KIA Cee'd - 1.6 and LPG installation - it's worth it if it's a mista
SATAn_ 80205 13
Is it worth installing LPG in a 2007–2008 Kia Cee'd 1.6, or should I avoid this car because of gas-related failures?
Yes, LPG can work in this engine, but only with a very good installation and preferably in a clean car whose history you know. One owner reports a 2007 Ceed SW 1.6 on gas for 50k km with a STAG 300 + lubrication setup, running perfectly and consuming about 15% more fuel [#13538566] Another reply says there are Ceeds with 100k+ km on gas without problems, and some installers recommend valve lubrication, though the effect on these engines is uncertain [#13500392] The main warning from the thread is that badly done LPG installations cause trouble, and there were comments about possible head/valve issues, so using a proven workshop is critical [#13435368][#13538566] A common recommendation is to buy a normal petrol car and install LPG yourself, rather than buying one with an unknown gas setup already fitted [#13538566]
  • #1 13434830
    SATAn_
    Help: 6
    Rate: 42
    I'm going to buy a Kia Cee'd around 2007-2008 with a 1.6 engine. I started looking in google about LPG installation and its failure in this model. Anyone have installed LPg for Kia and can write something more. Is it worth bothering about gas for this model or give up the car?
  • #2 13435368
    wojtek91edek
    Help: 18
    Rate: 163
    Good car, recommendable. The disadvantages in my opinion are: stabilizer links like to fly in it, the tailgate can corrode, the original radio can hang and the notorious crackling of the dashboard, but I would not recommend you to install the gas, generally even Kia Motors Polska advises you not to install gas. Problems after installing the gas are with the head and once I have encountered LPG in sportage with excessive clearance between the pistons and the cylinder, apparently the gas was to blame.
    Regards
  • #3 13435417
    psooya
    Help: 376
    Rate: 575
    STAG has its own LPG-powered KIA and they praise it. When you screw up the job and 99% of gasmen do it, it all flies. Toyota with VVTi also fly and I'm driving and it's ok, so far only 35kkm on LPG, we'll see what will happen after another 35kkm, some after 100km the head fell :D
  • #4 13435665
    gimak
    Help: 614
    Rate: 1678
    I also drive 127 kkm and I think I will drive for a long time, but you need to take care of the valve clearance (check and possibly correct).
  • #5 13435805
    psooya
    Help: 376
    Rate: 575
    Well, good luck with the clearance adjustment of the VVTi low cost which has no plates and only glasses to size. Currently, Toyota has gone into hydraulic self-regulators, or at least in the Yaris because I drive them.
    So I do not even check the clearance because when it comes to grinding the glasses, the cost will exceed the replacement of the motor and I have the second one as a spare. Maybe someday I will check the clearances for another 35kkm ;-p or wait for it to rain.
  • #6 13436148
    SATAn_
    Help: 6
    Rate: 42
    I've read about the flap and stabilizers, but you can get over it. At the beginning, I was thinking about the gas version (there is 1 pc from Germany with BRC gas for 7 years), but I departed from this idea.
    I currently have a waffle 3 with 1.4 AEX, and judging by what people write, the Kia burns almost exactly like mine.
    I think about gas in the near future, but it is not 100% sure, so I ask in advance.
  • #7 13436177
    psooya
    Help: 376
    Rate: 575
    Honestly, if you have to set up gas or buy gas, these are only Polish systems, you will buy BRC, you will complain if it does not work and the chakra will bill you for 1500 and it will still not work, for this cylinder is approved for 10 years, so to be honest, I would prefer myself assume than buy with. There is also the other side of the coin, Polish gasmen are mostly bunglers looking at it to earn money quickly, so you will also have to go if you get it wrong. Only proven workshops recommended on the forum, preferably partner workshops, so that you would not be left on the ice.
    Regards
  • #8 13436220
    SATAn_
    Help: 6
    Rate: 42
    I came to the same conclusion and skipped the car with the gas already installed.
  • #9 13436238
    psooya
    Help: 376
    Rate: 575
    The only advantage of a car with gas is an entry in the registration certificate which allows for spontaneous modifications, so it is cheaper than with a gasman, but then you need to know gas or learn, for this car it is best to have a Polish driver, then possible changes, the injectors can be the reducer if it was in a bungler and of course the gas is not 7 years old and let's say two three, then the cylinder is lux and you can play.
  • #10 13500392
    marco123
    I know a few Kia ceed that have 100k + driven on gas and nothing, some recommend gas with lubrication but I do not know what effect it has on these engines. As for knocking (valve play), it is worth avoiding such symptoms when buying, it may well be a chain or a more serious fault.
  • #11 13538566
    inoja
    Rate: 11
    Kia ceed sw 2007 1.6. Gas 50 k. STAG 300 + lube installation. The basis is a good assembly. Works perfectly with gas burning + 15%. In Krakow, I can recommend the gas generator that installed the installation in all my cars. There was no problem with any of them, and I had several of them. Overall, the toy car is great with a few small inconveniences to get over. It is best to buy a clean car and install the installation. Then you know what's under the hood.
  • #12 13645133
    SATAn_
    Help: 6
    Rate: 42
    I bought a 2010 Ceed in 1.4 gasoline. The car is already after the lifts, so far I can only praise :-)
  • #13 13646083
    romkoski
    Congratulations, a very nice car. You can easily put a stag in it, with the current gas prices it is very cheap to drive.
  • #14 13648267
    SATAn_
    Help: 6
    Rate: 42
    When I decide to use gas, I will mention this to my trusted gas company
    Thanks for the information.
The discussion revolves around the installation of LPG systems in the 2007-2008 Kia Cee'd with a 1.6 engine. Users express mixed opinions on the viability of LPG conversion, with some recommending against it due to potential engine issues, particularly with valve clearance and head problems. Others share positive experiences with LPG installations, particularly with the STAG system, emphasizing the importance of quality installation and maintenance. Concerns about the reliability of Polish gas installers and the need for proper lubrication systems are also highlighted. Overall, while some users report successful LPG use, caution is advised regarding installation quality and potential engine complications.
