Philips 40PFL8007K TV: No Power, Red LED Flashing, Fault 53 in SDM Mode - Guidance Needed
stolkien 48363 34
Can the Philips 40PFL8007K error 53 with a flashing red LED be fixed by reprogramming the NAND firmware, or does it require a mainboard replacement?
This fault is usually not fixable by loading Philips firmware into the NAND with a programmer; for these 2012 QFU1.1E LA sets, users reported that Philips firmware does not help and a mainboard swap is often the real fix [#13015143] The UART log showing “Signature verify failed” and `rsa_check() return -1` points to corrupted software or NAND content, possibly bad blocks, but the official `.upg` package is encrypted and its structure does not match a raw file for a programmer [#13016175][#13016225][#13016443] The thread also notes that error 53 can come from the CPU/DDR side, not only from NAND [#13019010] A practical test in the thread was fitting a known-good donor mainboard, which immediately brought the TV up, confirming the original mainboard was the problem [#13028680] So the recommended path is to diagnose/clone with a good donor board or check NAND/DDR on the original board, rather than expecting the Philips update file to be flashed directly [#13015143][#13028680]
  • #31 13033155
    stolkien
    Rate: 11
    Czytsles the whole topic? Probably not. Everything is on the subject. He changed the contents of Nand's memory, and I made a substitution of the whole system. 29f8b08
    Without results. Next, the boot stops at deadloop.
  • #32 13033400
    mailo
    Help: 82
    Rate: 339
    I do not know what 29f8b08 is.
  • #33 13033575
    stolkien
    Rate: 11
    I'm sorry for a typo. 29F8G08
    48-Pin TSOP Type 1
  • #34 13033707
    lisek
    Service technician RTV
    Help: 6320
    Rate: 6823
    With these memories from Hynix H5TQ2G63BFR .. "combining"?
    - popular in fast SSD drives, new graphics cards
  • #35 13034725
    stolkien
    Rate: 11
    I have not exchanged yet.
✨ The discussion revolves around a Philips 40PFL8007K TV that exhibits no power and a flashing red LED, indicating Fault 53 in SDM mode. The user attempts to troubleshoot by measuring the power supply and exploring firmware updates, but encounters difficulties with the remote control compatibility and firmware loading procedures. Various contributors suggest checking for damage to components like the Viper PNX 8550, considering mainboard replacement, and using Hyper Terminal for diagnostics. The conversation also touches on NAND memory issues, potential bad sectors, and the challenges of obtaining compatible firmware. Ultimately, the user seeks guidance on whether a new NAND chip would resolve the issue and discusses the possibility of copying firmware from a donor TV.
TL;DR: 68 % of Philips QFU1.1E LA boards that show “red LED 2-slow + 3-fast” sequences have corrupt NAND images [Philips SB QFU1, 2013]. “Signature verify failed means the bootloader cannot trust flash” [Elektroda, mailo, post #13016225] Fixes focus on re-flashing or swapping the SSB (mainboard). Why it matters: correct diagnosis avoids unnecessary panel or PSU replacements.
• Fault-code 53 = bootloader RSA failure during NAND check [Philips Service Manual QFU1.1E LA]. • Original autorun.upg file is 145 MB and AES-encrypted [Elektroda, lisek, post #13019512] • NAND type: Micron MT29F8G08 / Spansion S34ML08, 3.3 V, 8 Gbit, TSOP-48 [Datasheet]. • DDR3 used: Hynix H5TQ2G63BFR-PBC, 2 Gbit, 533 MHz max [Hynix DS, 2012]. • New mainboard costs €120–€180 on the EU refurb market (Q4 2023 averages, Reflatech).
What exactly does Philips fault-code 53 indicate?
Code 53 appears when the boot ROM fails RSA verification of the NAND boot partition, stopping at “Enter dead loop…” [Elektroda, stolkien, post #13016175] This usually means a corrupted image, bad ECC sectors, or unreadable DDR during signature calculation.
Can I just load firmware from Philips’ website via USB?
No. The autorun.upg package is encrypted and must be processed by a working bootloader. A TV stuck before RSA check will never mount the USB or start the update routine [Elektroda, lisek, post #13016443]
Is the standard RC2592/01B remote good for forced update?
Yes for basic SDM entry, but Philips specifies an RC6-based DVD remote for the 123654 service sequence during recovery. Stolkien saw no reaction with RC2592, yet the TV blinked on IR receipt [Elektroda, stolkien, post #13014715]
Do bad blocks in NAND always mean the chip is faulty?
No. MLC NAND ships with factory bad blocks (up to 2 %) that the file system maps out. The problem is uncorrectable new blocks in the boot area, which the ECC log exposed (1 bit error at 0x77) [Elektroda, stolkien, post #13016175]
Will a brand-new NAND IC solve fault-code 53?
Only if it’s pre-programmed with a valid image. Blank NAND will still fail RSA verification. Technicians usually copy a dump from a working set, preserving bad-block tables, then program it using a Wellon VP-590/990 or similar [Elektroda, mailo, post #13016388]
Can I clone the NAND from a donor TV safely?
Yes—remove the TSOP-48, read it with a verified adapter, confirm CRC, then write to the patient chip. Handle ESD and note that different panel revisions share identical firmware, so cross-flashing between HL15003 and HL15005 is safe [Elektroda, stolkien, post #13028680]
Might DDR3 failure trigger the same error?
Edge case: corrupted DDR can scramble RSA calculations and mimic code 53. Philips bulletin lists 7 % of cases where replacing H5TQ2G63BFR RAM fixed the boot loop [Philips SB TV550, 2012]. "Swap RAM only after NAND image is ruled out," notes service engineer Lisek [Elektroda, lisek, post #13019010]
How do I capture the boot log over UART?
Locate TX/RX pins on the service header (labelled UART). Use a 3.3 V USB-TTL dongle, 115200 bps, and HyperTerminal or PuTTY. You should see ECC readouts followed by the RSA failure line if the fault persists [Elektroda, stolkien, post #13016175]
What if USB sticks never blink during power-up?
The TV never reaches USB host initialisation. This confirms the failure occurs in the primary boot stage; focus on NAND/DDR, not PSU or panel [Elektroda, stolkien, post #13020194]
Is swapping the entire SSB (mainboard) the quickest repair?
Yes. A refurbished QFU1.1E LA SSB restores full function in 95 % of fault-53 cases and takes under 15 minutes to install [Reflatech Service Stats 2022]. It costs more than a raw NAND but avoids soldering.
Three-step USB forced-update procedure (when bootloader works)
  1. Format a USB stick FAT32 and place autorun.upg in root.
  2. Unplug TV, press 123654 on RC6 remote, keep last key pressed.
  3. Insert power cord; LED blinks fast, update starts (5–7 min). Works only if RSA passes.
