Premiumbox + nc + decoder - Connecting the audio decoder to the receiver / ampli
Ryhoooo 5391 4
  • #1 16756891
    Ryhoooo
    I want to connect the s / pdif output with the aux input on my denon amplifier (2x cinch). The only cables I see are type y but the annotation that is used to connect a subwoofer e.g. Prolink 2rca - 1 rca (tcv3610).
    In the old tractor (turbobox) I had the options left right cinch and on any cable 2 - 2 admittedly only stereo but I had a beautiful sounding home theater.
    What should I do with this new? Please, help me.
    sosarek
    Help: 9320
    Rate: 15532
    Provide device MODELS.
    Since the decoder has a digital output, you will not connect it to the analogue amplifier inputs - either you will use a signal converter or use the SCART socket.
    Z
    Pka, Poznań, 60-850
  • #3 16757046
    Ryhoooo
    Great, thank you nc +!
    The decoder is ADB NCP-4740SF has this spdif single chinch output and the PMA-720AE receiver
  • #5 16757726
    Ryhoooo
    Wounds how simple it was. Thanks!
