Understanding Yuasa KA3F27 Battery Production Date and Voltage Standards
aksal4 43899 9
How do I decode the production date on a Yuasa KA3F27 battery?
The production date is apparently burned into the battery case: the first two digits are the year and the next two digits are the week of manufacture [#13098177] The battery also has a barcode, and replies pointed to barcode-decoding references that may help identify the date [#13097948][#13097981] One user reported the barcode number as `5/050694/029370`, but the thread does not confirm how that translates to a date [#13098063] The code `KA3F27` was discussed, but no one in the thread definitively explained whether the ending `27` means 2007 or anything else [#13098242]
  • How to decode Yuasa date code and verify voltage
    #1 13097939
    aksal4
    Rate: 18
    Yuasa KA3F27 batteries
    Hello everyone
    this topic has been dealt with before but I still don't know how to read the date
    I bought a new YUASA 85ah 800a 12v battery, I checked the volts and it has 12v. It seems to me that it should have at least 12.5 or 13v - I have 2-year-old batteries in other vehicles and they have 13v. I asked the seller where I can read the year of production, he replied that he had no idea. Please help
  • #2 13097948
  • #3 13097957
    aksal4
    Rate: 18
    Rather sure
    Added after 5 [minutes]:
    Barcode as for this one, it has
  • #4 13097981
  • #5 13098063
    aksal4
    Rate: 18
    barcode number 5/050694/029370
  • Old stock batteries explain shortened service life
    #6 13098177
    Samuraj
    Help: 286
    Rate: 619
    It seems to me that the year of production should be burned on the casing. The first two digits are the year and the next two are the week of manufacture.
    Recently, I encountered a situation that the replaced batteries do not last as long as the originals. The original battery could last 3 - 4 years in the device and after replacing the device returns to me after half a year. I compared the batteries and the original date would actually coincide with the date of manufacture of the device, while the "new" batteries usually have the first two digits 11 or 12. I asked the seller where the year of manufacture is and how you answered me that the seller does not know anything about it. That's why I said "I think" at the beginning of the post.
  • #7 13098242
    aksal4
    Rate: 18
    These letters and numbers are burned on the battery KA3F27 final numbers 27 does it mean 2007 or is it possible?
    I bought the battery 2 days ago
  • #8 17489846
    Jack78
    Help: 5
    Rate: 35
    I know it's a bit late, but maybe someone will benefit:
  • #10 20704522
    Piotrek z Łowicza
    Rate: 16
    I'm getting on the topic.
    Yuasa 7000 series EFB YBX7027. How to decode it? 44321
    I'm guessing this year 2023.
    Thanks in advance for your help :)
The discussion revolves around understanding the production date and voltage standards of Yuasa KA3F27 batteries. A user inquired about how to read the production date on their newly purchased Yuasa 85ah 800a 12v battery, which showed a voltage of 12v, lower than expected. Responses included suggestions to check for a barcode and indications that the production date might be encoded on the battery casing, with the first two digits representing the year and the following two the week of manufacture. There was also speculation about the meaning of the final numbers on the battery, with a query about whether "27" indicated a production year of 2007. Additional discussions included a reference to the Yuasa 7000 series EFB YBX7027 battery and decoding its production year.
