GAME PAD GENESIS PV58 - PAD GENESIS PV58 NO USB RECEIVER WHAT TO DO?
tee2bitz 14880 6
  • No receiver means no wired USB mode
    #1 19069984
    tee2bitz
    HEY, I HAVE A PROBLEM WITH THE GENESIS PAD, MODEL TO PV58. WHEN MOVING, UNfortunately, I lost the ORIGINAL USB RECEIVER WHICH WAS ATTACHED TO THE PAD. AFTER CONNECTING THE PAD TO THE PC VIA CABLES, THE DEVICE IS NOT DETECTED BY THE SYSTEM (WIN.7 X64). I WILL ADD THAT I TRIED TO CONNECT TO PLAY STATION 3 WITHOUT A RECEIVER - NOTHING HAPPENED
    QUESTION 1
    CAN THE ORIGINAL RECEIVER BE REPLACED BY ANY OTHER?
    QUESTION 2
    DOES ANYONE KNOW A WAY TO CONNECT THE PAD VIA A USB CABLE?
    I WILL ADD THAT AFTER HOLDING THE POWER BUTTON FOR 8 SECONDS, THE PAD SHOULD CHANGE MODES FROM AT LEAST X360 TO PS3 MODE - IT DID NOT CHANGE ANYTHING
    DO YOU HAVE ANY IDEAS? :) HELP!
  • #2 19070048
    piotrkol7
    Help: 677
    Rate: 731
    He should change.
    In D-Input mode, it can be connected to a computer via a USB cable.
    The mode change can be recognized by the fact that in the D-Input mode, pressing the middle button changes the lighting mode - the first diode and the first and second diodes (changing the analog operating mode).
    And please, don`t write in CapsLock, it never ends well ;)
  • #3 19070077
    tee2bitz
    I WRITE WITH CAPS BECAUSE I HAVE A MAJOR VISION IMPROPERLY AND I WOULD LIKE TO KNOW WHAT I`M WRITING BECAUSE I DON`T DISPLAY SPELLING ERRORS... #CAPS LOCK MAFIA
  • #4 19070081
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    @tee2bitz Instead of coming up with nonsense, maybe you could enlarge the font in your browser? Ctrl + mouse wheel forward.
  • #5 19070083
    piotrkol7
    Help: 677
    Rate: 731
    I recommend increasing the font on your device, there are such options both on most new phones and in Windows 10, from what I remember - display settings and accessibility settings.
  • Mode switch only works when paired with receiver
    #6 19070090
    tee2bitz
    piotrkol7 wrote:
    You can recognize the mode change by the fact that in D-Input mode, pressing the middle button changes the lighting mode
    IF I REMEMBER CORRECTLY, SWITCHING THE MODE WORKED, BUT ONLY WHEN THE PAD WAS PAIRED WITH THE RECEIVER. WHEN THE PAD IS TURNED OFF, SHOULD I PRESS WHEN THE LEDS ARE ALREADY BLINKING? NEED TO HOLD 8 SECONDS? AT THIS MOMENT, WHETHER THE PAD IS CONNECTED OR NOT, ALL THE LEDS ARE BLINKING (AFTER CONNECTING AT A DIFFERENT SPEED)
  • #7 19070111
    piotrkol7
    Help: 677
    Rate: 731
    Make sure that the cable you connect it with supports data transmission.
    The pad should be turned on and only then should the mode be changed.
    To view the material on this forum you must be logged in.
    Do you have all drivers installed?
The discussion revolves around the Genesis PV58 game pad, which is not being detected by a Windows 7 x64 system after the user lost the original USB receiver. The user inquires about the possibility of replacing the original receiver and connecting the pad via USB cable. Responses suggest that the pad can be connected in D-Input mode using a compatible USB cable, and that the mode change should occur when the pad is powered on. It is also noted that the correct cable must support data transmission, and all necessary drivers should be installed. The user expresses confusion about the mode switching process, particularly when the pad is not paired with the receiver.
