No Framework: Computer Startup Without RAM - Power Button, Blinking Lights & Sounds
zbigniewczyk 49014 13
What should happen when I press the power button on a computer with no RAM installed?
When you press the power button with no RAM installed, the fans should start, the front-panel POWER LED should light, and the system speaker should normally beep a memory error; there should be no image on the screen [#12684124] The motherboard LED can still be on even if the power supply is faulty, because it only shows that +5V StandBy is present [#12684163][#12684196] If absolutely nothing happens when you press power, the problem is likely in the power/startup path rather than the missing RAM itself [#12684124][#12684163]
  • #1 12684107
    zbigniewczyk
    Hello. Don't ask why, but I have a computer that doesn't have any frame. My question: when there is no RAM in the computer, should anything happen after pressing the "power" button? blinking lights, sounds? Or maybe nothing will start without the frame and nothing happens after pressing the "power" button?
    dt1
    Admin of Computers group
    Help: 7318
    Rate: 8296
    Welcome,
    After starting the computer without RAM, the cooling (fans) should start, the POWER diode on the front panel should be lit. The system speaker should beep (memory error code) - although I had a board that did not squeal from the speaker without RAM. More than that, nothing else should happen (especially no image on the screen).
  • #3 12684132
    zbigniewczyk
    Ok, thanks a lot for the answer. I have a computer without a frame (all the rest is) but when I press power, nothing happens, the computer does not respond to this button, although it is also functional and well connected. Symptoms as if the power supply is damaged, but unfortunately the diode on the motherboard is on ... so the computer does not start and everything seems to be working.
    johnny99
    Help: 19
    Rate: 33
    The LED may be on even if the power supply is damaged.
  • #5 12684191
    zbigniewczyk
    the computer does not start, does not respond to the power button - so a great chance that the power supply is the cause of the problems, since the diode does not matter.
    The fault occurred as follows: someone fired the computer, checked the e-mail and left it without turning off for 8 hours on the road. He probably hibernated or it is not known what is set in windows 7 on the standard .. anyway, when I came across him after 8 hours, he was already turned off (he turned off) and did not respond to the power button. How do you think the power supply failed?
    dt1
    Help: 7318
    Rate: 8296
    The LED on the board lights up when + 5V StandBy is supplied from the power supply. What is this power supply (brand, model / power?)
  • #7 12684210
    zbigniewczyk
    Chieftec 650W CFT-650-14CS
  • #8 12684269
    Januszf777
    Help: 59
    Rate: 46
    Or maybe you can reveal the secret of what is this album?
  • #10 12684311
    RADU23
    Help: 2428
    Rate: 1732
    Kindly start by giving your full configuration.
    Nobody will predict.
    Look at the board's power section for bulged capacitors.
    Disconnect the Power cable and connect the Reset cable to the board connector.
    Press Reset and check if the computer starts up.
    CPU power plugged in ?.
  • #11 12684373
    zbigniewczyk
    everything is in its place and looks good, this is the worst because I can not clearly state the fault. only when I put my ear to the power supply, I hear a sound as if some cinematographer who chews the frames ... something in the pattern of the first seconds of this video at http://www.youtube.com/watch?v=6_-EvyyNJ14 - probably not normally the power supply makes such sounds? when I connect the power supply cable and put my ear, you can hear something like this (silently)
  • #12 12684391
    RADU23
    Help: 2428
    Rate: 1732
  • #13 12684447
    Radio control
    Help: 19
    Rate: 9
    Put the ram, e.g. from a friend and try to turn on the computer. If it does not start, the disk, the processor, test someone on the disc. Alternatively, give the computer to a "doctor", you will pay about PLN 20 and they will check everything separately. Check the cables if they are properly connected to the board , disk, CPU. Check the I / O button on the back of the computer, maybe it is on O and it does not fire. Make sure that there is a current flow in the socket
  • #14 12684552
When a computer is powered on without RAM, the cooling fans should activate, the power LED should light up, and the system speaker may emit a memory error beep, although some motherboards may not beep at all. If the computer does not respond to the power button, it may indicate a power supply failure, despite the motherboard LED being lit. The user reported a Chieftec 650W CFT-650-14CS power supply, which may be faulty. Suggestions include checking the power supply connections, testing with known working RAM, and examining the motherboard for bulged capacitors. If issues persist, professional diagnostics may be necessary.
