How to Set Bandwidth Priority for PC Over Laptop on Home Router With 1mb/s Internet
freezzz1 32232 19
How can I set bandwidth priority on my home router so my PC has priority over a laptop and my game ping stays low when the laptop is in use?
Yes—use the router’s Bandwidth Control/QoS on the router that is connected directly to the internet, set the total line speed correctly, and then limit the laptop’s bandwidth so your PC has priority [#12693266] For a 1 Mb/s line, one reply suggested entering about 1024 kb/s download and about 128 kb/s upload, then restricting the sister’s device in the Bandwidth Control settings [#12693266] On the TP-Link TL-WR740N, one reply said you can also use the original firmware’s Bandwidth Control tab, or flash alternative firmware such as Gargoyle if needed [#12693187][#12693256] However, another reply warned that if the upload is already too low and gets clogged, QoS/bandwidth control may not fully solve the lag [#12693233]
  • #1 12693080
    freezzz1
    Hello...
    I have such a problem ;)
    Because I have a wi-fi network at home and my internet is 1mb/s and now the cable goes from the router to the computer and the laptop is via wifi...
    And now when my sister is on the laptop and I play games I have a ping of 500 and now this question is whether it is possible to change in the router so that there is no such lag ? I mean, for example, that in the laptop was weaker internet and in the computer was better and that there was no lag
    add that when my sister is not on the laptop I have a ping of 40
  • #2 12693116
    mbo
    Help: 2333
    Rate: 845
    It depends on what kind of router you have - specify the model.
  • #3 12693150
    freezzz1
    well, because I have two routers :)
    It's like this ;)
    the first one is a tp-link tl-wr543g and there I have the internet connected and from there goes the cable to the computer from port 1 and from 2 goes the cable to router 2
    router 2 is a tp-link tl-wr740n
  • #4 12693165
    hermes-80
    Help: 1177
    Rate: 743
    tl-wr740n - you upload an alternative FW and split the link as needed - make sure which hardware version.
  • #5 12693169
    freezzz1
    hermes could you be clearer ? Because I don't grasp this at all :) .
  • #6 12693174
    hermes-80
    Help: 1177
    Rate: 743
    Find the nameplate (on the router) and read the hardware version of the router from it.
  • #7 12693183
    freezzz1
    Kurde tell me exactly what to go into because I really don't know what is going on.... Sorry ;) .
  • #8 12693187
    etezet
    Help: 65
    Rate: 129
    All you need is the original FW, Bandwidth Control tab.
  • #10 12693201
    freezzz1
    ver 4.23
  • #11 12693210
    hermes-80
    Help: 1177
    Rate: 743
  • #12 12693212
    szafarz
    Help: 38
    Rate: 24
    The easiest way is for your sister to turn off movie/music downloading programs and not sit on youtube (possibly watching online videos). This will suffice completely.
  • #13 12693219
    freezzz1
    shfarz but it's even as she goes through, refreshes the page my ping jumps !
  • #14 12693233
    Heinzek
    Help: 554
    Rate: 494
    You have too low upload and the link gets clogged. For this even QoS or other brandwidth control will not help.
  • #15 12693239
    hermes-80
    Help: 1177
    Rate: 743
    He can always try, after all, games do not need so much bandwidth.
  • #16 12693244
    freezzz1
    maybe some other advice
  • #17 12693256
    hermes-80
    Help: 1177
    Rate: 743
    Well chlipie set Bandwidth Control to OFW - other advice won't be there I don't know what else you expect - you can always change the soft to Gargoyle
  • #18 12693260
    etezet
    Help: 65
    Rate: 129
    Or change the Internet to a faster one.
  • #19 12693266
    szafarz
    Help: 38
    Rate: 24
    If refreshing the page is also too much, you already got the right advice: Bandwitch Controll in the router (the one connected directly to the neostrada/netiostrada or whatever you have). The whole link: download 1Mb (1024kb), upload (I assume, but enter such as you have): 128kb. Limit sister to: Download
  • #20 12734883
    freezzz1
    szafarz wrote:
    If refreshing the page is also too much, you've already gotten the right advice: Bandwitch Controll in the router (the one connected directly to the neostrada/netiostrada or whatever you have). The whole link: download 1Mb (1024kb), upload (I assume, but enter such as you have): 128kb. Limit sister to: Download
The discussion revolves around optimizing a home Wi-Fi network to reduce lag while gaming, particularly when another user is streaming content on a laptop. The user has two TP-Link routers: a TL-WR543G connected to the internet and a TL-WR740N for wireless access. Suggestions include checking the hardware version of the TL-WR740N, using alternative firmware to manage bandwidth, and enabling Bandwidth Control in the router settings. Users also recommend limiting the sister's internet usage during gaming sessions and considering an upgrade to a faster internet plan due to the low upload speed, which contributes to high ping times.
