Peugeot 306 phII - Micro switch of the pug 306 remote control key (single button
Gandziorz 7884 12
What micro switch should I solder back into a Peugeot 306 Valeo single-button remote key after the original button fell off?
For this Valeo Peugeot 306 one-button remote, a suggested replacement is an SMD micro switch EVQP2, 4.7 × 3.5 mm with 2.5 mm height [#13632203] Another reply notes that ready-made replacement buttons for this remote are also sold on auction sites [#12986245]
  • #1 12985188
    Gandziorz
    Rate: 53
    I have a minor problem, so in Peugeot 306 the pilot has not been working for me since he fell.
    When he fell to the ground, there was a button and a micro switch that I did not find.
    Does anyone know what micro switch should be here?
    Valeo car key 09728319D.
    View of the housing:
    View on the plate:
    If someone has already processed this topic, I would be extremely grateful for the answer that the micro switch should solder.
  • #2 12986245
    leonek4
    Help: 104
    Rate: 638
    On the popular auction site there are the appropriate buttons for this remote.
  • #3 12986385
    Gandziorz
    Rate: 53
    leonek4 wrote:
    The popular auction page has the right buttons for this remote control.
    I did not find one with a single button.
    I found such a picture on the net.
    You can see on this button only I do not know what is its size and height.
  • #4 13632129
    nadrat1
    Rate: 8
    I have a similar problem - the Peugeot 306 identical key, has it been possible to match the right microstic?
  • #5 13632203
    mario12341234
    Rate: 32
    See this one. There are also other dimensions available.
    MICRO SWITCH SMD 4.7x3.5mm h = 2.5mm EVQP2 [1pc] # M1 (number 4201671044)
    shop sm-elektronik_en search on allegro
  • #6 13897917
    lewandi
    Hello, Is this key in the picture with or without an immobilizer.
  • #7 13898628
    pepe150
    Level 36  
    Help: 288
    Rate: 944
    PHIIs rather had immo in the key.
    The remote control for one button controls the central infrared lock.
  • #8 13898988
    lewandi
    I have the same key and it turned out that I have immo.
  • #9 13899141
    pepe150
    Level 36  
    Help: 288
    Rate: 944
    Just do not mix Immo with the central locking remote control.
    These are two separate things.
  • #10 13900258
    lewandi
    Yes, but the key must be somewhere immo, because there is a loop on the ignition.
    At least I think so
    Lewandi
  • #11 13900820
    pepe150
    Level 36  
    Help: 288
    Rate: 944
    Such a black tablet in the housing of the key. This is immo.
  • #12 13902660
    lewandi
    Yes, only last Thursday I lost the only car key and now I have a problem.
    Fortunately, I have a remote control from an auto alarm (the previous owner has installed a car alarm) and I can open the car without damaging the external locks.
  • #13 13904680
    pepe150
    Level 36  
    Help: 288
    Rate: 944
    Computer for electronics what Immo cried. And Peugeot gave two keys and an insert, I guess. Then he changed to two keys.
    If you want to go to the original, you are looking for a set of locks together with the ignition lock and you are mounting it in your car, including the ignition key.
The discussion revolves around a malfunctioning remote control key for the Peugeot 306, specifically the Phase II model. The user reports that the key's micro switch was lost after the key fell, and seeks assistance in identifying the correct micro switch to replace it. Several participants suggest looking for replacement buttons on auction sites and provide dimensions for a compatible micro switch (SMD 4.7x3.5mm, height 2.5mm). The conversation also touches on the presence of an immobilizer in the key, clarifying that the remote control and immobilizer functions are separate. Users share experiences related to key loss and the implications for vehicle access.
