Kia Ceed 1.6 petrol + LPG - The car does not start the first time when it is col
asabust 29013 16
Why does a Kia Ceed 1.6 petrol/LPG engine fail to start on the first attempt when cold but start immediately when warm, and how can the fault be diagnosed?
The reported cause was a fuel-vapor purge solenoid valve that remained continuously open, enriching the intake and causing difficult cold starts [#20117613] To test it, tightly block the inlet connection to the purge solenoid and try starting the engine; if the symptom disappears, replace the valve. On this Kia/Hyundai 1.4/1.6 engine, the valve is on the right side of the engine near the fuel-tank vent and fuel-supply lines, with part code 29010-2B000 [#20117613] If this test is inconclusive, read fault codes and cold-engine live parameters and check whether the LPG reducer is leaking gas into the intake [#17607250]
  • #1 17358741
    asabust
    Rate: 18
    Hi, the car has the following. symptoms:
    - Does not light the first time on a cold engine, sometimes it lights up only the third time.
    - When the engine is warmed up, it fires immediately.
    - The first time you start the engine on a cold engine and hold down the key for a long time, you can feel the car catching the ignition. Turning the key again already starts the car. When the car starts and I immediately add gas, you can feel its revs drop and the car almost goes out. If I wait for 30 seconds, there is no problem.
    - The stepper motor was checked and cleaned, unfortunately it did not bring any results.
    - The tank of petrol and gas is full.
    - Candles are made of 8 thousand. km.
    Let me know what else you can check. I wonder if I should not replace the candles prophylactically so as to be sure that they are not.
  • #2 17359139
    Piasek80
    Help: 129
    Rate: 666
    - remove the clamp from the battery
    - remove the fuse from the LPG controller supply cable (to "kill" the installation)
    - turn the key in the ignition with 2x to discharge all capacitive capacitors, etc., memory backup systems
    - connect the clamp to the battery
    - turn on the ignition, wait 30 seconds and turn it off (the petrol engine controller has just read the reference (factory) settings and petrol parameters)
    - turn the ignition on again, press the gas pedal to the floor for 5 seconds, release it, wait about 5 seconds and press it again for 5, release and turn off the ignition (you have just calibrated / adapted the gas pedal potentiometer or, in the case of an electric throttle - its adaptation to reference values) pre-loaded)
    - start the engine.
    Drive 2-3 days on gas only, observing whether the problems described by you occur or not. If not - the gas settings have fallen out = gas installation to be fully tuned.
  • #3 17607079
    inoja
    Rate: 11
    Replace the engine temperature sensor :) . I know it from the autopsy :) Cost max 40 PLN. I was skeptical too, but all my bouts of inflammation resolved. Although the sensor shows the temperature on the instrument cluster display, the engine control unit has no exact data. If it works and it will be, let me know.
  • #4 17607250
    kowal5
    Help: 25
    Rate: 69
    Connect the diagnostic computer, check the error codes and read the current parameters on the cold engine.
    For the test, remove the vacuum hose from the LPG reducer and check that no gas is leaking from this connector. Perform the test on a warm engine.
  • #5 17607732
    Eidems
    Help: 83
    Rate: 253
    Check the LPG installation, I had the same and the gas engine had to improve its work ;)
  • #6 17607795
    kakibara
    Help: 202
    Rate: 1284
    LPG injection is letting go of gas.
    But as a colleague above writes, disconnect the LPG and check the gasoline itself.
  • #7 18041772
    asabust
    Rate: 18
    All proposals, checked (temperature sensor, pump, LPG tests, injections, candles, etc.) - unfortunately the same all the time. Even with the LPG system disconnected, the car initially has a problem with gasoline. After a while everything works fine and the gasoline works fine. Interestingly, the car starts the first time with a full tank of gasoline, but if 1/6 of the gasoline is lost and about 5/6 is left in the tank, it has a slight problem. The car starts immediately on a warm engine.
  • #8 18077337
    wladekm
    Did you fix the problem? I have exactly the same as you in the same engine. I was recently checked the valve clearances on the KIA service in Krk (RM Filipowicz) and reported the problem. The clearances are supposedly OK and the problem was supposed to come from the leaks in the vacuum system from the LPG reducer / evaporator - that's what an experienced mechanic said. Installation of BRC - BRC GENIUS MB 1200 reducer. I ordered and replaced a set of original seals for this reducer. Unfortunately, it did not help. The problem still occurs when starting with a little less fuel in the tank. As in your case, I checked: the coolant temperature sensor, I replaced the fuel filter, fuel pump, fuel vapor filter. I have no idea what that might be. If I could solve the problem, I will describe what was with me.
  • #9 18102878
  • Cold-start failure after LPG conversion and sensor repairs
    #10 18114224
    Kasiek1001
    Hello, I have a Kia Ceed 2008 1.6 engine. I am asking for help because I have a similar problem and I am slowly losing my patience to visit a mechanic-gas-electrician-electrician on a regular basis for several months. The problem occurred after driving approx. 30 thousand. on gas. The mechanic stated that there is no point in "fumbling" with the valves because they don't make any "noises" whatever that means. At the beginning it turned out that the vacuum hose fell off - it was hooked up and everything was fine for a week. After a week, the car, standing in the sun for several hours, did not start at all. Transported on a tow truck to an electromechanical engineer - after more than a week of "browsing", the immobilaizer and the shaft position sensor were replaced. Another fault has appeared - it does not cut off the alarm - the alarm diode flashes all the time during driving and parking, and after removing the key from the ignition, the door lock does not release. A few corrections and resets at the electromechanic - the alarm and door lock still live their own life - it was recommended to drive for a few days on gas so that it would start in the morning on a cold engine ... - I press the gas and nothing - after a while I start the revs go crazy, normalize and the car starts to drive normally. The repairs have already consumed some funds and I am slowly getting irritated by listing everything one by one ... Can someone help? Any idea to fix the fault?
  • #12 18323105
    Kasiek1001
    Unfortunately, I am still struggling with the problem. Several months already. It looks exactly like the video. The mechanic checked the pump and something is not holding the pressure and cannot find the cause and does not want to charge me for costs. Almost full fuel tank but that does not solve the problem either. After the night, you have to wind up for it to fire.
  • #13 18384404
    mateklos
    Help: 50
    Rate: 189
    The quality of LPG gas was also spoken of loudly about it.
    Does Bence work ok? We are looking for the reason in the LPG installation, sometimes the driver is jingling if there is. The reason is the gas parameters of the controller,
    filters and security controls.
    To petrol, if the pump does not hold, something is leaking or the pump should be replaced.
    Unfortunately, as it is like in the movie, it clearly cuts off the fuel.
    See lpg / Benz switch. It displays some engine error you did not write what?
    Cold Ignition See Engine Set T-sensors.
  • #14 18964015
    zbych_2004
    Rate: 12
    Hello, I have to share with you the success of the repair, because the craze can overwhelm a man, as he checked all the suggestions and the car still did not burn, maybe someone will take advantage of it, namely the kia ceed 2.0 benz 2008r errors in the controller no problem with firing up was the fuel pressure control valve that was stuck and it is in the fuel tank, this part is in my case No. 31110-1H000 in the attachment photo valve best regards .center] Kia Ceed 1.6 petrol + LPG - The car does not start the first time when it is col [/ center] [/ syntax]
    • Kia Ceed 1.6 petrol + LPG - The car does not start the first time when it is col Screenshot_20201007-142945_Allegro.jpg (220.96 KB) You must be logged in to download this attachment.
  • #15 18965199
    mateklos
    Help: 50
    Rate: 189
    And you see, I was close, greetings.
  • Fuel vapor solenoid valve stuck open causes cold start failure
    #16 20117613
    wladekm
    Hello after a loooong time. I decided to write you what was the reason in my tadpole. The problem with starting the engine on a cold gasoline engine was caused by the continuous opening of the fuel vapor solenoid valve. It is quite easy to check it yourself, just close the inlet connector to the solenoid valve tightly and try to fire it. The solenoid valve is located on the right side of the engine - it can be easily located on the fuel tank vent tube next to the fuel supply tube. The part has the code 29010-2B000.
    The solenoid is also present on other KIA and Hyundai models with 1.4 and 1.6 engines. Greetings to the forum members and maybe someone is still struggling with this problem.
  • Fuel vapor solenoid valve stuck open caused cold start issue
    #17 20166338
    HotSzesnastka
    wladekm wrote:
    Hello, after a long time. I decided to write you what was the reason in my tadpole. The problem with starting the engine on a cold gasoline engine was caused by the continuous opening of the fuel vapor solenoid valve. It is quite easy to check it yourself, just close the inlet connector to the solenoid valve tightly and try to fire it. The solenoid valve is located on the right side of the engine - it can be easily located on the fuel tank vent tube next to the fuel supply tube. The part has the code 29010-2B000.
    Hey, I have the same problem, I have already ordered this solenoid valve, you would be nice enough and send a photo where exactly it is located, I would be very grateful
The discussion revolves around a Kia Ceed 1.6 petrol vehicle experiencing starting issues when cold, requiring multiple attempts to ignite. Symptoms include delayed ignition, engine revs dropping upon immediate acceleration after starting, and successful ignition when the engine is warm. Various troubleshooting steps have been suggested, including checking and replacing the engine temperature sensor, inspecting the LPG installation, and ensuring the fuel system holds pressure. Users have reported similar issues, with some identifying the fuel pressure control valve and the fuel vapor solenoid valve as potential culprits. Recommendations include using diagnostic tools to check error codes and calibrating the gas pedal potentiometer.
TL;DR: Cold-starting Kia Ceed 1.4/1.6 petrol+LPG? A ~40 PLN coolant temp sensor swap fixed it: "Replace the engine temperature sensor". This FAQ compiles member-verified fixes and tests. [Elektroda, inoja, post #17607079]
Why it matters: Owners can quickly triage first-crank no-starts on Kia Ceed petrol+LPG without guesswork.
What’s the cheapest first fix for cold-starting Kia Ceed 1.4/1.6 with LPG?
Replace the coolant temperature sensor. One owner reports all cold-start issues disappeared after the swap. The dash gauge may look normal while the ECU reads wrong. The part cost about 40 PLN. “Replace the engine temperature sensor.” [Elektroda, inoja, post #17607079]
How do I test the EVAP purge solenoid (29010-2B000)?
Temporarily block the valve’s inlet hose and try a cold start. If it starts cleanly, the purge valve may be stuck open and flooding the intake. It sits on the right side of the engine on the tank vent line. “The problem … was caused by the continuous opening of the fuel vapor solenoid valve.” [Elektroda, wladekm, post #20117613]
Where is the EVAP purge solenoid located on the 1.4/1.6?
Look on the right side of the engine bay. It is mounted in-line on the fuel tank vent tube, near the fuel supply tube. The quick confirmation is to trace the vent hose and find the small solenoid with two hose ports and a connector. [Elektroda, wladekm, post #20117613]
Which in-tank valve can cause no-start, and what’s the part number?
A stuck fuel pressure control valve in the tank can block proper starting. One Ceed 2.0 case was fixed by replacing the valve, part number 31110-1H000. If pressure bleeds or sticks, the engine cranks without firing until pressure recovers. [Elektroda, zbych_2004, post #18964015]
How can I isolate LPG and reset adaptations?
Try this 3-step check:
  1. Pull the LPG controller fuse, disconnect battery briefly, then reconnect.
  2. Ignition ON 30 seconds, OFF. ON again, hold pedal down 5 seconds, wait 5 seconds, hold 5 seconds, OFF.
  3. Start and drive 2–3 days, observing cold starts. [Elektroda, Piasek80, post #17359139]
How do I check for gas leaking from the LPG reducer into the intake?
Warm the engine, then remove the vacuum hose from the LPG reducer. Check at that connector for any LPG presence. Any gas there indicates leakage past the reducer diaphragm into the intake manifold. Repair the reducer before further tuning. [Elektroda, kowal5, post #17607250]
Can leaking LPG injectors cause hard cold starts?
Yes. If an injector or rail lets LPG through when off, the intake can flood. That creates long cranking on petrol until the mixture normalizes. To verify, temporarily disconnect the LPG system and test petrol-only starts. [Elektroda, kakibara, post #17607795]
My Ceed starts first try with a full tank but struggles after ~1/6 is used. Why?
One owner observed immediate starts with a full tank, but slight problems after about 1/6 of fuel was consumed. The pattern persisted even with LPG disabled, pointing toward petrol-side behavior on initial start. Warm restarts remained normal. [Elektroda, asabust, post #18041772]
Does replacing the fuel pump always solve the cold-start issue?
No. One user replaced the pump and it only helped briefly. They suspected air entering the fuel system afterward. This edge case suggests checking for pressure loss paths beyond the pump itself. [Elektroda, Anonymous, post #18102878]
My mechanic says fuel pressure isn’t holding overnight. What next?
That matches long cranking after a night. One report noted pressure not holding, with hard cold starts even on a near-full tank. Continue pressure diagnostics for bleed-off, including valves and lines, before replacing more parts. [Elektroda, Kasiek1001, post #18323105]
Can LPG quality or controller settings cause these starts?
Yes. Members flagged LPG controller parameters, filters, and protections as culprits. Verify the LPG/petrol switch, refresh filters, and retune the controller. Poor gas quality can exacerbate cold-start stumbling and cut fuel unexpectedly. [Elektroda, mateklos, post #18384404]
What live data should I capture during a cold-start diagnosis?
Scan the ECU on a cold engine. Read stored codes and live parameters during cranking and initial idle. This helps spot false coolant readings, purge flow anomalies, or fuel trims that indicate flooding or lean starts. [Elektroda, kowal5, post #17607250]
Should I replace immobilizer or crankshaft sensor for this symptom?
One owner replaced both after a no-start incident, but cold-start issues persisted. They also developed alarm and door lock quirks. Focus first on fuel, purge, and sensor data before immobilizer work. [Elektroda, Kasiek1001, post #18114224]
Do BRC GENIUS MB 1200 reducer seals commonly cause this?
One user with a BRC GENIUS MB 1200 replaced the reducer seals without improvement. Valve clearances checked OK at a KIA service. Look beyond seals to purge and fuel pressure controls. [Elektroda, wladekm, post #18077337]
How do I adapt the throttle/pedal after a power reset?
Ignition ON for 30 seconds, then OFF. Turn ignition ON again, press the gas pedal fully for 5 seconds, release, wait 5 seconds, press again for 5 seconds, then OFF. Start and verify idle. [Elektroda, Piasek80, post #17359139]
