Excel: Converting Hours to Numbers - File Attached, Seeking Guidance
tasiek87pl 28422 3
  • #1 13230538
    tasiek87pl
    I'm having trouble converting hours to numbers. I am attaching a file. thank you in advance for your help.
    • czasowy_problem.xls (29 KB) You must be logged in to download this attachment.
    kernel-panic
    Help: 17
    Rate: 20
    And if you enter = F3 * 24 and give the number format of the cell, it doesn't work?
  • #3 13231008
    markoz7874
    Help: 132
    Rate: 208
    I understand you want to convert sexagesimal system to decimal system.
    Divide the minutes by 60:
    =MINUTA(F3)/60
  • #4 13232795
    tasiek87pl
    it worked, thanks for your help.
    =MINUTA(F3)/60
    Unfortunately, this formula did not help me because the result was 0.75 but thank you for your statement. The kernel-panic solution worked. greetings.
