Epson XP-205: Black Ink Not Printing, Cartridge Recognized, Color Prints Fine, Head Cleaning
krisxxl 47523 9
Why does an Epson XP-205 print colors normally but produce no black from text and nozzle tests, even though the black cartridge is recognized?
If the nozzle check shows no black at all, the black printhead/nozzles are clogged, air-bound, or possibly damaged, so the problem is in the black ink path rather than cartridge recognition. [#12924457] The black channel may also be suffering from a venting or feed problem, where ink reaches the nozzles too slowly. [#12924560] A suggested fix is to rinse only the black head with head cleaner, IPA, or glass cleaner, leave it for a day, and then repeat the head-cleaning cycles. [#12924560] The nozzle check is the key test here, because it should show all colors, including black, and if black never appears the black channel is the failing one. [#12923171]
  • #1 12920792
    krisxxl
    Help: 122
    Rate: 202
    I have a practically new printer that first ran out of black ink, so I used mixing the color inks to get a black print. Then the color ran out, so on the same day I bought all the color replacements and installed it to the printer and it started. Black ink does not print at all, but the cartridge itself is recognized correctly. Color prints flawlessly. Cleaning the heads (repeatedly) does nothing but consumes ink. At first I assumed that the problem was caused by the drying of the black head, because it hadn't been used for quite a long time. But this is probably not a problem, because if I accidentally ran a table printout from Excel, where the frames were black and the text was also black, the frames were surprisingly printed in black, but the text was not! What's more, the frames are so perfectly printed that they look like from a laser printer and there is not even a single black dot in place of the expected text. So I suppose the problem is not a dried-up head, but somewhere else, but where? Where to look for the problem? Factory reset didn't help either.
    Regards
    Krystian
  • #2 12923171
  • #3 12924318
    krisxxl
    Help: 122
    Rate: 202
    The nozzle check printout shows only the colored inks. There is no droplet from the black. The grayscale printout changes nothing. In both cases, from Excel, an empty table is printed in black and there is no text. In Word, regardless of whether I print with the gray option selected or not, it prints nothing in black, neither black and white pictures, nor tables, nor text. Interestingly, the amount of black ink is decreasing rapidly, for example when I order photo-quality printing.
    Regards
    Krystian
  • #4 12924444
    sorier
    Level 30  
    Help: 166
    Rate: 635
    krisxxl wrote:
    the amount of black ink is diminishing, and at a rapid pace
    Does it lose it physically from the cartridge or only on the ink level indicator on the display or on the computer?
  • #5 12924446
    krisxxl
    Help: 122
    Rate: 202
    It is depleting on the indicator in the printer driver. Physically, I don't know if it's declining, because I don't know how to check it.
    Regards
    Krystian
  • #6 12924457
    sorier
    Level 30  
    Help: 166
    Rate: 635
    If the black one does not check the nozzles, the head to the head is clogged / dry, or possibly damaged. When printing, black is sometimes folded from colors and sometimes printed from black, but all colors must always be included in the nozzle test.
  • #7 12924467
    krisxxl
    Help: 122
    Rate: 202
    I am aware that you may suspect a dry nozzle and mixing colors to obtain black, but I do not like it when printing a table from Excel, because the black obtained there is too black for mixing colors. I know what black was from the black cartridge and I know what it was from mixing colors - these are two different shades.
    Regards
    Krystian
  • #8 12924560
    sorier
    Level 30  
    Help: 166
    Rate: 635
    Since you are sure that it is black over black, it is possible that the printhead is clogged with air, or the cartridge has a problem with venting and ink flows into the nozzles too slowly. To print the table, relatively little ink is needed, so the table is printed, and before each printout of the nozzle pattern, the printer cleans the heads, using all the ink that has already flowed into the nozzles, and the test looks like it looks like. Yes, my theory :)
    I would advise you to rinse the heads (black only) with head cleaner, ipa, or glass cleaner. Leave it like that for a day and try to clean the heads systemically. This may have to be repeated several times.
  • #9 12925361
  • #10 12931017
    krisxxl
    Help: 122
    Rate: 202
    Unfortunately, it didn't work. The printer gave up the ghost completely. After starting it, it moved the ambulance as standard and then the LEDs went out and I can't start it anymore. Anyway, I have to buy a new one, and I will take this one apart and see what's inside :) I would like to thank all those who are interested for their help.
    Regards
    Krystian
The discussion revolves around an Epson XP-205 printer experiencing issues with black ink not printing, despite the cartridge being recognized and color prints functioning correctly. The user initially attempted to mix color inks to produce black but later found that the black nozzle was not functioning, as indicated by a nozzle check printout showing only color inks. Suggestions included checking the printer driver settings, potential clogging of the printhead, and the possibility of air blockage or venting issues with the cartridge. The user reported rapid depletion of black ink during print jobs, leading to further troubleshooting attempts, including head cleaning. Ultimately, the printer ceased functioning entirely, prompting the user to consider purchasing a new unit.
