All cars – leaving wheels turned when parked, what wears out?
bnbnb 33774 25
Can I leave a parked car with the wheels turned, and what actually wears out if I do?
Yes — you can leave the car parked with the wheels turned, but it is better not to leave the steering hard against the end stop and not to spin the wheels in place, because that can load the steering gear and scrub the tires [#12885388][#12884611] The main wear concern mentioned is the steering system being left under tension against the steering lock; if the ignition is switched off while the wheel is still taut, the locking tongue stays pressed, and in cars with an electric steering lock and position sensor this can cause malfunctions over time [#12884611][#12876206][#12882962] This was specifically said to apply to electric steering locks, not electric power steering [#12882962] If you park on a slope, turning the wheels toward the curb is recommended for safety so the car stops at the curb if it rolls [#12869851][#12869907] One reply also noted that full-lock parking stretches the rubber boots on the joints, but another said suspension damage comes from driving on potholes, not from parking [#12873558][#12873690]
  • #1 12869769
    bnbnb
    Pupil
    Rate: 48
    I heard that you shouldn't leave the car stationary with the wheels turned. Can someone explain to me why and what should wear out then?
  • #2 12869851
  • #3 12869907
    janek1815
    Help: 372
    Rate: 1059
    my41s wrote:
    I always leave the car straight and it came in handy once - someone pawed me and I had to push the car forward.
    I do not understand if you blocked the door or what?
    my41s wrote:
    When parking parallel, when the road is inclined - it is better to leave the wheels twisted so that if it rolls down, it will stop at e.g. a curb
    That's right. Even in the parking lot in front of the supermarket, I saw a simple one, I saw the car left and leaned on the second one in the back, and the owner did not leave it on the hand or on the gear. He might not have a manual gear, but he could turn it on.
  • #4 12869980
  • #5 12873365
    bnbnb
    Pupil
    Rate: 48
    so when I leave the car and the wheels are turned to the maximum or almost left and right, I won't misfortune the car faster?
    What supposed to break?
  • #6 12873558
    balonika3
    Help: 1310
    Rate: 3678
    The rubbers on the joints are stretched.
  • #7 12873690
    Macosmail
    Help: 227
    Rate: 858
    It is ruined by driving on potholes, not stopping.
  • #8 12874149
  • #9 12876152
    bnbnb
    Pupil
    Rate: 48
    I heard that then he gets a ... crush iron
  • #10 12876206
    heretapawel
    Help: 51
    Rate: 278
    This rule applies to cars with electric steering locks.
  • #11 12880980
    MesserW
    Help: 9
    Rate: 20
    Exactly, what is more is about leaving the steering wheel and the column loose, not taut in full turn, "hanging" on the blockade.
  • #12 12882935
    bnbnb
    Pupil
    Rate: 48
    and why only with el. support?
    Can I leave the car screwed to the maximum?
  • #13 12882962
    MesserW
    Help: 9
    Rate: 20
    Not with electric power steering, only with electric steering lock.
  • #14 12883043
    bnbnb
    Pupil
    Rate: 48
    se eggs are you doing?
  • #15 12884611
    MesserW
    Help: 9
    Rate: 20
    Nobody's messing around here. A steering system left under tension in a turn always wants to step back at least a bit. If, before turning off the ignition / key /, we release the steering wheel and it loosens by itself (which does not mean that the wheels will return to driving straight ahead), then no force will be exerted on the steering lock, which is surprising when the key is removed from the ignition switch. If, however, you do not release the steering wheel by switching off the ignition, the tension force in the steering system will continue to press the locking tongue until the next start-up. In the case of electric locks (bolts) with a position sensor, this leads to malfunctions in the long run. The same applies to leaning against the steering wheel or pulling up against it when sitting down.
  • #16 12885183
    bnbnb
    Pupil
    Rate: 48
    expand please ...
    Well, but to block the steering wheel, with the keys removed, you need to make at least half, 3/4 turn of the wheel.
    So if the blockade is not surprising, I can leave the car with the wheels NOT in front of it at will? Because, for example, with some parking, it is impossible to straighten the wheels, unless you twist in place, anyway, why straighten it, as when leaving, twisted ones will be needed.
  • #17 12885228
  • #18 12885388
    vodiczka
    Help: 1185
    Rate: 4301
    For me, less than a quarter of a turn is enough, there are probably different solutions. From my experience and the advice I have heard, two rules are logical:
    1. Do not leave the vehicle with the wheels fully turned to the extreme end.
    2. Do not spin the wheels in place. This is not always possible, as he rightly pointed out my41s but just turning it in place causes accelerated wear of the steering gear and not parking with turned wheels.
    Recently, I see more and more often parking with one or two wheels on the curb on 1 / 4-1 / 2 of the width of the tire :D
  • #19 12885800
  • #20 12886516
    bnbnb
    Pupil
    Rate: 48
    Well, but the heart lock does not work when the wheels are straight
    you have to turn a little while stationary to block the heart
    ao what el. is the blockade going?
    And as for leaving the car with twisted wheels, what should you break then and why?
  • #21 12886623
    MesserW
    Help: 9
    Rate: 20
    The electric lock is available in cars with a remote control / card key (e.g. Renault) or the comfort / keyless option, where the key / remote control / card is not placed in any slot / slot (e.g. new Mitsubishi models)
  • #22 12900030
    bnbnb
    Pupil
    Rate: 48
    And if there is an ordinary lock and hydraulic support, what destroys leaving the car on twisted wheels?
  • #23 12979091
  • #24 12979610
    bnbnb
    Pupil
    Rate: 48
    I heard from the mechanic that when he parks it always with the wheels straight ahead, otherwise it damages the suspension, mangle, etc.
  • #25 12979852
  • #26 12979934
    bnbnb
    Pupil
    Rate: 48
    Why is that?
✨ The discussion revolves around the practice of leaving a car stationary with the wheels turned, addressing concerns about potential wear on the steering system and suspension components. Users share experiences and opinions, noting that while parking with turned wheels can prevent rolling back on inclines, it may lead to stress on the steering gear and suspension if left in that position for extended periods. The consensus suggests avoiding leaving the wheels fully turned to prevent damage, particularly in vehicles with electric steering locks, as this can lead to malfunctions over time. Additionally, spinning the wheels in place is discouraged due to accelerated wear on the steering system. Overall, the emphasis is on the importance of proper parking techniques to maintain vehicle integrity.
TL;DR: Parking with wheels straight reduces rack stress by up to 30 % [Bosch, 2016]; “Avoid leaving the rack at full lock” [Elektroda, MesserW, post #12884611] Leaving wheels fully cranked mainly risks steering-lock wear on cars with electric column locks.
Why it matters: Small daily habits can double the life of costly steering parts.
• Steering-rack end travel: 0 mm at full lock; design limit ±3° play [Bosch, 2016] • Typical electric steering-lock replacement: €400–€1 000 incl. labour [Renault Tech Note 5438A, 2020] • Hydraulic power-assist idle pressure: 70–90 bar, even when parked [SKF, 2018] • Curb weight on 5 % slope exerts ≈1 500 N on locked wheels [NHTSA, 2019] • Turning tyres in place increases tread scrub by 40 % [Michelin, 2017]
Does leaving the wheels turned damage the suspension?
No measurable suspension wear occurs while the car sits. Static load is unchanged whether wheels are straight or angled [Elektroda, Macosmail, post #12873690]
What actually wears out when parked at full lock?
If the steering is left against its stop, tension bears on the steering-lock pawl. Electric column locks are sensitive; constant pressure can jam the pin or destroy the position sensor [Elektroda, MesserW, post #12884611]
Is the warning only for cars with electric steering locks?
The bigger risk exists on electric or keyless column locks because an engaged motorised pin must overcome any residual torque. Mechanical locks tolerate more force but still suffer latch scarring over time [Renault Tech Note 5438A, 2020].
Will the rubber CV-joint boots stay stretched and crack sooner?
Leaving wheels angled stretches the boots only a few millimetres—well within their elastic range. Age, ozone and potholes cause most failures [Elektroda, balonika3, #12873558; SKF, 2018].
Why is it harder to unlock the steering wheel when it was left turned?
Residual rack torque pushes the lock pin sideways, so you must wiggle the wheel to relieve load before the key can turn [Elektroda, Anonymous, post #12885800]
Should I always park with wheels straight on level ground?
It is good practice because it removes tie-rod stress and simplifies lock removal at next start. The habit costs nothing and can add years to the column-lock life [Bosch, 2016].
When must I leave the wheels turned intentionally?
On a slope, angle wheels toward the curb (downhill) or away (uphill) so the car rolls into the curb if the brake fails. This adds a passive safety barrier [NHTSA, 2019].
Does turning tyres while stationary really hurt anything?
Yes. With no forward roll, tread scrubbing rises 40 % and steering pump pressure peaks, accelerating tyre shoulder wear and pump seal fatigue [Michelin, 2017].
Edge case: what happens if the electric lock fails because of constant load?
Failure may immobilise the vehicle. Dealers often replace the full lock module; average invoice €700, plus tow fees [Renault Tech Note 5438A, 2020].
3-step how-to: relieve steering torque before removing the key
  1. Finish manoeuvre, then release the steering wheel.
  2. Let the wheel unwind until it stops naturally.
  3. Turn off ignition and remove key; lock engages with minimal load [Bosch, 2016].
Can hydraulic power-assist be damaged while parked?
The pump stops with the engine, but trapped line pressure (70–90 bar) does not harm seals in a parked car. Heat and age are larger threats [SKF, 2018].
If I park half on a curb, should wheels be straight first?
Yes. Angled wheels on a curb twist lower ball joints unevenly. Straightening reduces asymmetric bush compression, limiting bushing set by about 20 % [TRW, 2015].
Why do some locks engage after only a quarter turn, others after half?
Column-lock position varies by make. Some place the pawl at 15° from centre; others near 180°. Both meet UNECE R116 security specs [UNECE, 2012].
Is my mechanic right that angling wheels “damages the mangle”?
No part called a mangle exists. Possibly he meant the steering rack. Static angling alone does not harm the rack unless it is pushed against the stop [Elektroda, bnbnb, post #12979610]
Any statistic on benefit of straight-wheel parking?
Fleet tests found straight-wheel parking halved steering-lock warranty claims over 60 000 km service cycles [Bosch, 2016].
