Smart home system visualisation applications like SCADA
mojzo 6891 6
  • #1 13279403
    mojzo
    Hello, I want to make a visualisation of a building automation system for an imaginary building created by myself. The problem is that I haven't found the right applications to do something like this. Namely, I want to create something similar to SCADA or a visualisation showing/signalling the operation of system elements, e.g. switching on lights, closing blinds, showing sample temperatures, etc.
    Thank you in advance for any suggestions and assistance.
    Pawcio89
    Help: 32
    Rate: 24
    For this you can use, for example, LabVIEW
  • #3 13280440
    falowniki.com
    Power inverters specialist
    Help: 86
    Rate: 134
    Familiarise yourself with CoDeSys in the standard software you have the ability to program visualisation and program structure. Extensive libraries for building automation systems.
  • #4 13335132
    mojzo
    Thanks Pawcio89, Labview enables me to get exactly what I wanted. As for CODESYS, I have downloaded the program, but I can't seem to get into the mode of creating visualisations or program structure. From what I have seen CODESYS gives really great possibilities, so please give me more information related to this program.
  • #5 13466656
    gervee
    Automation specialist
    Help: 100
    Rate: 94
    You surprised me by not finding anything for yourself.
    E.g. in the iFIX software the Krakow-based ZDANiA has created a system -> here you have a description http://www.vix.com.pl/proficy-w-inteligentnych-budynkach,c/
    As far as I know also in the InTouch software such things are done e.g. http://wonderware.com.pl/branze/zarzadzanie-budynkami-bms.html
  • #6 14004920
    arkady_pl
    Help: 59
    Rate: 24
    mojzo wrote:
    The problem is that I have not found the right applications to do something like this.
    Before I can help you, I'm going to need some information from you about what the application needs to be in order to be - as you put it - suitable. Without this, there is no way to help you. You can flood in with suggestions, but you can't help choosing.
  • #7 15499841
    mojzo
    The topic is closed
