Repairing Solo HD Beats by Dr. Dre Headband: Best Glue & Techniques for Broken Plastic
41607 19
How can I repair a cracked Beats Solo HD headband, and what glue or reinforcement should I use for the broken plastic?
Use a two-component epoxy, but don’t rely on glue alone because the headband is under stress; reinforce the crack mechanically with a thin aluminum or spring steel plate, wire/strip, or similar insert, then let the epoxy cure for about 24 hours [#12909248][#12909318][#12909326][#13097985] For a more durable repair, identify the plastic type first (often marked on the part) and use an adhesive or plastic-welding method suited to that material, since ordinary glues may not bond PE/PP-type plastics well [#12982356] Several replies also suggest that if the crack is severe, a professional plastic weld or a full replacement headband may be the only lasting solution [#13097985][#13015208]
  • #1 12909024
  • #2 12909248
    ioiok
    Rate: 10
    It will not be it anyway, but it will be best to use a two-component epoxy glue, you can buy it in almost all electrical wholesalers, for plastic it is probably one of the best glues, but you have to leave it to dry for about 24 hours, even if it was written for a shorter time.
  • #3 12909318
    kemot55
    Help: 184
    Rate: 147
    Glue alone is not enough. You need to paste the "core" (wire, thin tape). If the cross-section of the crack is of a reasonable size, you can drill holes there and glue the cores, and then glue everything together. But rather, it will fall apart over time. I would give up the aesthetics a bit and try to strengthen it mechanically (e.g. attach a parallel thin, elastic (metal) tape from the top (just be careful because you don't know what goes through the middle there).
  • #4 12909326
    Błażej
    Help: 1923
    Rate: 3627
    Strengthen this crack from the bottom by sticking the headband, for example, with a thin aluminum sheet or a strip of some plastic. The latter, if found from the same material group, can be welded to the original part.
  • #5 12909664
    yogi009
    Help: 850
    Rate: 2658
    Take a bit of shavings from the broken element and look for a solvent that dissolves the material. Then it would be worth finding a similar material and, after dissolving it, make the best glue for a given type of "plastic". You strengthen the headband with a mechanically resistant element (for example a steel plate) by sticking it and pouring it from the outside. If you hit right with the solvent, this combination will be as durable as the original.
  • #6 12909809
    anet870
    Help: 67
    Rate: 248
    Trim it with leather or other material and it will be grazing :)
  • #7 12912271
  • #8 12912331
    Błażej
    Help: 1923
    Rate: 3627
    With this approach, you can't actually fix it. The headphones are cracked, right? Not usable at the moment, right? If you cut the lining or take it off somehow and stick the headband with one of the proposed methods, you probably won't hurt a lot. And sticking such headphones together is not a flight to Mars, which you are trying to equate to yourself here. you got very accurate advice and a description of several different and effective methods. So it's time to take your fingers off the keyboard and get down to business.
  • #9 12912337
    yogi009
    Help: 850
    Rate: 2658
    Once again ... You put a steel plate (springy) to the upper and lower part of the headband. You wrap it with natural string. You pour the appropriate glue. Ultimately, you should try to obtain an additional "coating" that mechanically stabilizes the entire structure. Well, as someone wrote above, you cover it with leather and you have limited edition headphones :-)
  • #10 12912360
  • #11 12933651
    ioiok
    Rate: 10
    Show off how it turned out and what repair method you chose, others will have proven methods in the future when they break their headphones.
  • Epoxy reinforcement failed; internal cable also broke
    #12 12977991
  • #13 12978028
    Błażej
    Help: 1923
    Rate: 3627
    What did the resin detach from? From a plate or plastic? Looks like you glued something wrong. Send it in and I'll try to fix it :D If there is anything else ...
    Can't match the headband from some other cheaper headphones?
  • #14 12978052
  • #15 12978246
    anet870
    Help: 67
    Rate: 248
    Insert a picture of what is left, we will adjust something or put it together. Many are on the market and exchanges of used headphones with razed speakers, such as low-budget Philips Esperanza tdk firsty etc. :)
  • #16 12978764
    yogi009
    Help: 850
    Rate: 2658
    Did you wrap it with string before epoxy pouring?
  • #17 12982195
  • Identify plastic type before choosing adhesive
    #18 12982356
  • #19 13015208
  • #20 13097985
    elektronic-27
    Rate: 31
    You're right, you can't. You can stick something that has no stress. You have to do like here Link . So you either take them to where they weld plastics and maybe they will do it for a few zlotys, or you have to blend something in yourself.
The discussion revolves around repairing the broken headband of Solo HD Beats by Dr. Dre headphones. Users suggest using two-component epoxy glue for strong adhesion, emphasizing the need for mechanical reinforcement, such as inserting a wire or thin tape, and possibly using aluminum or steel plates for added stability. Some recommend checking the type of plastic for appropriate adhesive selection, while others propose creating a new metal headband due to the difficulty of effective repairs. The author shares their unsuccessful repair attempts, leading to the conclusion that a new headband may be necessary.
