Epson XP-235: Replacement Cartridges Installation & Compatible Brands for Windows 10 and Wi-Fi
Blancos1910 9054 5
  • #1 16332135
    Blancos1910
    Hey,
    I have a problem with the Epson XP-235 printer, I bought a set of replacement cartridges and I can not install them. The printer does not recognize ink. Does anyone know how to install this type of ink in the correct way? Possibly which company's replacements are easy to use? I have windows 10 and connect to the printer after Wi-Fi.
    Moderated By rys57:
    3.1.18. Do not send links that will cease to be active after some time. This will make the discussion lose any sense.
    All you need is a type and possibly a producer.
    The link has been deleted.
  • #2 16332178
    magir
    Help: 128
    Rate: 379
    Did you exchange one, two or all?
  • #3 16332488
    Blancos1910
    I just wanted to mention black, because the rest is Jezi.
  • #4 16333097
    magir
    Help: 128
    Rate: 379
    Well, based on my experiences, I know that either they are all replacements or originals. Other configurations did not work.
  • #5 16340618
    Blancos1910
    And someone can recommend replacements that do not cause a problem? Because the ones I bought do not work.
  • #6 16341583
    magir
    Help: 128
    Rate: 379
    Once I had Epson, I did it - I searched for Allegro who sells such replacement cartridges and has 100% positives (but a few thousand not a few hundred). In such cases, the printer will accept them without problems - but all of them must be replaced.
