Philips LCD 32PFL7332/10 shows error code 53 after relay click—what does it mean?
JURWIN 5701 8
  • #1 4466844
    JURWIN
    Rate: 15
    Hello. I got a LCD TV like in the title. After switching on, I hear the relay knock and after a while the LED emits error code: 53. I do not have a service manual with error codes and I do not know where to look for a fault. I would be grateful for the help (scheme I have).
  • #2 4469077
    adolf 111
    Help: 14
    VIPER PNX 8550 item 7V00 this layout is responsible for 53 error
  • #3 4470191
    rom_tel
    Question from another keg if this model can receive DVB-T transmissions?
    The diagrams attached to it show that it has an MPEG-2 decoder.
    Maybe someone has sparadził?
    Pozdr.
  • #4 4470253
    helena
    Help: 6
    Rate: 14
    The problem of the code 53 may arise during the uploading of the NAND Flash software, but also the change of the option code for the matrix results in the same effect. At first, it is better to check the flesh.
  • #5 4470441
    JURWIN
    Rate: 15
    I'd like to look closer at this. I have another question: where to get the flash soft?
  • #6 4470712
    helena
    Help: 6
    Rate: 14
    I can send it tomorrow. But generally should be on the official website of Philips. But if you need to write, is it BJ 3 or FJ 3 because it's different softs.
  • #7 4470752
    JURWIN
    Rate: 15
    Ok.Check and write.Pozdrawiam
  • #8 4627584
    Robson316
    I have exactly the same situation in PF9830. Error code 53. The TV tries to start, you hear a few clicks of the relay and after 1-2 minutes the red LED displays the code 53. How do you program (check) the flash?
  • #9 4628728
    JURWIN
    Rate: 15
    in my case the viper was damaged. it was necessary to replace the whole module. I am answering and closing the subject.
✨ The discussion revolves around the Philips LCD TV model 32PFL7332/10, which is displaying error code 53 after powering on. Users suggest that this error may be linked to issues with the VIPER PNX 8550 component or problems during the uploading of NAND Flash software. It is recommended to check the flash memory and the option code for the matrix. One user mentions that their similar model, PF9830, also experienced the same error, indicating potential commonality in the issue. The need for the correct flash software is highlighted, with suggestions to obtain it from Philips' official website. A user reported that in their case, the VIPER component was damaged, necessitating a complete module replacement.
