Seeking Service Manual for Assembling BMW E46 N42 Engine from Disassembled Parts
dorek83 7980 4
  • #1 12921582
    dorek83
    Rate: 28
    Hello, I need help because I have to put the engine in the above-mentioned car. I got the car dismantled, i.e. without the head and chain. I have a carton of screws and parts. I need a service manual, I will be grateful for help.
  • #2 13545861
    ComTom
    The engine is simple in its construction. As for the schematics, you have here realoem parts from which this engine is built http://www.bmwstore.pl/en/katalog/grupa/11-silnik/i47653/kL/sN
    The problem is correct setting of timing (you need specialized tools for blockade to set the price per 1000-1200pln) Also, it is already in parts to check if the tensioning rails are not cracked and if the tensioner is already corrected or faulty http: // imageshack. us / photo / my-images / 833 / zdjcie0600.jpg / corrected is the one with smaller holes and the final designation 680. Good luck
  • #3 13546388
    dorek83
    Rate: 28
    Thank you for the answer but the car has been driving for a long time.
  • #4 14966043
    darek2640
    Valve BMW 318 1.8 engine N42
    In turn, what and how to dismantle, assemble.
    http://tis.bmwcats.com/doc1070375/
    You can use a Google translator, but everything is known after pictures.
  • #5 15689110
    dorek83
    Rate: 28
    engine put together thank you for help. Topic is closed
