STK407-070 Chip: Seeking Datasheet and Verification of Authenticity
22590 11
Where can I find a datasheet for the STK407-070, and is the chip in the photo genuine or fake?
A datasheet for STK407-070B was linked, but the thread also says there is no exact STK407-070 datasheet available online, so the recommended approach is to use the schematic/application diagrams from equipment that used this STK family instead [#13043058] [#13044035] [#13048231] One reply explicitly said the chip in the photo is the original [#13043996] A later post shared a Pioneer service-manual page and STK407-70 application information, but another user warned that STK407-070 and STK407-090 are not interchangeable because the pinout differs [#18625944] [#18626492]
  • #1 13041665
  • #3 13043996
  • #4 13044009
  • #5 13044035
  • #6 13044253
  • #7 13044270
  • #10 18625935
    trojan19730510
    here is part of the pioneer xc21 block with the stk chip ....
    • Manual.pdf (1.64 MB) You must be logged in to download this attachment.
  • #12 18626492
    zadam64
    Help: 552
    Rate: 738
    radiogaga wrote:
    http://www.elenota.pl/datasheet-pdf/157770/Sanyo/STK407-070B you can replace with a stronger STK 407-090 e.g.
    From what I found, 070 is not interchangeable with 090
    Examine the schematic of pioneer and the second stk407-090 application
    Added after 4 [minutes]:
    I add full service and STK407-70 applications
    from what I found out 090 seems to be stronger but different pinology of the system. I do not propose to replace it.
    • STK407-090-ETC.pdf (45.96 KB) You must be logged in to download this attachment.
    • STK407-070.pdf (54.27 KB) You must be logged in to download this attachment.
    • PIONEER M-IS22.pdf (1.78 MB) You must be logged in to download this attachment.
The discussion revolves around the STK407-070 chip, with users seeking a datasheet and verification of its authenticity. A link to a datasheet for the STK407-070B is provided, along with suggestions to consider the STK407-090 as a stronger alternative. Users express difficulty in finding a datasheet online and share insights about the chip's application in amplifiers, referencing its use in devices like the Sony RX90 tower. There are concerns regarding the interchangeability of the STK407-070 with the STK407-090 due to differences in pin configuration. Additional resources and schematics are shared to assist in understanding the chip's specifications and applications.
