Seeking Confirmation on Ground Warning Tapes Colors & EN Standards for Energy, Water Supply
rafal2893 46287 6
  • #1 12915993
    rafal2893
    Rate: 14
    Hello. Where can I find standards for ground warning tapes for energy and water supply?
    these tapes are buried about 20cm above the cable / sewer pipe.
    I will add that I was looking in Uncle GOOGLE
    tape:
    BLUE for cables with a rated voltage below 1 kV
    RED for cables with a rated voltage above 1 kV
    + text "attention cable"
    BLUE - WATERPOWER?
    WHITE - BLUE?
    GREEN - ???
    WHITE - GREEN thermal energy networks
    BROWN ???
    BLACK ???
    + the inscription "NOTE WODOCIĄG" or "KANALIZACJA"
    I learned this from the site:
    http://ptsrabka.pl/systemy-oznakowania-sieci/
    I am looking for confirmation of this in EN standards - ___ ___ and markings
    other colors for tapes for sewerage?
    TWK
    Electrician specialist
    Help: 220
    Rate: 510
    There are also orange for telecommunications cables.
    The colors of the foil for power cables are described in the PN-76 / E-05125 and N SEP-E-004 standards.
  • #3 12916243
    rafal2893
    Rate: 14
    thanks to that i meant part of it. and as for the standards for markings of warning tapes for water pipes are also there?
  • #4 12917156
    stomat
    Help: 257
    Rate: 1982
    You would have to ask on the waterworks forum. Yellow is also often used for telecommunication cables, but I don't know if there is any "holy script" for it.
  • #5 12919148
    TWK
    Help: 220
    Rate: 510
    stomat wrote:
    Yellow is also often used for telecommunications cables
    Yellow is for gas. The most important thing when it comes to security.
    An example of what ends up with a mistake while working on gas:
    http://warszawa.fotolog.pl/4,2005,archiwum.html
    http://wiadomosci.wp.pl/kat,1342,title,Wybuch...owie,wid,7054297,wiadomosc.html?ticaid=1119cc
  • #6 12919930
    voytalo
    Help: 61
    Rate: 130
    Blue tape, width 20 cm with the inscription "ATTENTION WODOCIĄG". Without the inscription is also applicable and it is not illegal. Brown tape, often marked "CAUTION SEWAGE", to mark sewage discharge pipes. Yellow for gas, but also for district heating pipes (also often described). Orange ribbon with description is currently used for telecommunications. In the past, yellow was actually used to mark telecommunications cables.
  • #7 13025767
    malina998
    Rate: 44
    Yellow - Gas
    Blue - up to 1 kV (but there is some telecommunications connection)
    Red - above 1 kV
    Orange - Telecommunication cables (e.g. Note !!! Optotelecommunication cable)
    In addition, it can be Yellow with an appropriate imprint and purple for district heating,
    Blue, green, brown with an appropriate imprint for water supply or pressure, sanitary sewage systems;
    Well, it was probably already described above :) Unfortunately, you can often encounter many surprises underground ...
The discussion centers on the standards for ground warning tapes used for energy and water supply applications, specifically their colors and associated meanings. Users confirm that blue tape is designated for cables with a rated voltage below 1 kV, while red is for those above 1 kV, both marked with "attention cable." Additional colors mentioned include yellow for gas, orange for telecommunications, and brown for sewage. The PN-76/E-05125 and N SEP-E-004 standards are referenced for power cable markings. Users seek further clarification on the EN standards for water pipe warning tapes and their specific color codes.
