DOES NOT WORK - The pad does not work, although it will detect it and install it
kosiorwks 65283 6
  • #1 12770900
    kosiorwks
    Hello, I struggled to create an account here, as I am looking for an answer to my question. I couldn't find help anywhere, uncle google was unsuccessful. I bought the rains Media-tech MT1507. it is not very significant because whatever it is, it should work. The automatic installation was successful, detecting it in your devices as a joystick or something. Windows 8 makes it difficult to find any drivers, but I don't think that is conical at all. OK, the pad works, but when I turn on the pes 2014 game (football), it does not detect this rain in the settings, also in the game - logical.
    And hence my question, how to do it, as I say, there is a pad but it does not work, windows 8 drivers, no usb goes as always, and the problem has been thrilling me for a few hours and I feel damned because I wanted to connect from ps3 (motionjoy, fun up to 2 in at night and nothing, supposedly it was raining from ps3 but it does not work in pesie in settings. So I bought a controller for the PC and also threads ...
    HELP!!! I will be very grateful.
  • #3 12771136
    kosiorwks
    Unfortunately, it did not help. in this program, it does not detect it, although when I turn it on, sei installs ... natomaist from ps3 it detects me, but it does not work anyway: /
    Eh it seems that I am not able to play on a PC pad ...
  • #4 12771479
    DriverMSG
    Help: 3984
    Rate: 4883
    I don't know about PES 2014, but in older versions of this game, to activate the joypad you need to run the setting before starting the game - did you check it?
    Illustrative picture:
  • #5 12772322
    kosiorwks
    Gosh, I wrote that it does not detect me in settings. You didn't even read my post.
  • #6 12772397
    DriverMSG
    Help: 3984
    Rate: 4883
    We did not understand each other. Copy the Xinput program (link I provided) to the game folder. Run Xinput, then setting, and then check.
  • #7 12774028
    kosiorwks
    Ok, after turning on this program, the pad worked in the game but settings cannot see it. And you can't change the keys, turn on the analogs, everything is the other way around. In the game I can not change it and it is as it should, and the settings, as I mentioned, are not even available, they do not read it there. I tried all the options. I would still manage to change the keys, but mainly the problem with analogs. I will add that the ps3 pad has no analog switch.
The user is experiencing issues with the Media-tech MT1507 gamepad, which is detected by Windows 8 but fails to function properly in PES 2014. Despite successful automatic installation, the game does not recognize the controller in its settings. Suggestions include using an Xinput program to facilitate detection, but the user reports that while the pad works in-game, it cannot be configured, and the analog controls are not functioning correctly. The user also attempted to connect a PS3 controller using MotioninJoy but faced similar issues.
