Mouse cursor moves by itself on Windows 7 with PS/2 and USB mice, MBAM clean
geeknoob 27531 7
  • #1 12898310
    geeknoob
    Rate: 11
    Windows 7. Namely, sometimes the cursor moves on the screen by itself at several millimeters distances. This is not because the mouse is damaged. Tested on PS / 2 and USB and the same with another mouse. Worm or what? MBAM shows nothing after the update.
  • #2 12898451
    mati211p
    HDD and data recovery specialist
    Help: 2585
    Rate: 1133
    Got a laser mouse? Sometimes it happens on a given surface, put some kind of pad on it and check.
  • #3 12898994
  • #4 12899433
    geeknoob
    Rate: 11
    My mouse is optical at http://www.komputronik.pl/product/33206/Sprze...ia/A4_TECH_X6_60D_czarna_EVO_Glaser_60D_.html I have it for about 5 years, I think. So far, there have been no such problems. I do not use mousepads, the mouse is always placed next to the keyboard on a pull-out shelf. I will try with different "washers" and let me know if it stopped doing that.
  • #5 12899811
  • #6 12899832
    geeknoob
    Rate: 11
    e-mega wrote:
    The second important thing is the transparent prism (I'm not sure if it can be called a prism) through which the ray from the diode passes and the reflected beam returns. There must be no dust or fur there. Once I had a cat hair on this part, and I couldn't understand why the mouse wasn't working.
    I had it too, I thought the mouse had died and that's where the hair of the cat's hair was.
    e-mega wrote:
    The mouse has spacers on the underside (rubber or plastic) that are in contact with the ground, they must be cleaned as the mouse behaves strangely
    I clean them when the mouse starts scratching when moving and interferes (at least for me) with my work with the computer. So, as I wrote earlier, I will test different materials for the mouse and let you know how it behaves.
    This prism can be gently cleaned with a hygiene stick and nail polish remover? I do not have isopropyl alcohol.
  • #7 12899995
    fauxkalel
    Do not clean the slides / prisms / transparent elements with something such as a cleaner, it is also best not to use alcohol. Such substances will mattify and only worsen the situation.
    A self-moving optical / laser mouse cursor is almost always the surface on which the mouse lies curved light, sticky gliders that cause uneven or incorrect height from the surface, the sensor or setting the refresh rate too high on the mouse port (if you don't know what about what speech, it probably comes off).
  • #8 12901388
The discussion revolves around an issue with a mouse cursor moving autonomously on a Windows 7 system, despite the user testing multiple mice (both PS/2 and USB) and ruling out hardware damage. Participants suggest that the problem may stem from the surface on which the optical mouse operates, as laser mice can behave erratically on certain materials. Recommendations include using a mouse pad, cleaning the mouse's underside and sensor, and avoiding harsh cleaning agents that could damage the optical components. The user mentions using an A4 TECH X6 60D optical mouse for five years without prior issues and plans to experiment with different surfaces to resolve the cursor movement problem.
