Using Toshiba Satellite L675 as External Monitor via Network Port Cable
szklanaszklana 13392 4
  • Laptop network port cannot drive an external monitor directly
    #1 15663818
    szklanaszklana
    Hello, I have a problem. Well, in the toshiba satellite L675 laptop my matrix broke down.
    I read that it is possible to connect the so-called external monitor, but despite performing the recommended actions, nothing works. I would like to ask if I have a suitable cable, namely it is gray with network port inputs on both ends. When connecting both laptops to each other and pressing the FN + F5 matrix with a working matrix, nothing happens, I tried this combination also on a broken laptop - the same. I would like to add that I have the toshiba satellite u305-s7449 laptop external monitor at my disposal. I am asking you for help.
  • Network cable cannot turn a laptop into an external monitor
    #2 15664044
    maurycy123
    Conditionally unlocked
    Help: 226
    Rate: 744
    szklanaszklana wrote:
    but despite following the recommended steps, nothing works.
    What kind?
    And correctly.
    I also tried this combination on a broken laptop - same
    J / w.
    You need to connect an external monitor. Alternatively, there is a possibility of remote access (remote desktop), but if it was not configured earlier, you will not do anything with a damaged matrix.
  • #3 15664403
    szklanaszklana
    You mean, I can't make this external monitor using another laptop for it, but I can succeed using the TV as this monitor? And what about this cable - will it be one or another is needed (I checked it on the TV - it also has such an input)?
  • Use a TV or monitor via HDMI or VGA
    #4 15664469
    m.marrcin
    Rate: 8
    You have to use an external monitor (maybe a TV set), it is unlikely to work with the other laptop. You would have to have the remote desktop turned on, as my colleague maurycy123 wrote, and I suspect that you didn't turn it on, because then there would be no topic. As you wrote, you have a TV set - you can connect it with an HDMI or D-sub cable (commonly known as VGA), if both devices have such inputs. You can find what cables and inputs look like in google.
  • #5 15664479
    maurycy123
    Help: 226
    Rate: 744
    Exactly.
    but can it be successful using the tv as that monitor?
    If the TV has the right inputs and the laptop has the outputs.
