Alpine 3540 Amplifier: Identifying Wire Connectors, Speaker & Power Outlets, and Alternatives
stefcio 7035 5
  • #1 13404866
    stefcio
    Help: 24
    Rate: 27
    Siemka.
    This amplifier was in good working condition and in good condition, but without cabling. I would like to experiment with it, but I do not want to solder cables to loudspeaker sockets and power supply. I have already searched the various types of auction portals and found nothing.
    Do these speaker / power outlets / connectors have any professional name? Something that simplifies the search or does soldering remain?
    Greetings. Alpine 3540 Amplifier: Identifying Wire Connectors, Speaker & Power Outlets, and Alternatives
    Sarever
    Level 19  
    Help: 27
    Rate: 21
    Once I had a problem with getting an Alpine 3531 cube, under the mains plug from the computer power supply, the longest one. I plugged the dice and cut off the remaining, unnecessary part. Check maybe you can choose something. Maybe you will get a four-pin plug from the power supply of the motherboard, as in the annex? greetings
  • #3 13406638
    stefcio
    Help: 24
    Rate: 27
    Sarever wrote:
    I used to have a problem with getting an Alpine 3531 cube, under the mains plug from the computer power supply, the longest one. I plugged the dice and cut off the remaining, unnecessary part. Check maybe you can choose something. Maybe you will get a four-pin plug from the power supply of the motherboard, as in the annex? Regards
    I was already thinking about it, but I was hoping that I would find a more professional or dedicated solution
    But it will be better than soldering cables anyway. Thanks for the help.
  • #4 13407591
    milejow
    Help: 1566
    Rate: 5161
    stefcio wrote:
    I was hoping to find a more professional
    You will not find a more professional one, in the original there was an identical plug like that from the power supply of the processor at the power supply, only cables of a different color. The second is to supply the old peripherals, you need to cut off only one pin :D
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #5 13410226
    jurand87sca
    Help: 207
    Rate: 317
    Hello. In TME Łódź, connectors and connectors for these are called mini-fit Jr. MOLEX producer, 4.2 mm raster. Symbol of MX-5556 connectors, housing MX-5557
    http://www.tme.eu/pl/katalog/zlacza_46/#searc...d=accuracy&s_order=DESC&id_category=33&page=1
    Only 3pin has the marker inversely .. 4pin will rather fit .. So, as colleagues right better, it is probably possible to dismantle this ATX connector from some branded power supply with thick cables around 30-50cm per konetor. As for colors, I once used to make such a connector for some kenwooda and, surprisingly, colors even fit the wires ...
  • #6 14215270
    stefcio
    Help: 24
    Rate: 27
    Maybe someday it will be useful to someone. Description of pins in pdf.
    • Alpine_3540_Power_Ampl_Instal.pdf (71.25 KB) You must be logged in to download this attachment.
