[Solved] Manganese Genesis 200 Gamepad - Issues with Forest and Batman Asylum Gameplay Controls
Bigsnakers 18801 5
  • #1 17964886
    Bigsnakers
    Hello, so I had a Tropper Esperanza pad normally thanks to it I could play Batman Asylum, the Forest, fifa, unfortunately it was damaged I bought a new title pad Mangan Genesis 200. I connected windows installed drivers (as it was written in the manual) I turn on fife everything is fine it works, I turn on the Forest and here there is 1 problem: the pad almost does not respond only when I move the mouse and then when I press any button on the gamepad, the mouse is centered in the middle of the screen, in the settings I have the option of this controller selected, i.e. it detects it. .. Let's move on to Batman, it detects all the super buttons - however, the front knob makes the hero move backwards, and the back knob makes him go forward cxy anyone know a solution?
    Koziolaa
    Help: 7
    Rate: 17
    Hello. x360ce or x360ce_x64 might help. Everything can be set. Copy the program files to the game directory.
  • #3 17965155
    Bigsnakers
    I downloaded this emulator as if it automatically detected some settings for my controller, I threw the 2 created files into the game folder and nothing changed, then the same situation.
    Koziolaa
    Help: 7
    Rate: 17
    The program has 3 files. Put them all in the game folder. There are two versions of the program. Try both.
  • #5 17965434
    Bigsnakers
    Wgl, when launching the program some automatic setting is detected for my controller however, the image of the Xbox360 controller itself is greyed out in this program and there is a red square next to Controller 2.
    I tried both 64 bit and 32 bit versions
    Added after 38 [minutes]:
    It helped.
    Here if someone has the same problem or wants to play games on a PC pad that only support Xbox 360 pads.
    2 links:
    The first helps to resolve the red square and gray gamepad issue in the Xbox360ce app
    https://youtu.be/oPuMWTRb4DY
    The second shows where to put the files from Xbox360 and one more Xoutput (we put it in the folder where the exe file running the game is)
    https://youtu.be/7l4e2BsujjE
  • #6 17965502
    Bigsnakers
    It helped.
    2 links:
    It helped.
    2 links:
