Impact of Constant Heat from Radiator on USB, Power, and DVI Cables
Kojot321 10281 4
  • #1 12720152
    Kojot321
    Hello, I have a slightly unusual question. Well, I bought a new computer and since I don`t have a better place in the room (the tall casing doesn`t fit under the desk), it will be placed on the windowsill, next to the desk. There is a radiator under the windowsill and I have some doubts here. Will nothing bad happen to the USB, power and DVI cables if I am exposed to constant heat from the radiator? These cables will constantly be in contact with the surface of the radiator. Would it be wiser to completely switch to a second radiator away from the computer?
    Robert B
    Help: 2027
    Rate: 1412
    They`ll be fine. PVC insulation withstands up to 105 degrees.
  • #3 12720239
    PeteSh
    Level 30  
    Help: 95
    Rate: 71
    For the elegance of the solution, you can consider using a masking strip. There are plenty of them on the market now (not necessarily white ones). You can also use a decorative conduit to hide all the cables going towards the desk.
  • #4 12720258
    safbot1st
    Help: 2719
    Rate: 1585
    Instead of radiators, it is better to take care of the windows, position the equipment so that the wind does not blow rain on your electronics when it is gusty.
  • #5 12720277
    Kojot321
    There will be no problem with this, there is a balcony outside the window and water cannot reach the glass.
