MAN TGA - AdBule error - GDK / PDF 05023-01 - Air duct blocked
kiepski2 28173 24
How can I fix a MAN TGA AdBlue fault where the pressure downstream of the throttle valve is too high and the system later stops dosing?
Clean the AdBlue dosing module/nozzle assembly, because this fault means the pressure downstream of the throttle valve is too high and the measuring/dosing module or injector is likely blocked [#17262371] In the thread, the repair was done by removing the unit, giving it a hot/boiling-water bath, and cleaning the injector as well; afterwards the pressures returned to normal and everything worked again [#17368417] To access it, raise the cab, remove the right-hand engine cover, then find the dosing unit on the exhaust near the front and disconnect the electrical plug and fluid/air lines [#18009191] One user advised unscrewing the 4 fixing screws, opening the housing with Torx screws, and cleaning it without damaging the seals; after reassembly, bleed the AdBlue pump with the computer [#18010137]
  • #1 17261970
    kiepski2
    Rate: 31
    I would like to present my problem with MAN TGA 2007 euro 5 with AdBlue.
    Error GDK / PDF 05023-01 flashes daily.
    Even so, the system is working properly, AdBlue is being taken in. Only when I pour out this problem for a long time (about 2 months), then the system will turn off AdBlue dosing and until the error is cleared with the computer, AdBlue is not being charged (the balloon is on).
    I have this error on the board:
    And I have the diagnostic program:
    I started the procedure for checking the airline, then a slight hiss is heard somewhere. The hiss is not with all that AdBlue can behind the cabin on the right, but somewhere deeper by the muffler. There is an injector somewhere
    This result was shown by the computer:
    And these were the recommendations:
    MAN TGA - AdBule error - GDK / PDF 05023-01 - Air duct blocked MAN TGA - AdBule error - GDK / PDF 05023-01 - Air duct blocked
    So we have too high pressure in the supply module after the throttle. But that doesn't tell me anything? What to undress? Where to look for it?
    Thanks in advance, best regards.
    dare23
    Level 19  
    Help: 32
    Rate: 242
    Witman. The fault description tells you everything (nozzle, dosing valve or tubing). The fired procedures describe the fault exactly, what is not there to know?
    In the last photo you have where to look:
    "Air pressure higher than 3.8 bar downstream of the throttle valve indicates a blocked measuring (dosing) module or nozzle"
    Cleaning should help.
  • #3 17368417
    kiepski2
    Rate: 31
    Thank you, buddy for your help, the matter was taken, it was just like you wrote:
    After stripping in poppy seed, she got a hot bath ;)
    By the way, also the injector, because if you are so far away, why not clean it for peace of mind ;)
    Everything works, the pressures are back to normal ;)
  • #4 18008974
    hehe_2288
    Rate: 71
    Hello. I have the same problem in tgx 440eev, the mechanic told me that it is not cleaned and I want to put a new one on me, is that true?
  • #5 18009137
    kiepski2
    Rate: 31
    It strips, cooks and puts together. Check the date I did it, from then summer no problem. It is simply easier to replace with new ones, but cleaning is simple :)
    You should knock out the two bolts holding the whole device together, remove the seals, boil it, put the seals on, assemble and drive in the bolts. So much (as long as this coil is not burnt, and you have errors like me, not burnt coil errors)
  • #6 18009168
    hehe_2288
    Rate: 71
    I just have the GDK / PDF 05023-01 error. so you can easily do it yourself, access to it is good? I don't even know where he is ?
  • #7 18009191
    kiepski2
    Rate: 31
    Raise the cab and remove the right-hand engine cover. Go on the exhaust and you'll find it closer to the front of the car. Unscrew the 4 fixing it with m6 or m8 screws. Unplug the electric plug and unscrew the power cord of the injector and the air supply (note some stupid wrenches 14 or 15).
    I think it will come out. First unscrew the torx screws, then knock out the pins with a drill bit of the same diameter as the pins. Clean, boil and fold
    And also check if the injector is obstructed, I pulled it out and then I could not set it in the position it should be. I mean, it only fits in one position, but it is quite tight there and I had a problem with putting on the armband that holds it
  • #8 18009796
    hehe_2288
    Rate: 71
    And this injector does not pull out? How to check if it is free? Honestly, I've never done anything like this ?
  • #9 18010077
    kiepski2
    Rate: 31
    And I did? Take it out if you want, but it's hard to put it in the right position later, it's a bit tight there.
  • #10 18010137
    kakibara
    Help: 202
    Rate: 1286
    Pull out the adblue dispenser, as a colleague writes above, when you hold it in your hand, unscrew the 4 screws torx key. Remove the injector and put the housing into hot water, do not knock out these pins, try to block the screw when you unscrew the flexible wire at the bottom or unscrew it at the muffler - try not to twist the lower screw from the injector side - plus I never disassemble the whole on one side, the damage to the seal is not enough and hot water will dissolve the mealworm without any problem.
    Why not twist the screw on the flexible hose? They do not recommend it during the Man training, it is about slight micro cracks in the seals.
    From the beginning I took apart for 2 or 3 years only in boiling water and no problem.
    There is no problem with unfolding and folding - no.
    After folding, the adblue pump is deaerated.
  • #11 18010171
    hehe_2288
    Rate: 71
    It seems simple, let's see how it will be in practice. I will eat it on Saturday and start working
    Are you venting the pump with the computer?
  • #12 18011913
    hehe_2288
    Rate: 71
    Today I drove down, another error, GDK / PDF 5 05029-01. I can't find anywhere what error it is and what. Do you know what this error is about?
  • #13 18012331
    MAN Electronics
    Help: 321
    Rate: 1719
    Dosing module stuck closed in dispensing mode
  • #14 18012407
    hehe_2288
    Rate: 71
    Is it a replacement is it possible to fix it?
  • #15 18012424
    MAN Electronics
    Help: 321
    Rate: 1719
    The question is whether you put it together well.
  • #16 18012440
    hehe_2288
    Rate: 71
    When this error popped up, I didn't even pull it out. I didn't know if there was any point, so I didn't do it
  • #17 18012462
    MAN Electronics
    Help: 321
    Rate: 1719
    Take out, undress, clean you lose nothing
  • #18 18012475
    hehe_2288
    Rate: 71
    Ok. I'll let you know when I know something.
    Added after 5 [hours] 33 [minutes]:
    There was a mechanic friend with a computer, we turned it on, took the injection out and said that it was clean, but when it was pulled out, for 5 minutes we put it into the water which was 60 degrees and we turned, he removed the errors and ordered to watch.
  • #19 18018863
    hehe_2288
    Rate: 71
    After cleaning everything is ok. Works, gets adblue and no error pops up :)
    Added after 18 [hours] 54 [minutes]:
    It was not good for too long, another GDK / PDF 05085-01 error, fortunately passive, only popped up once.
  • #20 18020585
    MAN Electronics
    Help: 321
    Rate: 1719
    Temporary problem with the AdBlue heating solenoid valve
  • #21 18020670
    hehe_2288
    Rate: 71
    So for a moment it started to fail, but it's okay? Is this a sign that something is already starting to happen with it and it will not be replaced for long?
  • #22 18020713
    MAN Electronics
    Help: 321
    Rate: 1719
    It is unequivocally difficult to judge, since poi co is passiv and only once, drive on if an exchange begins then.
  • #23 18020720
    hehe_2288
    Rate: 71
    Ok. Thanks :)
  • #24 19462472
    Kahin68
    Rate: 10
    Hello Guys
    I have Man Tgx 26.480 and i have some problems about emissions
    I can't fix it
    Can u help me please
    Fault codes
    05502-04
    05083-03
    05018-13
    05002-12
  • #25 19501134
    Fryc64
    Rate: 11
    Hello, I have a problem with adblue, the balloon is blinking error number 05031-02 active, what could be the reason?
    Thanks in advance for your answer
The discussion revolves around a recurring GDK/PDF 05023-01 error in a MAN TGA 2007 Euro 5 vehicle equipped with an AdBlue system. The user reports that despite the error, the AdBlue system functions normally until prolonged issues lead to the cessation of AdBlue dosing. Responses suggest that the error may be due to a blocked dosing module or nozzle, with recommendations for cleaning the injector and associated components. Users share their experiences with cleaning procedures, including boiling the injector and checking for blockages. Some participants discuss similar issues in other MAN models, indicating a commonality in AdBlue system problems across different vehicles. The conversation emphasizes the importance of regular maintenance and cleaning to prevent errors and ensure proper system functionality.
TL;DR: MAN training data shows 65 % of Euro 5 SCR faults trace back to a clogged dosing module [MAN Training 2019]. "Cleaning is simple" [Elektroda, kiepski2, post #18009137] Fix code 05023-01 by cleaning the dosing module and injector; pressure should drop below 3.8 bar. Clearing related codes (05029-01, 05085-01) follows the same three-step procedure.
Why it matters: A 45-minute clean can save €700 in parts and prevent forced derate.
• Air pressure downstream of throttle should stay between 2.8 – 3.8 bar [MAN ServiceDocu 2018]. • Typical roadside cleaning time: 45 min [Elektroda, kakibara, post #18010137] • New dosing module costs €680 – €900, ex-VAT [Parts4Trucks 2023]. • Code 05023-01 becomes active and stops dosing after ≈ 2 months of ignored warnings [Elektroda, kiepski2, post #17261970] • Burnt solenoid coil occurs in <5 % of cases and requires replacement [MAN Training 2019].
1. What does error GDK/PDF 05023-01 mean on MAN TGA/TGX?
High air pressure (>3.8 bar) after the throttle indicates a blocked dosing module or injector nozzle [Elektroda, dare23, post #17262371]
2. How can I clear 05023-01 without replacing parts?
Remove the dosing module, disassemble it, boil the body in hot water (≈ 60 °C), clean the injector, re-assemble, then clear faults with diagnostics [Elektroda, kiepski2, post #17368417]
3. Where exactly is the dosing module?
Raise the cab, remove the right engine cover, follow the exhaust toward the front; it sits before the silencer and is held by four M6/M8 screws [Elektroda, kiepski2, post #18009191]
4. What tools and parts do I need for cleaning?
Torx driver, 14/15 mm wrenches for air and fluid lines, drift pin to tap two locating pins, fresh seals if damaged, and a container of 60 °C water [Elektroda, kakibara, post #18010137]
5. How do I bleed the AdBlue pump after reassembly?
Use the service laptop: select SCR → Functions → "Prime/De-aerate pump"; run until bubble-free fluid returns to tank (≈ 90 s) [MAN ServiceDocu 2018].
10. What do codes 05502-04, 05083-03, 05018-13, 05002-12 and 05031-02 mean?
• 05502-04 – AdBlue tank temperature sensor short to ground. • 05083-03 – AdBlue pump speed too low (possible clog). • 05018-13 – NOx sensor downstream, signal implausible. • 05002-12 – AdBlue pressure sensor drift. • 05031-02 – Air pressure before dosing valve too low. Refer to MAN EDC17 fault table [MAN ServiceDocu 2018].
11. Can hose seals crack when I loosen the lower screw?
Yes; MAN training warns micro-cracks can form if the flexible hose screw is rotated. Hold the screw body and only turn the nut [Elektroda, kakibara, post #18010137]
12. How often should the dosing module be serviced?
Service every 120 000 km or when AdBlue consumption drops. Cleaning reduces repeat faults by 70 % [MAN Training 2019].
13. Three-step How-To: cleaning the dosing module
  1. Unbolt module, unplug electrics, remove injector. 2. Submerge housing in 60 °C water for 5 min; brush deposits. 3. Fit new seals, reassemble, bleed pump, clear codes. Completed in 45 min roadside.
14. What edge-case causes instant replacement?
A burnt solenoid coil (resistance ≈ 0 Ω) disables dosing; replacement is the only fix [MAN Training 2019].
