Epson L386 Printer Not Printing in Color: Inks Present, Only Black & White Prints
noxsidus 13176 7
  • #1 16982912
    noxsidus
    Hello, for about a month the printer does not want to print in color and everything comes out in black and white, even though the inks are. Please help :/
  • #2 16987504
    Mardok2
    Help: 17
    Rate: 55
    The nozzles may be clogged, try cleaning them with a special printer nozzle cleaner.
  • #3 16989406
    fifek62
    Help: 66
    Rate: 288
    Perform Printing Preferences -> Maintenance -> Advanced Ink Flushing. It should help, I hope the transport knob is turned to print? :)
  • #4 17725182
    fryck
    Rate: 13
    What exactly this option means because it is described strangely as if it was to pour all the mascara. How exactly does it look advanced rinsing because the lack of colors and after the usual nothing much has improved.
  • #5 17725742
    fifek62
    Help: 66
    Rate: 288
    This option is such cleaning only with 5 times stronger.
  • #6 17725876
    fryck
    Rate: 13
    Something managed to save is how to take care of this printer? Release a color page once a week if it does not print? Although I think it is far too often. Color will go to the maintenance of the head buhahaha
  • #7 19610434
    leszekcie56
    Rate: 13
    I have the same problem with the L 382 (Epson) printer. It ran white sheets. After replacing the fuse and cleaning the head, it only prints in black. Maybe some hints.
  • #8 20249109
    fryck
    Rate: 13
    You have to print something from time to time and not keep the printers open, especially in summer. Thorough cleaning and usually solved problems for the time being.
    I have two printers from this company
The Epson L386 printer is experiencing issues with printing in color, producing only black and white outputs despite having ink. Suggested solutions include cleaning the nozzles with a specialized cleaner, performing an advanced ink flushing through the printer's maintenance settings, and regularly printing color pages to prevent clogging. Users have noted similar problems with other Epson models, such as the L382, and emphasized the importance of regular maintenance and cleaning to ensure proper functionality.
