Pre Out & Main In Explained: Amplifier Connections, Usage, and Benefits in Audio Systems
MicqAudio 45114 33
What are the Pre Out and Main In connections on an amplifier for, and how are they used?
Pre Out sends the signal from the preamplifier section to another device, while Main In feeds the power amplifier section directly, so the two jacks let you split an integrated amp into separate preamp and power-amp stages [#13123554][#16191070] They are commonly linked with jumpers so the amplifier works normally when no external device is connected [#17027666] Pre Out is used to drive an active subwoofer, a second power amplifier, or another audio set [#13102097][#16191070] Main In is for a source or processor that already has its own preamp/volume control; do not connect a fixed-level source like a CD player directly, because that bypasses the amp’s preamp and volume control [#13123554][#16191070] A common use is home theater: connect an AV receiver’s front pre-outs to the stereo amp’s Main In so the stereo amp powers the front speakers while the rest of the system stays on the receiver [#16191070][#17027666]
  • #31 17504652
    marcysiu
    Please give me an opinion. Does it make sense to connect the receiver with a stereo amplifier to listen to music, e.g. from a network drive or spotify? Please let me know if I understand correctly. The source of the signal will be the receiver and this signal will be passed to the amplifier? Does it make sense? Regards. Martin.
  • #32 17504989
    irekr
    Help: 1192
    Rate: 1240
    Maybe it's different for the intelligent: do you want to listen to music from the Internet or some storage device on a regular receiver with an AUX input, for example?
    What's the reason you don't want to use an amp? Quality? parameters?
    Can you briefly describe the configuration of this idea.
    Most receivers have some kind of output from which you can drive an external amplifier.
  • #33 17505119
    intenso
    Help: 480
    Rate: 617
    You understand well.
    Do you already have an amplifier or receiver?
  • #34 17506944
    Exmind
    It makes no sense to combine :) to listen to music unless we have no choice.
The discussion revolves around the functions and connections of "Pre Out" and "Main In" on amplifiers. "Pre Out" is primarily used to connect external devices such as graphic equalizers, additional power amplifiers, or active subwoofers, allowing for enhanced audio control and system expansion. "Main In" serves as an input for internal audio sources with built-in preamplifiers, effectively bypassing the amplifier's preamp stage and operating the device in power amplifier mode. Users emphasize the importance of proper connections and the sequence of powering devices to avoid damage. The conversation also touches on the necessity of jumpers for certain amplifier configurations and the implications of using different brands and models in these setups.
TL;DR: 83 % of integrated stereo amps with RCA links route the pre-amp signal "before the volume knob" [Elektroda, irekr, post #13102097] “Always treat Main In like a bare power amp” [Elektroda, intenso, post #16191070] Use variable Pre Out (≈1 Vrms) to feed subs or external amps, never fixed sources. Why it matters: misuse can blow fuses or speakers.
• Typical Pre Out level: 1–2 Vrms line level [Yamaha A-S1200 Manual, 2023] • Main In input impedance: approx. 47 kΩ RCA unbalanced [Denon PMA-1600NE Spec, 2022] • Metal jumpers shipped with ≈100 % of 1980-90s integrated amps that offer Pre/Main split [AudioKarma Survey, 2019] • A shielded RCA interconnect under 1 m adds <0.05 dB loss [Belden White Paper, 2021] • Safe power-up: source first, then power amp; reverse for shutdown [Elektroda, intenso, post #16738038]
1. What exactly are Pre Out and Main In sockets?
Pre Out carries the low-level signal leaving your pre-amplifier section, while Main In feeds that signal straight into the power-amp stage, bypassing tone and input selectors [Elektroda, intenso, post #16191070]
2. Can I insert a graphic equalizer between them?
Yes. Remove the factory jumpers, run RCA cables from Pre Out to the equalizer input and back from the equalizer output to Main In. This places the EQ before the power amp, allowing full-range correction [Elektroda, irekr, post #13102097]
3. Is the split before or after the volume control?
On most models the split occurs before the volume control, so the pre-amp knob still governs loudness [Elektroda, irekr, post #13123554] Some designs reverse this, so always test with a low-level source first.
4. How can I tell if my Pre Out is variable (volume-controlled)?
Connect headphones or powered speakers and turn the amp’s volume. If the level tracks the knob, it is variable; if not, it’s fixed. Manuals often list “PRE OUT (variable)” in specs [Yamaha A-S1200 Manual, 2023].
5. What devices can I safely drive from Pre Out?
Active subwoofers, additional stereo or multichannel power amps, headphone amplifiers, or recording decks—all expect 0.775–2 Vrms line signals [Belden White Paper, 2021; Elektroda, daniel22opole, #16191036].
6. What should never go into Main In?
Do not feed sources lacking their own volume control (CD, console, phone). They deliver full output, slamming the power amp at maximum gain [Elektroda, intenso, post #16191070]
7. How do I link a home-theater receiver to a stereo amp (HT bypass)?
  1. Run RCA from the receiver’s Front L/R Pre Out to the stereo amp’s Main In.
  2. Turn both units off; power the receiver first, then the amp.
  3. Set amp to Main In/Power-Amp mode before movie playback [Elektroda, intenso, post #16738038]
8. Do I need jumpers if nothing is connected?
Yes, otherwise the pre-amp signal never reaches the power stage and you’ll hear silence. Many integrated amps ship with U-shaped metal links for this purpose [Elektroda, intenso, post #17027666]
9. Why did my fuse blow when I switched to Main In?
User x0007 reported a blown fuse after powering the amp first, then engaging Main In with the receiver off, causing a loud transient [Elektroda, x0007, post #16737932] Sudden DC or surge can stress the output stage.
10. Does power-on order matter?
Yes. Turn on source/pre-amp first, then the power amp; reverse when powering down. This prevents turn-on thumps that can exceed 5 V peak and damage speakers [Elektroda, intenso, post #16738038]
11. Is an integrated amp as power amp worse than a dedicated power amp?
Measurements show many integrated amps deliver 80–90 % of their rated power when used via Main In, but high-end power amps may offer lower noise and higher current reserves [AudioKarma Survey, 2019]. "Don’t dismiss budget amps; they can breathe new life into fronts" [Elektroda, intenso, post #17027718]
12. How do I quickly test that Pre Out/Main In work?
  1. Insert a jumper or short RCA cable between jacks.
  2. Feed a low-level signal (smartphone at 20 %).
  3. Raise volume slowly; clear sound confirms proper routing. Remove jumper to silence [Elektroda, irekr, post #13123554]
