Yuasa Car Batteries Performance: Comparing Longevity to Bosch S5 in Mediterranean Climate
psilos1 72513 16
Are Yuasa car batteries durable enough to be a good replacement for a Bosch S5, especially in a hot Mediterranean climate?
Yuasa car batteries are generally reported as very durable in this thread and often seem to last longer than the Bosch batteries mentioned here, but there is at least one early-failure report, so buying fresh stock matters [#16034230] [#16151577] [#19071313] Several users describe Yuasa as “top shelf” or “one of the better brands,” with examples of 6 years of trouble-free use and even a 10-year run in a car [#16034230] [#16151577] [#21801684] [#21881389] One user also reports a Yuasa Silver High Performance battery still working after a few months, while another says a Yuasa for Subaru failed completely after only 3.5 months despite the car being garaged [#19071313] [#19071828] The only clear caution raised is to avoid old warehouse stock and possible counterfeits [#21801684] [#16151614] By contrast, Bosch is repeatedly described as failing after about 3–4 years in these replies [#16034163] [#19071313]
  • #1 13768063
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    It's time to replace the battery - BOSCH s5 has gone to the land of free electrons after just four years of use in the Mediterranean climate ... I became interested in Yuasa batteries - I have one in a motorcycle since the new (2005) used occasionally and WORKS without any problems. cars of this brand are just as durable? Unfortunately, I did not find too many opinions on the Internet ...
  • #2 13769040
    SQLmaster
    Help: 31
    Rate: 172
    psilos1 wrote:
    It's time to replace the battery - BOSCH s5 has gone to the land of free electrons after just four years of use in Mediterranean climates
    Unfortunately, I also found out that there is no worse crap than Bosch batteries.
    Even some no-name can be better. Yuasa is a well-known producer of gel batteries, e.g. for alarms, and they perform very well there. I did not know that they do for cars - but it is definitely not a bush company.
  • #3 15300721
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    I have purchased a Banner battery from the Starting Bull series ... service - under the sticker are plugs for electrolyte control.
  • #4 16034050
    jr1
    Rate: 9
    And what ?
    I have good experiences with this company, I haven't had a chance for years.
  • #5 16034133
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    jr1 wrote:
    And what ?
    So far it works without any problems
  • #6 16034163
    helmud7543
    Help: 1216
    Rate: 1564
    Bosch died in Yaris after 3 years, so far he is riding the Warta and it is ok, Delta was probably sitting at the original (he survived 8 years).
  • #7 16034230
    wielecki
    Help: 34
    Rate: 323
    Yuasa is the top shelf. Quality of batteries factory-installed in cars.
    10 years, no problem. My personal experience with this brand from several years ago. I hope no dad or bosza has bought them recently and they still keep their level.
  • #8 16035380
    jarekstryszawa
    Help: 49
    Rate: 482
    I do not know how I had factory in suzuki samurai. Born in 2003, it still runs in the MT8.132.2 tractor with a two-cylinder Lombardini (parked under the shelter). There is no view of the manufacturer's markings, only the Suzuki lettering. Tough brute.
  • #9 16151577
    inforobert
    Rate: 9
    psilos1 wrote:
    I became interested in Yuasa batteries-
    I've had two, very good ones. One of the better brands.
  • #10 16151614
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    No, only chinols passionately counterfeit them. Fujjj. I am a fan of AC Delco.
  • Yuasa YBX5005 failed completely after 3.5 months
    #11 19071313
    A-E
    psilos1 wrote:
    It's time to replace the battery - BOSCH s5 has gone to the land of free electrons after just four years of use in the Mediterranean climate ... I became interested in Yuasa batteries - I have one in a motorcycle since new (2005) used occasionally and WORKS without any problems. cars of this brand are just as durable? Unfortunately, I did not find too many opinions on the Internet ...
    Added after 4 [minutes]:
    [syntax = text] [/ syntax]
    I bought a YBX5005 YUASA for Subaru. He was walking like a storm ... 3.5 months and suddenly he collapsed completely. Car in the garage.
  • #12 19071828
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    The banner is over after four and a half years ... now I have a Yuasa Silver High Performance 52Ah YBX5012 for a few months ... it was not cheap, we'll see how much it comes from
  • #13 21564478
    vic_tm
    >>13768063 I have had a Yuasa SY50-N18L-A in a Virago 1100 for twenty some years. Replacement every 4 years. I won't buy another company. For the car, also recently Yuasa.
  • #14 21801651
    Shopen1
    >>16034163 Bosch and Varta are the same battery, both are made by Johnson Controls.
  • #15 21801684
    MarcinM2020
    Help: 71
    Rate: 247
    I have a Yuase (the silver one) in a Honda Jazz. It was bought over 6 years ago, the car has been under a cloud and is still running as expected. I still have a yuase battery in my other car (honda hrv), so I think the batteries are worth recommending.
    From what I've heard, you just have to make sure the battery isn't a warehouse stock.
  • #16 21881389
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    Yuasa is now 6 years old and still fully operational....
  • #17 21909286
    kakibara
    Help: 202
    Rate: 1284
    I had one in a diesel with no start stop lasted a very long time, I changed it to an optime with a yellow cap. This one was also a buck, the car stood for months and fired up.
    Price = quality. In these two cases.
The discussion compares car battery longevity in a Mediterranean climate, starting from a Bosch S5 battery that failed after about four years. Participants report mixed experiences with Yuasa batteries: several describe them as durable, high-quality batteries with long service life in cars and motorcycles, while others note premature failure in a Subaru after only a few months. Alternatives such as Banner, Warta, Delta, and Optima are mentioned, along with the observation that Bosch and Varta may share the same manufacturing base. A recurring point is that battery condition depends on storage age and usage, and that some Yuasa batteries, especially silver versions, have performed reliably for 6–10 years or more.
