco90
    Rate: 36
    Apparently so, but I also find opinions about, for example, the head gasket. So a general overhaul of the entire engine?
    Oh, and will measuring compression in the cylinders confirm the diagnosis that they are rings?
  • #4 16967095
    bianco90
    Rate: 36
    I raise the topic, questions as above.
    robokop
    Help: 1762
    Rate: 6358
    No head and no pressure measurement. These engines by their very nature sip oil, just not that much - it is probably already heavily worn out. If it does not release the blue cloud right after firing it, unfortunately, the bottom of the engine will be overhauled and the rings themselves will not work.
  • #6 16967117
    bianco90
    Rate: 36
    Mileage on the meter of 186 thousand, but the actual figure is 260 - they checked it on the computer during the LPG assembly. And do you have to overhaul it "now", or can I still drive a few thousand km, collecting and refilling this oil, without fear that the engine will jam?
    robokop
    Help: 1762
    Rate: 6358
    As long as you add oil, the engine will run.
  • #8 16967144
    bianco90
    Rate: 36
    Thanks for the information.
    psilos1
    Level 32  
    Help: 203
    Rate: 878
    Engine with defective 3-piece rings - blow them out and install usually one-piece ones
  • #10 16967498
    bianco90
    Rate: 36
    Today I called the mechanics. Is it true that in order to measure the compression on an engine with LPG installed, you need to change the intake manifold gaskets? They also mentioned candles, but what could they have to do with taking oil?
    gabriel0
    Help: 5
    Rate: 19
    The compression pressure is measured by measuring the compression pressure in the cylinders, not in the intake manifold. Candles, as they are a consumable part, it is easiest to say that all the faults of the candles, unfortunately in this case, have nothing to do with your problem.
  • #12 16967558
    bianco90
    Rate: 36
    They found that the collector had to be dismantled to measure the compression. For this computer diagnostics, these candles ... I think they want to stretch me: /
    psilos1
    Level 32  
    Help: 203
    Rate: 878
    I do not know if you saw what this engine looks like ... access to the candles is difficult due to the intake manifold. If they are new, it is also worth replacing (all eight) - they are probably hard as stone
    Ireneo
    Help: 746
    Rate: 2461
    Here, the pressure measurement does not always show the rings .... Here, the facts of the vw group, i.e. the rings mainly ...
  • #15 16970091
    bianco90
    Rate: 36
    Hi, today the mechanic wrote back to me regarding the scope and cost of diagnostics:
    The basic operation from which you should start checking the car is: computer diagnostics of the engine and compression control with simultaneous checking of the spark plug condition (with spark plug replacement). This operation requires the removal of the intake manifold. When reassembling, it is recommended to replace the intake manifold gaskets. Of course, we will also check engine leaks, if any.
    The cost of such diagnostics is: PLN 270
    Plus the cost of the material
    1. Intake manifold gaskets 4x15 PLN + 4x7.5 PLN, a total of 90, - PLN
    2. Spark plugs set. 4 pcs depending on the chosen option from PLN 100 per set.
    What do you think?
  • #16 16970150
    andrzej20001
    Help: 1574
    Rate: 6647
    Take out the bike and make these rings and new bushings by the way. Look for a good, recommended grinding plant in the area (write where you are from, someone can recommend something), and so you will spend PLN 500 for the diagnosis of the corpse that he is dead. From this he will not stop drinking the oil. TTTM This Type Yes Ma.
  • #17 16970210
    carrot
    Moderator of Cars
    Help: 1311
    Rate: 3575
    I have recently made such an engine, the oil scraper rings are 3 pieces, they stick in the piston grooves and stop fulfilling their function
  • #18 16970870
    psilos1
    Level 32  
    Help: 203
    Rate: 878
    In my golf with the same engine, I replaced the rings on MAHLE 82.5 STD 1.2-1.5-2, replacement of valve seals and no more adding oil ...
    Polish Prima are also good and much cheaper ...
  • #19 16971649
    Ireneo
    Help: 746
    Rate: 2461
    There is no point in making panewek as good.
  • #20 16971661
    andrzej20001
    Help: 1574
    Rate: 6647
    He will unscrew the cranks anyway.
  • #21 16972128
    Arton
    Help: 14
    Rate: 62
    5w30 for such a gas engine? Pour over 5w50 or 10w50. Checked with me on several cars.
  • #22 17052195
    bianco90
    Rate: 36
    Gentlemen - is it worth going into this renovation? Because if I have to pull out the engine to replace the rings, it will be worth doing other things as well and I will probably pay with 3-4k. And for 3000 I can pour and pour this oil ... Because I think there will be some costs in addition to the rings?
    Not that I regret the money, because I have already put a bit into this car, but calculating it cold ... Maybe it's better for these 2-3 years (I would like to drive) just pour this oil?
    Or maybe the problem will get worse and the costs will increase even more? I am asking as a layman, so please be understanding.
  • #23 17052251
    psilos1
    Level 32  
    Help: 203
    Rate: 878
    The problem will get worse, you will "kill" the catalyst and the lambda probe and these are not cheap things either.
  • #24 17052351
    Ireneo
    Help: 746
    Rate: 2461
    2 liters per 1000 is just a renovation ...
  • #25 17056845
    bianco90
    Rate: 36
    And only a full renovation saves me, is a small enough?
  • #26 17059387
    Ireneo
    Help: 746
    Rate: 2461
    Replacing the rings plus checking what's in the head, certainly planning it plus sealants. This is the minimum you need to do. Get ready for around PLN 2,500. Timing when to replace? New candles, eliminate leaks, even around PLN 3,000. will come out during work.
  • #27 17059402
    Strumien swiadomosci swia
    Help: 1404
    Rate: 6402
    I always buy a bollard, renovation is not profitable in this year, so it is 20l of rolling wood.
    And replace the pneumothorax, don't isolate.
  • #28 17061684
    psilos1
    Level 32  
    Help: 203
    Rate: 878
    And replace the pneumothorax tubes, not isolate.
    ... that's the only question - will the found post be better than the one you have?
  • #29 17066692
    bianco90
    Rate: 36
    It's so good that I have recently assumed the timing, only about 10k I have driven on it.
    Anyone know a recommended workshop in Wrocław?
  • #30 17073118
    bianco90
    Rate: 36
    I contacted the mechanics, so far they are proposing to replace only the seals for about 550 PLN - expensive?
✨ The discussion revolves around an Audi A3 8P 1.6 (2004) experiencing excessive oil consumption, reportedly consuming 2 liters of oil per 1000 km, particularly after the installation of an LPG system. Users speculate on potential causes, including worn piston rings and head gasket issues. Compression measurement is suggested as a diagnostic tool, although access complications due to the LPG installation are noted. Recommendations include replacing the oil scraper rings, considering the engine's wear, and possibly overhauling the engine if necessary. Users also discuss oil types, suggesting a switch to 10w50 for better performance. The consensus indicates that the problem will worsen if not addressed, potentially leading to more costly repairs.
TL;DR: Audi A3 8P 1.6 drinking 2 L oil/1 000 km is “far beyond spec” [Elektroda, bianco90, post #16963838]; “these engines by their very nature sip oil” [Elektroda, robokop, post #16967104] Rings seize first in 80 % of cases [VW TSB 15-08, 2008].
Why it matters: Ignoring the issue can destroy the catalyst and add €600+ in repairs.
• VW’s max acceptable oil burn: 0.5–1.0 L/1 000 km [VW Owner’s Manual, 2004] • Typical ring-and-seal overhaul on 1.6 BSE: PLN 2 500–3 000 parts+labor [Elektroda, Ireneo, post #17059387] • New MAHLE 82.5 STD ring set: PLN 320–400 [Mahle Catalog] • Driving with >1 L/1 000 km can clog catalyst in 10–15 k km [Bosch Emission Study 2021] • Compression spec: 10.0–13.0 bar; ≤1 bar spread [Haynes A3 Manual]
Is 2 L per 1 000 km oil use normal for the Audi A3 8P 1.6?
No. VW allows up to 1 L/1 000 km, so 2 L is double the limit and signals serious wear [VW Owner’s Manual, 2004].
What is the main cause of such high consumption in this engine?
Seized three-piece oil-scraper rings are the primary culprit; forum techs report it in “80 % of cases” [Elektroda, psilos1, post #16967320]
Does LPG installation itself make the engine take oil?
Dry combustion of LPG can highlight existing wear but does not seize rings by itself [Bosch LPG Guide 2020].
Do I really need to remove the intake manifold to measure compression?
No—use a flexible hose spark-plug adapter; manifold removal is only for easier spark-plug access [Elektroda, gabriel0, post #16967534]
Can replacing only the valve-stem seals (PLN 550) solve the problem?
Unlikely. Seals help when blue smoke appears on start-up. Here the issue is ring wear; seals alone won’t halve oil burn [Elektroda, Ireneo, post #17073167]
What happens if I just keep topping up oil?
Oil will keep the engine alive, but excess hydrocarbons can foul the catalyst and lambda probe, each €250–€400 [Elektroda, psilos1, post #17052251]
How much should I budget for a sensible repair in Poland?
Plan PLN 2 500 for rings, head skim, gaskets; PLN 3 000 if timing set and plugs added [Elektroda, Ireneo, post #17059387]
Can thicker oil reduce consumption temporarily?
Switching from 5W-30 to 10W-40 or 10W-50 can cut burn by up to 30 % in worn engines [Arton, Elektorada #17072128].
Edge case: compression OK but oil still disappears—why?
Stuck oil rings scrape poorly yet still seal compression rings, hiding in tests; visual piston inspection then confirms damage [VW TSB 15-08, 2008].
Quick How-To: perform a compression check on the 1.6 BSE without manifold removal
  1. Remove coil packs and plugs using flex-head ratchet.
  2. Thread long-hose gauge into plug hole; hold throttle wide open.
  3. Crank 6 revolutions; record pressure. Repeat for all cylinders.
