Rural High-Speed Home Wi-Fi Setup: LTE, T-Mobile/Orange, Huawei & TP-Link, 1.3-2 Gbps Capacity
3696 5
  • #1 16873069
  • #2 16873089
    bogiebog
    Help: 2569
    Rate: 1530
    grze.gajda wrote:
    I would like to build a Wi-Fi network with a minimum capacity of 1.3 Gbps (preferably around 2 Gbps
    It is impossible, built-up, through walls / ceilings, the more it cannot.
    You can try a twisted pair cable to any room where there is a fast WIFI, 5ghz "ac" WIFI router + devices supporting this standard.
    http://www.tomshardware.co.uk/802.11ac-wifi-router-testing,review-33190-4.html
    "repeater" => cuts the bandwidth 2 times.
  • #3 16873114
  • #4 16873555
    m.jastrzebski
    Help: 679
    Rate: 865
    What you write cannot be realized. These bandwidths given in GBit / s written on the router's packaging are marketing, most often all router capabilities that you will not use for one connection.
    In addition, a lot depends on the specific device you attach. If the cell in WiFi AC will only work with 1 antenna (it is written in a very small print), you will be happy when it goes 100mbit / s. Each WiFi gives x2 speeds (upload + download simultaneously) Very few multimedia devices will support high-speed AC standards with 3 antennas. If only WiFi N will be inserted, you already have a fraction of the speed.
    You want good - invest in cables wherever possible. There you get "real" 1000mbit / s without asking. Doing it very well to at least partially meet your expectations will be rather difficult for the amount given.
    Good LTE reception requires an external antenna. So you need an LTE router.
    LTE is free of your requirements, so whatever works. A certain level of PLN 300 would be fine. The shorter the antenna cable, the better.
    For this 1gbit switch, ordinary unmanageable - 200-300 PLN for 16 ports.
    For this the best possible AP. I recommend unifi. probably 400-500PLN for AC versions
  • #5 16875773
    KOCUREK1970
    Help: 3860
    Rate: 5488
    grze.gajda wrote:
    I would like to close myself entirely to PLN 700-800, but with good arguments, I am going to increase the limit to PLN 1000
    The router itself will come out from PLN 600-800 and the rest of the equipment (with your requirements).
    I think you even have to triple your budget for such requirements!
    grze.gajda wrote:
    I would like to build a Wi-Fi network with a minimum capacity of 1.3 Gbps (preferably around 2 Gbps) and sending the Internet from the LTE receiver.
    After 2 Gb wifi? - you can do it on paper, forget it in real life - maybe you can miraculously "hit" 500-600 Mb (but this is only possible in the 5 GHz band).
    Wired? - no home network equipment has network cards faster than 1 Gb.
    It is possible to make a fast wifi network (500-600 Mb with good winds maybe) but not in the money you assumed.
    But be aware that you can spend PLN 3,000 and have only 200 Mb in a maximum of 5 GHz - WiFi has this to itself that nobody, anything and nowhere with it in the lead role in it (even operators have such provisions on WiFi networks in contracts).
    Here is a nice and efficient set:
    https://www.morele.net/router-ubiquiti-afi-hd-1111328/
    Modest and only PLN 1,500 ;) - and this is just ONE equipment with ONLY 2 AP (you wanted something aesthetic :) ).
    With your assumptions, it is like with the renovation of the bathroom: you had PLN 10,000 allocated for the renovation, only PLN 20,000 was finally spent ...
  • #6 16882382
    primabus
    Rate: 9
    And I congratulate you with this Tp-link, I crash this equipment everywhere because it keeps getting stuck, etc. I understand that the configuration is vaginal :)
