Creating One Seamless WiFi Network with Multiple Routers in Basement, Ground Floor, and Attic
lolasss 25176 20
How can I set up multiple routers on different floors so they act as one Wi‑Fi network, and do I need a router between the DSL modem and the switch?
Yes — configure the routers/access points with the same SSID and the same security settings so they appear as one Wi‑Fi network [#12820591][#12829954] Put a router behind the DSL modem first; the usual layout is modem → router → switch → the other rooms/APs, because a switch by itself is not enough when the modem is only a DSL modem [#12820578][#12829954] Set the extra devices as access points: connect them via LAN, turn off DHCP on each AP, give each one a unique static IP in the same subnet, and use different Wi‑Fi channels so the signals do not overlap [#12848139][#12827663] With that setup, you can cover the basement, ground floor, and attic under one network name [#12828916]
  • #1 12820559
    lolasss
    Hello! I have a question. Well, I built a house and I'm going to lay all the cables and I figured out that in the basement I will connect a DSL modem from him switch and from the switch ethernet cables to each room, the house has a ground floor + floor + attic. And I wish there was a WiFi Router on every level. and here the problem begins, is it possible to have one network of all this, i.e. one wifi network
    So, for example, wherever I was at home I would have a network, for example: "blacksmith-WIFI" and not 3 wifi, "blacksmith-WIFI, ground floor", "blacksmith-WIFI floor", "blacksmith-WIFI attic" and 2nd case Is the switch itself enough in the basement or would I have to connect the main router, i.e. MODEM ----> Router ----> switch to rooms + routers in the corridors.
    Please also do not answer the type: why do you need 3 router or cable for each room ...
    tomiok
    Help: 133
    Rate: 292
    lolasss wrote:
    ... is it possible to have one network of all this, i.e. one wifi network?
    So, for example, wherever I was at home I would have a network, for example: "blacksmith-WIFI" and not 3 wifi, "blacksmith-WIFI ground floor", "blacksmith-WIFI floor", "blacksmith-WIFI attic"
    Can be.
    lolasss wrote:
    and the second thing is whether the switch itself is enough in the basement
    Not enough ...
    In the basement, there should be a router first - not a switch ;)
    CHACA
    Help: 875
    Rate: 457
    Generally, if you set the same network name in each of them and encryption, it will be visible as one whole. However, you must remember to assign the appropriate addressing to each router. As for the next matter, there must be a router behind the modem that will assign addresses to other routers via a switch.
  • #4 12820615
    lolasss
    Yes, yes, I know the rest, and even if something is full of it on the Internet. So a banal solution. Thanks a lot ! ; )
  • #5 12827593
    peyp
    I connect to the topic.
    Hello, I would like to strengthen the network signal so that you can connect the Internet in the basement, the problem so far was the range of the router. To avoid high costs, I decided to use a second router (instead of an amplifier). signal between each other forming a network. (ie tp link tp link td in 8901g with vivanco virless) What are the possibilities of combining these routers to form a single network?
  • #6 12827663
    lolasss
    In the main router, you set everything normally and in the 2 that I will be connected to the main one, you set the ip to 192.168.154 (the highest that the main router assigns) then you set other channels so that the signals do not overlap. And the roters should be connected via the lan input and on the 2nd router you still need to turn off the dns server.
  • #7 12828667
    szaleniec
    Help: 476
    Rate: 199
    tomiok wrote:
    Not enough ...
    It depends. If the operator gets a router-gateway, often called a modem, the switch itself is enough.
  • #8 12828776
    tomiok
    Help: 133
    Rate: 292
    A colleague wrote:
    lolasss wrote:
    ... connect a DSL modem in the basement ..
    I don't think he would get anything else home - something else in companies.
  • #9 12828808
    szaleniec
    Help: 476
    Rate: 199
    tomiok wrote:
    An individual customer may also have the "Internet DSL" service - I know a few such cases. And even if it were a neostrada or other mass offer, a router-gateway is also often offered.
  • #10 12828857
    tomiok
    Help: 133
    Rate: 292
    It's best to let a colleague @lolasss say what he has at home.
  • #11 12828916
    Nouvion
    Rate: 11
    I have a regular wifi router + 2 WR702N portable routers. Everything set to Repeater mode. Here is a nice description of how to connect: http://www.tp-link.com.au/article/?faqid=397
    Wifi works throughout the house and garden with one network name :D
  • #13 12829954
    jimasek
    Help: 3783
    Rate: 2681
    lolasss wrote:
    So, for example, wherever I was at home I would have a network, for example: "blacksmith-WIFI" and not 3 wifi, "blacksmith-WIFI ground floor", "blacksmith-WIFI floor", "blacksmith-WIFI attic" and
    It's a matter of device configuration (same SSID and security)
    lolasss wrote:
    Looks like some "cable" is supplying you with the internet. Then Modem-> Router-> Switch if you don't have enough ports from the main router itself.
  • #14 12848033
    peyp
    Welcome back. I still have a problem with connecting the router (configuration of 2 routers) I have a router from the Neostrada network. I do not have access to its configuration, by entering the IP address of the router, I cannot find me on the TP-LINK website. The type of router is TP-LINK W8901G. Connection to the telephone network. I am asking for advice and information on how to configure these two devices together and any suggestions why the router and its settings are not visible on the page.
  • #15 12848139
    haring
    Help: 5
    Hello lolasss: you think right, but ... I suggest to leave this router in the basement, while in each level install access points on each of them set a different channel, e.g. ground floor channel 11, attic channel 12 etc. mandatory on each access point ' turn off DHCP - gatewey will be the same leased everywhere from that router in the basement. In addition, on each access point set the same for the network, i.e. the router has, for example, 192.168.1.40 IP allocation from 192.168.1.100 to 192.168.1.200 and on the access points set "hard - manually" 192.168.1.50, .. .. 1.60 etc.
    Install the Ekahau Heatmapper software on the laptop and check the range of each access point
    Added after 6 [minutes]:
    peyp: probably one of them is the so-called main ADSL2 + second you want to connect to the first one and here the question arises what is an ADSL or WAN / DSL router ??? If the WAN / DSL thing is simple, the cable from the main one, plug in the WAN, set the routing, ie the address of the "main" router, if it is ADSL separately, i.e. connect the computer, set the subnet the same as the main one and turn off DHCP nstp. you connect routers (to any port) VOILA should blink, if you don't understand something, write
  • #16 13209555
    tomikos2
    Help: 10
    I'll warm up the topic
    in the company is dsl
    the network looks like this:
    dsl modem (from tepsy) - hereinafter TL-WR740N wifi router connected to it, cameras, 1 computer and 1 switch to a printer switch and a second switch at the end of the building.
    Now I have to redo it so that there is wifi everywhere.
    so it will be:
    dsl modem - TL-WR740N router and two wifi routers in the extreme parts of the building (I'm interested in wifi and switches in them)
    The question is what routers to buy? And how to configure them so that wifi and of course lan work?
    Let's assume that the price for 1 router is around PLN 200 and preferably also tplink.
    Probably the best solution should be assigned by 1 router.
  • #17 13209565
    jimasek
    Help: 3783
    Rate: 2681
    If you are satisfied with the WR740N, you can purchase it and configure it as an AP - Link
  • #18 13209830
    tomikos2
    Help: 10
    thanks a lot for something like that ;)
    I am happy with the router, it works without problems so far, but I was thinking about something with 2 antennas to increase the WiFi range, I understand that no matter what router I buy a tplink for about PLN 200, it will work as I need it?
  • #19 13210184
    jimasek
    Help: 3783
    Rate: 2681
    The two antennas have nothing to do with the range of the router. You only have a faster radio.
  • #20 13210759
    tomikos2
    Help: 10
    which is a plus that my boss will want to have, so I will order with two antennas ;)
    thanks for the help
  • #21 14463756
    kampio
    I will step on the thread asking for help,
    The network is standing and everything worked until it became necessary to expand with an additional router.
    They are all TP-LINK TL-WR940 / 941
    The first router is 192.168.0.1
    on the cable
    the second one is set as AP plugged in LAN 192.168.0.2 and
    another cable is plugged into it, also as AP
    only 192.168.0.3 and here the stairs appear because
    when everything is plugged in, the first and the last one works
    as it should, and the middle one seems to have conflicts
    because the net disappears on it ??
    A question for you and a request for help on how to set up the configuration
    networks, change in those walking as AP
    at 0.21 and 0.22 or something else that I mixed up :|
    Greetings
    Added after 42 [minutes]:
    A little tinkering, and I figured out what I messed up :(
    The one that was supposed to run as AP didn't have DHCP turned off and it was getting messy. Everything is already flashing.
    Sorry for the confusion
To create a seamless WiFi network across multiple levels of a house, it is essential to connect a primary router to a DSL modem in the basement, which will then connect to a switch. Each additional router on the ground floor and attic should be configured with the same SSID and security settings to appear as a single network. Proper IP addressing is crucial; the main router should assign IP addresses, while secondary routers must have DHCP disabled and be set to different channels to avoid interference. Users have successfully implemented this setup using TP-Link routers, ensuring that all devices are connected via LAN ports for optimal performance.
