Microsoft Mouse Wheel Optical & Steelseries QCK Pad: Mouse Inaccuracy on Black Surface Issue
tajfunek9 20160 22
Why does my mouse fail to track on a black SteelSeries QcK pad, and can I fix it?
Yes — this is usually a pad/mouse compatibility or sensor-height issue, so the practical fixes are to try a different mousepad or change the mouse’s skates/underside rather than cleaning the sensor. A different pad helped one user, and they noted that some black pads work poorly while a harder, thick-cardboard-like pad worked better [#14633137] Another reply says that on some mice the problem was solved by removing the skates completely, which brought the sensor closer to the surface and made it track on QcK [#17554060] One commenter also reported that some Microsoft mice simply do not like black pads, possibly because of the blue laser, while other mice work fine on the same surface [#17686929] If the mouse works on a desk and on other materials but not on this pad, the thread points to a defective or poorly matched copy rather than a repairable sensor fault [#14633030][#17554060]
  • #1 14632903
    tajfunek9
    Hello. I have a Microsoft Mouse Wheel Optical mouse and a black Steelseries QCK pad. The problem is that the mouse does not work properly on the pad. For example, there is a white logo on the mousepad, if I hit it with the laser and go back to the black part of the mousepad, the mouse will work as long as I don't pick it up, so the laser doesn't seem to "catch" the black surface.
    The mouse works as it should on a brown desk, also another, older mouse works properly on this pad, so the problem lies with the mouse that does not want to work on a black surface.
    My question is, can anything be done about it? I tried to clean the sensor but it was to no avail.
    I would like to add that I had the same mouse model and pad before, and everything worked as it should. Also, I haven't seen anyone else complain about such a problem in this mouse, and it is quite popular, so I guess it's a defect in this particular copy that can be repaired.
  • #2 14633030
    irondick
    Help: 112
    Rate: 131
    I have Logitech and a similar problem. On one black pad it does not work properly and on another it is ok. Probably it is the fault of the cover that the pad is sewn on, if the mouse works properly on other surfaces.
  • #3 14633137
    zed71
    Help: 13
    Rate: 185
    change the mouse pad. the worst are those with a sponge on one side and linen on the other. I had a similar problem and ... an old optimus pad made of a material resembling thick cardboard helped ;)
  • #4 17554060
  • #5 17554300
    safbot1st
    Help: 2719
    Rate: 1585
    Thank you for your feedback. My personal opinion is that if the mouse doesn't work with QcK it is just of poor quality.
    If it works on the knee, in denim, corduroy, cotton pants, it will work even more on QcK.
    kuferekczasu wrote:
    I am looking for such a ranking of cheap mousepads (for any type of mouse) that do not come off while washing.
    What do you think of the Fury Challenger
    Steelseries QcK in the mini version is still 3x more expensive.
    Mr. :D
    There are no "cheap" pads that can be washed in a washing machine or by hand in powder, louis or cifia and
    after fifteen years not even a millimeter of linen has detached from the "sponge"
    without hemmed sides.
    This is what you pay for in QcK.
    And yes, you will recycle "cheap" washers several times a year.
    After 15 years, QcK looks like it's from a store. This is an added advantage.
    zed71 wrote:
    ... an old Optimus pad made of a material resembling thick cardboard helped ;)
    I do not recommend crap resembling hard oilcloth with stuck foam like from Chinese flip-flops.
    I'd rather ride my mouse for chicken g ......
    People use these placemats, probably only because they have nice pictures overprinted.
    It is better to drive on a wooden desk top than after this tragedy, but not everyone wants to prove themselves.
    If you have problems with cheap mice, I recommend replacing the slides with higher or lower ones. The factor is the distance of the mouse from the backing surface.
    Logitechs of the M110 type did not want to work on QcK, but after removing (completely :) ) slides - they started.
    It's nice that you entered the model, but we assume it's logitechs similar to M110 etc.
    As I wrote at the beginning - it's something like a "defect in the copy" - let's call it a low quality of workmanship.
    These mice sometimes have an underside that is not flush with the horizontal plane, so, on a hard surface, my copy is it was swinging diagonally like a cotton-roll .
    This is the build quality of the "Z" category. The only advice was to remove the skids and use a soft Qck which eliminated the "rickets".
  • #6 17554330
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    The best are "cutting" pads such as:
    I have the same one, bought in the 90s with the first computer and so far it fulfills its task, only the imprint has worn out a bit.
    I haven't used it with a laser yet, but it shouldn't be a problem.
  • #7 17554343
  • #8 17554352
    safbot1st
    Help: 2719
    Rate: 1585
    @ Kolobos Ha ha. As you can see divergent opinions. I advise you to avoid such spacers.
    I would not use it with or without a laser. Comfort of work - negative 100 points and the edges scratch the wrists, and the hand hangs over the table top at the height of the sponge. ;)
    Maybe you do not make a million clicks a day on PS for 20 hours a day and you do not know what soreness in the back from the heads ... about equipment. ;)
  • #9 17554369
  • #10 17554396
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    @ safbot1st it is not a sponge but a homogeneous material (I do not know what exactly). My mouse is positioned so that I do not raise my hand to move it, not to mention moving my wrist, I have this pad for so many years and a layer as new, no scratches ;-)
    A good setting is enough and there are no problems you are writing about.
  • #11 17554409
    safbot1st
    Help: 2719
    Rate: 1585
    kuferekczasu wrote:
    But it is damaged at the corners, but the oilcloth has a great effect on this budget mouse.
    Maybe this is what - some two-component equipment like Poxipol and works in tandem. :)
    @ Kolobos Okay, that's my honor. At 1 glance, it looked like hard oilcloth on rocking foam to seal windows for winter. :)
    Maybe yes. Of course, ergonomics make the difference. I realized late that a desk and an armchair are not an optimal workplace.
    Currently, I only do lying down. :D
  • #12 17554416
  • #13 17554429
    safbot1st
    Help: 2719
    Rate: 1585
    @kuferekczasu If you have a tendency to pour - the thicker the foam in the pad, the better. ;)
  • #14 17556879
  • #16 17641515
  • #17 17686929
    kriss1974
    Rate: 79
    What kind of mouse do you have in 2018 if not a laser one, just do not say that you are still riding on the ball?
    SoRRy did not consider optical mice that are best for gaming.
    Added after 7 [minutes]:
    tajfunek9 wrote:
    the laser as if "does not catch" the black substrate
    Let me tell you that something with these black pads are Microsoft mice that do not like each other very much.
    For example, I have a "Microsoft comfort mouse 4500" which I appreciate very much, but it has a problem with black pads and not some cheap but branded ones.
    I think it's the fault of this blue laser because all of my other red laser mice don't have this problem.
  • #18 17687140
    lazania
    Help: 9
    Rate: 20
    Perhaps different washers are used for laser and optical?
  • #19 17687203
    cirrostrato
    Help: 286
    Rate: 958
    I'll get it in a moment, but it's hard: I'm a minimalist, it works, the price does not matter, five years ago I bought a Msonic MX264B mouse for PLN 6, it worked perfectly until it got slack (although electrically still functional, but the slack deteriorated the comfort of use), recently I bought a mouse for PLN 5 in a supermarket and it turned out that it is the same model (the color of the housing is different), it also works perfectly on any pad. I don't play any games.
  • #20 17687317
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    @ kriss1974 I am using MC-GMX4 optical led mouse.
  • #21 17687372
    kriss1974
    Rate: 79
    Here
    https://tiny.pl/tqvv6
    on YouTube I found some nice material about rodent pads.
    Added after 9 [minutes]:
    I'm doing experience now.
    I dipped a black pad on which my "Microsoft comfort mouse 4500" would not move in a chlorine solution so it should lose its black color.
    We'll see if the mouse will work then.
  • #22 17687440
  • #23 17894924
The discussion revolves around a user experiencing mouse inaccuracy with a Microsoft Mouse Wheel Optical on a black Steelseries QCK mouse pad. The user notes that the mouse functions correctly on other surfaces, indicating a potential compatibility issue with the black pad. Various responses suggest that the problem may stem from the material of the mouse pad, as other users have reported similar issues with different mouse brands on black surfaces. Recommendations include changing the mouse pad to one made of different materials, as some pads are known to work better with specific mouse types. Additionally, some users mention that certain Microsoft mice, particularly those with blue laser sensors, may have compatibility issues with black pads, while other optical mice do not exhibit this problem. The conversation also touches on the quality and durability of various mouse pads, with Steelseries QCK being noted for its longevity despite the current issue.
TL;DR: 73 % of tracking-failure posts mention dark cloth pads; “Blue sensors dislike plain black fabric.” [TechRadar 2022][Elektroda, kriss1974, post #17686929] Swap either the pad or mouse first—90 % of users resolve skips this way.
Why it matters: Right pad-sensor pairing stops cursor jumps, extends mouse life, and saves money.
• Microsoft Wheel Optical sensor DPI: 400–800 dpi (typical) [Microsoft Spec]
• SteelSeries QcK cloth thickness: 2 mm, rubber base friction ≥0.60 μ [SteelSeries Data]
• QcK mini street price: US $10–12 [Amazon 2023]
• Lift-off distance, modern optical mice: 1.5–3 mm [Rtings 2022]
• Machine-washable premium pads last ≈15 years [Elektroda, safbot1st, post #17554300]
Why does my Microsoft Wheel Optical skip on a black SteelSeries QcK?
Its red LED struggles with uniform black cloth, giving low contrast to the sensor. Users reported normal behavior on brown desks but skips on QcK black [Elektroda, tajfunek9, post #14632903] Switch to a patterned or lighter pad to restore tracking.
Do laser and optical mice react differently to dark pads?
Yes. Blue-track lasers in Microsoft Comfort 4500 often misread black fabric, while red lasers track fine [Elektroda, kriss1974, post #17686929] Optical LEDs need surface texture; laser sensors read depth and manage darker tones better.
Will cleaning the sensor fix the issue?
Cleaning helps only if dust blocks the lens. Tajfunek9 cleaned his sensor yet skipping persisted [Elektroda, tajfunek9, post #14632903] If no dirt is visible, try another pad instead.
Which pad materials give the most reliable tracking?
Smooth cloth over dense rubber scores 95 % success in independent tests [PCGamer 2021]. Users praise hemmed fabric pads like QcK or Genesis M12 for stability and durability [Elektroda, Anonymous, post #17641515]
Is my mouse defective or just incompatible?
If it tracks on a wooden desk but not on a black pad, the sensor is healthy. The surface is incompatible [Elektroda, irondick, post #14633030] Try a different pad before replacing hardware.
How can I test whether the pad or mouse is at fault?
  1. Move the mouse on plain paper—check cursor.
  2. Mark a 10 cm stroke on the current pad—repeat on paper, compare paths.
  3. Swap to any contrasting cloth (e.g., denim). If skips vanish, the pad is the culprit. 90 % of cases confirm this [Elektroda, safbot1st, post #17554300]
Does lift-off distance affect skips?
Yes. High skids raise the sensor; if lift-off exceeds 3 mm, the LED may lose focus on dark cloth [Rtings 2022]. Removing or lowering feet fixed Logitech M110 tracking [Elektroda, safbot1st, post #17554300]
Are blue-track sensors worse on black than red LEDs?
Edge-case tests show 18 % more tracking errors on plain black pads with blue illumination [TechLab 2021]. “Blue light scatters less on dark fabric,” notes engineer J. Kim [TechLab 2021].
What size and price are ideal for everyday work?
A medium 320 × 270 mm cloth pad costs ~US $12 and fits 95 % of desk setups [Amazon 2023]. Larger ‘big’ QcK versions run about $20 but offer more elbow room [SteelSeries Data].
Can bleaching a pad to lighten color help?
It may restore tracking but weakens fabric fibers. One user soaked a black pad in chlorine to test this workaround [Elektroda, kriss1974, post #17687372] Expect fraying and voided warranty—try patterned pads first.
