A simple program for placing the watermark logo on the pictures
mita 12279 7
  • #1 16196763
    mita
    Rate: 61
    I need a simple free graphic program to put a watermark logo saved in .jpg format. The logo's dimensions are 2600x300 pixels. The problem is that with different sizes of the logo, I accept different sizes. And it should always occupy 1/4 of the image width and start with x pixels from the right and bottom.
  • #2 16197105
    Pan.Jan
    Help: 14
    Rate: 21
    E.g. Gimp. Adjust the size of this logo manually, you will have everything the way you want :)
  • #3 16197121
    mita
    Rate: 61
    Well, that's not what it was, and you know for sure ;)
  • #5 16357002
    mita
    Rate: 61
    It still is not one or the other that works the way I want. The nearest I found Watermark Image. With the fact that you can not determine the percentage of the distance of the logo from the edge only pixels, and this with different sizes of photos looks uninteresting but there is something.
  • #6 16532779
    Ohio851
    It would be also worth noting grafido.pl - simple, functional and accessible from the level of the browser, wherever you login.
  • #7 16544561
    piotrczel
    And how much does this pleasure cost? Because it is important at the beginning of the activity as if you do not look at it, because everything eats away with a little money and creates a round sum that can not be swallowed.
  • #8 16544650
    Ohio851
    I used it as it was still in the testing phase for free, but now the place is 10 PLN a month, because there are discounts when someone has other services of the same company. I do not know what the regular subscription price is.
A user seeks a simple, free graphic program to apply a watermark logo in .jpg format, specifically requiring the logo to occupy 1/4 of the image width and to be positioned a certain number of pixels from the right and bottom edges. Suggestions include using GIMP for manual adjustments, and online tools like grafido.pl and Watermark Image, although the latter does not allow for percentage-based positioning. The user expresses dissatisfaction with existing options, noting that some tools only allow pixel-based positioning, which is not ideal for varying photo sizes. Pricing for some services is also discussed, with one mentioning a subscription cost of 10 PLN per month.
