Can Asus K50C be used as a PC monitor after my monitor fell?
Kacprex 26151 5
  • #1 12734050
    Kacprex
    Hello. As the topic. My monitor has fallen today and I don't have any money to buy a new one. However, I have a laptop (asus k50c) and I would like to use it as a second monitor. The question is, can it be done? If so, I would ask for any advice. I would be very grateful as I dreadfully need my PC right now.
  • #2 12734059
    Kuniarz
    Moderator of Designing
    Help: 371
    Rate: 826
    It's not possible. If you look around carefully, you will get a CRT for free, ask around the companies.
  • #3 12734064
    Kacprex
    Ok :) For now, I will probably be forced to get the 42 "plasma ;)
  • #4 12734071
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    As mentioned above - it is impossible to do this directly, but you can use some software that allows you to work remotely on a PC - WTS (present in some versions of Windows), VNC or FreeNX. Of course, to configure the server of such a service, you need to borrow a monitor from somewhere ...
  • #5 12734084
    Kuniarz
    Help: 371
    Rate: 826
    Kacprex wrote:
    Hmm ... I also assumed that possibility ... But could you explain to me why?
    Because the laptop screen connects to the graphics card with a completely different connector than the typical "monitor" connector. Indeed, in this day and age, getting a CRT monitor is not a problem. If you turn well, you can give up some old LCD screens for a four-pack of beer ;-)
  • #6 12734094
    Kacprex
    Thanks for any replies :) I'm going to come up with something on this topic :D
