Computer Shuts Down Seconds After Starting: Power Supply or Graphics Issue?
NigHteR 49030 12
Why does my PC power off a few seconds after startup, and is the graphics card to blame?
The graphics card could be involved, but the thread’s best answer is to first rule out the power supply, then check RAM and CPU cooling, because the same shutdown symptom can also come from faulty memory or overheating [#8090892][#8093387][#8093799] Remove the GeForce 9600GT and try booting on integrated graphics if available, and test the machine with a known-good, real power supply rather than another questionable unit [#8090892][#8093573][#8094058] If it still shuts down, test the RAM sticks one by one; one user reported an identical case that was fixed by replacing a defective memory module, and another confirmed the system would stay on with no RAM installed [#8093387][#8091818][#8093799] Also check that the CPU cooler is seated correctly and that no push-pin has popped out, because overheating can trigger an immediate shutdown [#8090892] Finally, inspect the electrolytic capacitors around the CPU and in the power supply, and note that one reply suggested the PSU may not be sending the proper 'good power' signal [#8094269][#8090899]
  • #1 8090842
    NigHteR
    I was looking for a similar topic, but I didn`t find any, if there is already one, I apologize in advance.
    Two days ago, while playing, my computer suddenly turned off. When I tried to turn it on again, the computer turned off about 2 seconds after turning it on. I unscrewed it and felt the greatest heat coming from the power supply. I thought it was the power supply`s fault, so I connected another one (Modecom Feel II 350W or something like that), but the problem did not go away. In addition, when I cleaned the graphics card and tried to start the computer, this time it turned off not after 2 seconds but after about 5. Can the graphics be the cause of the failure?
    Equipment I have:
    - main board Gigabyte GA-945GCM-S2L
    - Intel Core 2 Duo E4500 processor
    - Gainward GeForce 9600GT graphics
    - Tracer 4Life 400W power supply
    I have had each of the components for 2 years and there have been no failures before.
    Thank you in advance for your answers and best regards.
  • #2 8090885
    jankolo
    Rest in Peace
    Help: 1792
    Rate: 587
    First of all, check the operation of the set on the POWER SUPPLY.
  • #3 8090892
    neophyte
    Help: 162
    Rate: 50
    The reason may be, among others, a too weak/damaged power supply or an overheating processor.
    Remove the GF9600 and, if you are sure of the efficiency of this Feel, connect it and run the computer using the integrated graphics.
    Check if the processor cooler fits well (one of the push-pins could have fallen out).
    If you have the opportunity to borrow a decent power supply, go for it.
  • #4 8090899
    yogi009
    Help: 848
    Rate: 2655
    It looks as if the power supply was not receiving the "good power" signal.
  • #5 8091818
    NigHteR
    I turned on the computer without any memory inserted and, surprisingly, it didn`t turn off, only the loudspeaker was beeping (but that`s normal, he). So probably either the memory needs to be replaced or the entire motherboard?
  • #6 8092919
    Lzep
    Help: 486
    Rate: 133
    Haven`t you read the previous posts? You have g..... not a power supply
    - do not understand ?
  • #7 8093328
    NigHteR
    And did you read what I wrote until the end? I also checked with another power supply and the computer behaves exactly the same...
  • #8 8093387
    piotr1979
    Rate: 34
    I once had the same symptoms, I replaced everything possible, and in the end it turned out that it was defective (in my case) 1 memory, after replacing it, the computer is still working
  • #9 8093573
    Lzep
    Help: 486
    Rate: 133
    Feel is worth the same - check it with a real power supply!
  • #10 8093799
    djmeeyker
    check the RAM memory, as the predecessor said, if you have 2 sticks, use each one separately... it may also be the CPU`s fault, it happened to me when the sensor of the CPU burned out and in the BIOS it said 150*C and immediately reset it, if it was then reset it. BIOS will then disable the option to turn off the computer at a certain temperature. CPU...
  • #11 8094033
    Lukson
    Help: 162
    Rate: 128
    Without a decent power supply, we have no point in continuing our production in this field. Tracer and this feel are only suitable for throwing them after dogs.
    Moderated By Matuzalem:
    Forget about these types of statements, because the testimony you give yourself with them is not a flattering one.
  • #12 8094058
    Dez1
    Help: 35
    Rate: 39
    Because he got almost the same, if not worse, power supply.
    As my colleagues write - check with a real power supply, because this is the first cause of problems that needs to be ruled out in order to think about RAM, CPU cooling, etc.
  • #13 8094269
    forgetful
    I understand that you removed the skin on the heat sink under the CPU fan, it must have formed there after 2 years, check the electrolytic capacitors around the CPU, they can fail, in the power supply too.
The discussion revolves around a computer that shuts down shortly after startup, with the user suspecting either the power supply or the graphics card as the cause. Initial troubleshooting included replacing the power supply with a Modecom Feel II 350W, but the issue persisted. Users suggested checking the power supply's functionality, ensuring proper CPU cooler installation, and testing with integrated graphics. The possibility of faulty RAM or a defective motherboard was also raised after the user reported that the computer did not shut down when started without memory. Recommendations included using a reliable power supply, checking RAM sticks individually, and inspecting the CPU cooler and surrounding capacitors for issues.
