Adobe Reader XI - Program Shuts Down After Opening Document: Solutions for Stability Issues
nogiln 25530 6
  • #1 13114575
    nogiln
    Rate: 21
    I have Adobe Reader XI installed, after opening the document the program turns off after a while, what should I do?
  • #2 13114837
    Richter
    Help: 84
    Rate: 165
    Run the program itself without the .pdf file after opening the Help menu> check for updates
  • #3 13115445
    nogiln
    Rate: 21
    The program has updated and continues to crash.
  • #5 13115635
    iagre
    Help: 213
    Rate: 281
    The program without a pdf file also turns off? If not, does the automatic shutdown occur with all pdf files or only with some?
  • #6 13350385
    JohnySpZOO
    Electric installations specialist
    Help: 186
    Rate: 330
    I recommend running it in compatibility mode, eg XP and after the problem.
  • #7 14518879
    centrumnapraw
    Rate: 37
    I have the same problem. You don't need to run it in compatibility mode. Run as administrator is enough.
Adobe Reader XI is experiencing stability issues, causing the program to shut down after opening documents. Users have suggested several solutions, including checking for updates, running the program without a PDF file, and using compatibility mode or running as an administrator. Some users have reported that the program continues to crash even after updates. Alternatives like Foxit Reader are recommended for those seeking more reliable PDF viewing options.
