Wireless Genesis P65 Pad Freezes and Lags in The Witcher 3, PES 2017, The Crew, NFS, AC on Win 10
monszy213 9330 19
Why does my wireless Genesis P65 pad freeze, lag, or stop responding in games on Windows 10 64-bit, and how can I fix it?
The problem is likely not the pad itself but interference or a USB/software issue, because both the wireless Genesis pad and the earlier wired Gioteck pad showed similar cutouts [#16616108][#16616240] First, test with the 2.4 GHz Wi‑Fi router turned off and keep other nearby wireless devices in mind, since the pad uses radio communication [#16616131][#16616138] Then try the receiver in the rear USB ports and update the motherboard chipset and USB drivers [#16616270][#16616366] A controller tester such as jstest-gtk showed normal input outside the games, which points more to a Windows/game/software conflict than a broken pad [#16616254][#16616275] If drivers and USB checks do not help, the suggested last resort was a system format/reinstall [#16616366]
  • #1 16616064
    monszy213
    Hello, I bought a wireless genesis p65 pad, after connecting and calibrating it in all the games I used it (The Witcher 3, PES 2017, The Crew, NFS, AC) there were effects as if the pad was freezing, choking. Sometimes for a short moment he did not respond to commands, clicks, and sometimes he would hang and the figure was walking or turning to one side for a while. Earlier I had a wired Gioteck vx-2 and this problem also occurred while playing on a PC.
    I have Win 10 64 bit.
    I am asking for advice.
  • #2 16616108
    safbot1st
    Help: 2719
    Rate: 1585
    Since both pads have the same problem, it must be assumed that something is interfering with radio communication.
    Do you have any such devices nearby? Wi-Fi 2.4GHz?
    The diagnosis would be facilitated by providing a list of components.
  • #3 16616123
    monszy213
    Yes, I have a wifi router right under my desk
    I5-6500
    GTX 1060
    MSI b150m bazooka
    Toshiba P300
    hyperx 8gb ram
    I would like to add that this pad from Gioteck was wired, but it got cut sometimes.
  • #4 16616131
    safbot1st
    Help: 2719
    Rate: 1585
    Then disconnect diagnostically and play "single".
  • #5 16616135
    monszy213
    I have to turn off the router, yes?
    Diagnostically?
  • #6 16616138
    safbot1st
    Help: 2719
    Rate: 1585
    Yes. This is what I proposed.
  • #7 16616149
    monszy213
    No, this is not the fact that there are still second cuts at the witcher, such as turning the camera left and right
    And at the beginning, when I start the game, everything is normal, only gradually everything starts to fall, first it cuts gently, almost imperceptibly and with every minute these pendants are longer.
    I don't know. I live in a block of flats. Next to me, as well as below and above me, people also have wifi routers but it's probably too large a range for it to interfere with the pad?
  • #8 16616240
    safbot1st
    Help: 2719
    Rate: 1585
    This is important info. But for the record - it's not the game stutters, it's the controls itself, right?
    In that case, I would look for the problem in USB, because this is how both pads are connected.
    Enter the model and brand of power supply.
  • #9 16616246
    monszy213
    Yep, the games run smooth as hell, the problem is the controls.
    Chieftec 500w GPA-500s8 power supply
  • #11 16616256
    monszy213
    Even when my friend comes back, he will try to see how this controller works. If it is fine with him, it means that the product is working, only something is fucking with me.
    Ok, I'll see you soon.
  • #13 16616268
    monszy213
    But the question is, how should I open this program?
  • #14 16616270
    safbot1st
    Help: 2719
    Rate: 1585
    Write where you connect to USB. Try rear USB ports. The front ones tend to be of poor quality due to the long, thin, non-connecting Chinese "conductors" that collect noise.
    You fire up bootable linux and install the program from the Internet under it.
    It is worth measuring the voltage from the power supply with a meter:
    https://www.elektroda.pl/rtvforum/topic1199202.html
    Up-to-date drivers are also required for windows chipset and USB .
  • #15 16616275
    monszy213
    I connected both the front and rear ports with the same effect. I updated the BIOS about a month ago or earlier. Everything works very well in this tester. For 5 minutes, I was turning knobs, clicking buttons, and nothing was stuck. I downloaded another tester and everything was fine too. It turns out that when you start games, writing something ugly is crazy.
  • #16 16616366
    safbot1st
    Help: 2719
    Rate: 1585
    It turns out that there is something wrong with your system. Not hardware, but software.
    Please update USB drivers yet. If that doesn't help, the format may be necessary. Usually it's a last resort, but in this case it will just be faster.
    Just don't forget to start uploading from motherboard chipset driver .
  • #17 16616423
    monszy213
    You mean to upload the chipset drivers right after the format? Then all the crap?
    And the usb drivers are to update from Intel?
  • #18 16616432
    safbot1st
    Help: 2719
    Rate: 1585
    Yes. Before the format, try both of these steps.
  • #19 16616495
    monszy213
    Okay, I installed the drivers, and indeed the testers now show crashing raining quite often.
    I also reset the bios settings to the factory settings, now this pad cuts every 2-3 seconds
    But it's also strange because the closer to this "usb plug", the more the pad jams. I set it raining on and it runs smoothly.
  • #20 16618349
    monszy213
    It is still the same. Anyway, I had to do the format but it did not change the correct operation of the controller. I will try to charge it again because it may be a draining battery, but I don't really believe that it will be it. On one of the pages that is testing this, I came across a user who had the same problem as me, except that he is on ps3. Just like him he gets cut when playing.
    "Hello, gentlemen, maybe you can advise something .. I have a small problem with the PV65, or actually the two I bought. While playing fifa, the pad" freezes "from time to time, the player just runs one way and only after a few good seconds all the diodes will flash a few times and the pad returns to normal. Do you know what could be wrong? I thought it was discharging, but when I connect it to charging it also happens "
    He's like the LEDs shine when he gets jammed, but not me, mine just gets stuck.
The discussion revolves around issues experienced with a Wireless Genesis P65 pad, which freezes and lags during gameplay in titles such as The Witcher 3, PES 2017, The Crew, NFS, and AC on a Windows 10 system. The user reports similar problems with a previous wired Gioteck VX-2 pad. Potential causes identified include interference from nearby 2.4GHz Wi-Fi routers, USB connection issues, and outdated drivers. Suggestions for troubleshooting include disconnecting the Wi-Fi router, testing the pad with different USB ports, updating USB and chipset drivers, and performing a system format if necessary. The user also noted that the pad's performance worsens the closer it is to the USB plug, indicating possible interference or power supply issues.
