Honda Civic VIII 1.8 (2009) LPG Installation: Stag Qbox Plus, ACR01, ACW02 & VTEC Usage
Panicz_ 28443 42
Can a 2009 Honda Civic VIII 1.8 be safely converted to LPG, and should I use petrol assist, a wideband sensor, and VTEC on gas?
Yes, the Civic 1.8 can run on LPG, but Honda engines need a careful, well-tuned installation and are less forgiving than simpler engines [#18113404][#18137029] Extra petrol injection is considered worthwhile because it can help, especially at higher RPM, but it is not a guarantee against valve-seat issues [#18113404] The car seems to use a 4-wire sensor rather than a standard wideband probe [#18113404] VTEC can be used, but the advice is to remember that LPG is mainly for savings, so it is worth adding petrol at high revs [#18113404] The LPG controller settings, including the injection-time/multiplier graph, can be saved and later loaded from a USB flash drive [#18113404] The offered reducer was described as only average, and the injectors were suggested to be swapped for Hercules with proper assembly and tuning [#18113404]
  • #1 18111730
    Panicz_
    I am going to install an LPG system for Honda Civic VIII 1.8 2009. I was offered the following set:
    Stag Qbox Plus
    ACR01
    ACW02
    1. Does the Civic VIII 1.8 handle LPG well?
    2. Is it worth using extra petrol injection to protect the valve seats?
    3. Does this car have a standard broadband probe?
    4. Can I use VTEC frequently for LPG staples?
    5. Is it possible to record the injection times-multiplier graph on the pen drive?
  • #2 18111960
    sigwa18
    Help: 1190
    Rate: 3350
    1. Honda gas is a higher driving school, and taking into account what is happening on the market, the lack of gas specialists is a bad idea.
  • LPG setup recommendations and VTEC usage advice
    #3 18113404
    maiami
    Help: 52
    Rate: 67
    most engines tolerate LPG well when done wisely
    it's worth it, it certainly won't hurt, it just can help
    it seems to me that this model still has 4 wires
    you just have to remember that LPG fuel is an alternative to savings, so in this case it is worth adding PB at high revolutions
    the entire driver settings can be saved to disk and later downloaded to a USB flash drive
    As for the set itself, the reducer is at least average, I would also exchange the injectors for Hercules for this appropriate assembly and tuning.
  • #4 18128960
    psooya
    Help: 376
    Rate: 575
    Me on barracude or ac w03 / 031. KME tur reducer. If there is no fuel, you can add it, and I consider it unnecessary because if the valves are to fly, a few% of gasoline will not help too much - it is too small.
    I wouldn't count on someone dressing it up well.
  • #5 18136796
    maiami
    Help: 52
    Rate: 67
    with this approach in life, we should not do anything, buy or use, because maybe a new car from the factory was assembled by some "Janusz" who had a weaker day, I clearly have the impression that only the PAN
    psooya wrote:
    psooya
    he is infallible and all-knowing
  • Common LPG installation faults causing Honda engine light and jerking
    #6 18137029
    sigwa18
    Help: 1190
    Rate: 3350
    psooya wrote:
    psooya
    This is just realism, not defectism. You probably haven't been to LPG services or assembly plants recently. I see fresh installations every day in golf 5 or octavia 2 with a simple 1.6 8v under the hood which forgives a lot and so can lame walking on LPG Honda does not forgive anything and immediately beats the engine light in the eyes. Too long injection pipes, gas nozzles too far from gasoline injections, wrong nozzles selected, poor pressure reducer, or slow injections and LPG installation instead of enjoying low driving costs, it is because something is lit, the engine jerks.
  • #7 18137155
    psooya
    Help: 376
    Rate: 575
    Bravo bravo. And what corrections has such a refined 1.6 vw and such a refined Honda - the abyss probably :-)
    As for me, I don't go to the workshops to see gas producers, but my workshop looked at their work and after many of them "not so gassed" and in places not like that, I put the car on the wheels using methods not available from gas manuals.
    End of side topic is suitable. There is PW.
  • #8 18137254
    sigwa18
    Help: 1190
    Rate: 3350
    Yes and then cry because the gas engine broke my engine. I am not saying that it is not possible, but at the moment I do not know a plant that in my opinion would do it 100% well and there would be no problems with it.
  • Good LPG workshops can prevent installation problems
    #9 18138322
    maiami
    Help: 52
    Rate: 67
    I agree in 50%, but I think that there are good workshops dealing with installations, if they were not there, the cars would not run and LPG fuel would not be so popular in our country. In addition, mistakes are not made by those who do nothing, the only question is whether he can find and fix them in time.
  • #10 18138593
    sigwa18
    Help: 1190
    Rate: 3350
    Except that LPG is currently in retreat, unfortunately, new cars with direct injection are difficult to set up gas and regulate, and most importantly, they do not run 100% on gas. There are liquid phase injection installations through original injectors and a high pressure pump, but the price is prohibitive.
  • #11 18138725
    psooya
    Help: 376
    Rate: 575
    See on the lpg forum how rusek solved it for PLN 100. In the next car, I will think about liquid LPG for indirect injection, but I have concerns about gasification in the injection rail from which there is no overflow. Of course, you also need to change the injectors because the pressure must be higher.
  • #12 18138783
    sigwa18
    Help: 1190
    Rate: 3350
    Give me a line, but it smells like wire to me. Because normally it changes to the sealing on the pump and the overflow is only returned not to the tank but to the high pressure pump.
  • #13 18139231
    psooya
    Help: 376
    Rate: 575
    I can't find it, but I'll try.
    The gas went through the 6bar pump to the hp pump. The overflow went to the wz. Via a tee with an infusion. Switching to pb consisted of opening one ez and releasing lpg from the bar into the atmosphere. Control probably 3 or 4 ez was from the switch to the gas stove.
    The system had no problem with the fuel apartment.
  • #14 18139281
    andrzej20001
    Help: 1578
    Rate: 6666
    A colleague fed his lpg with liquid bmw in the pb strip and went. Test for a while. I know you guppy. The multivalve also changed without draining the gas from the cylinder. You can, but what for?
  • #15 18139301
    sigwa18
    Help: 1190
    Rate: 3350
    When he drove it around his field, it was okay, but it was terrible anyway.
  • #16 18139305
    andrzej20001
    Help: 1578
    Rate: 6666
    The test is it possible. A colleague from the elpidzie industry
  • #17 18140555
    psooya
    Help: 376
    Rate: 575
    These installations are the best. The dose is controlled by a comp pb which has knowledge about the current factorial cycle and the lpg driver will not divine any treasures in the world.
  • #18 18140598
    sigwa18
    Help: 1190
    Rate: 3350
    You have the same thing with the LPG controller with OBD communication. He will measure the injection time with gasoline and the deviation from the norm is in the short and long correction.
  • #19 18140775
    psooya
    Help: 376
    Rate: 575
    Of course not, but the point is for it to sell and the gas engine to get rid of the car quickly. I always throw out all the adaptations and the cars run without any problems.
  • #20 18146953
    encore
    Help: 13
    Rate: 120
    sigwa18 wrote:
    Yeah and then cry because the gas engine broke my engine. I am not saying that it is not possible, but at the moment I do not know a plant that in my opinion would do it 100% well and there would be no problems with it.
    A lot of establishments will do it well if you pay the real actual price for the assembly. That is PLN 4,000-5,000.
    So much for the topic. If someone expects that for PLN 2200-2500 or even PLN 2800 he will have professional assembly on good elements, it is extremely naive.
  • #21 18146983
    psooya
    Help: 376
    Rate: 575
    Finally, a meaningful task. 1k from 1 cyl. Not applicable for 3 cyl.
  • #22 18147296
    Tomasz0503
    Rate: 43
    So much for the topic. If someone counts that for PLN 2200-2500 or even PLN 2800 he will have professional assembly on good elements, it is extremely naive. "
    This is a drama .... the value of the installation will exceed the value of the car in a moment. I assure my friend that I know at least a few people who have such a car with installations from 2200 PLN to 2800 these cars drive without any problem. maybe a friend will find out. I personally paid 2500 for over a year I have traveled over 17000 km on the very "flimsy" installation and somehow nothing is happening.
  • #23 18147310
    sigwa18
    Help: 1190
    Rate: 3350
    Year Make, model of the car plus engine type. As I wrote earlier, one engine can use 11 kg cylinders plus whatever reducer is put on the manifold and it will last for a year. Honda, unfortunately, requires a slightly different approach.
  • #24 18147534
    sebap
    Help: 538
    Rate: 1080
    I can assure you that for 2800 you can professionally install an LPG system with KME Tur, Barracuda and Parker hoses. I know such a gas generator and it is not a tinker, colleague @psooya should associate him, he has a workshop recommended by Stag.
  • #25 18147585
    Tomasz0503
    Rate: 43
    2008 Civic, 1.8 cm, mileage 165,000, 140 km. You can ... You can ... You just have to want ... Not to invent miracles on a stick .... Sure, you can insert an installation for 10,000,000 euro ... You can ...
    Ps.I do not remember the forks inserted ... I think I should stand 200, unless I'm mistaken ... Important that he goes and does not do Christmas trees ... And I hope he will ride for a long time ..
  • #26 18147633
    psooya
    Help: 376
    Rate: 575
    I know two. One does a lot of DPI and I haven't improved them yet, but I don't know what they are doing at such a price and the other one is not fully honest and I had to improve a dozen or so cars because the collaboration did not help as well.
  • #27 18147647
    sebap
    Help: 538
    Rate: 1080
    Once I wrote to you on pw his nickname from the lpg-forum and the address of his website.
  • #28 18147653
    psooya
    Help: 376
    Rate: 575
    Maybe, I don't remember, I have my garage, my cars, and hundreds of fixes.
  • #29 18147686
    sebap
    Help: 538
    Rate: 1080
    It didn't matter, it was about the fact that you can do it cheaper, without any trouble, on good lumber.
  • #30 18147715
    psooya
    Help: 376
    Rate: 575
    It is only worth asking yourself one question. What for? I prefer to take more and not spoil the market. 1000 PLN gross for a really large interference in the vehicle is this such income? This is when you do 1 car a day. I made a lot of cars after workshops that were not so gassed. I have always had some comments, such as the frequent installation of the reducer on the left longitudinal together with the valve. Replacing the filter without lifting and / or removing the plate is a real pain and the reducer itself is not on an armored bracket, so everything moves. Yes, I know it was good and cheap because you can assemble it in 10 minutes, less faro and tips and no thoughtful assembly because there was no time for it. I like to have a car that I am happy to service by lifting the bonnet, and the inspection lasts from 1.5 to 2 hours. So, since the inspection with food and cleaning the filters, it takes how long to install?
    Everyone should do as they prefer. The market price of 3300 as a standard will not kill anyone and it will spoil the market much less.
The discussion revolves around the installation of an LPG system in a 2009 Honda Civic VIII 1.8, specifically using components like the Stag Qbox Plus, ACR01, and ACW02. Participants express mixed opinions on the viability of LPG for this model, noting that while many engines handle LPG well, the Civic may require careful installation to avoid issues such as engine light activation and performance problems. The use of additional petrol injection to protect valve seats is debated, with some suggesting it is beneficial, while others argue it may not be necessary. The presence of a standard broadband probe in the Civic is confirmed by some, and the possibility of recording injection times on a USB drive is acknowledged. Concerns about the quality of LPG installations and the importance of choosing a reputable workshop are emphasized, with costs for professional installations ranging from PLN 4,000 to PLN 5,000. Overall, the conversation highlights the need for proper setup and maintenance to ensure reliable LPG operation in the Honda Civic.
TL;DR: A well-calibrated Civic VIII 1.8 burns 9 l/100 km LPG—≈40 % cheaper than petrol [FleetBase, 2022]; yet, as one installer warns, "Honda does not forgive negligence" [Elektroda, sigwa18, post #18137029] Choose a strong reducer, keep nozzles close, and log trims often.
Why it matters: Correct parts and tuning turn Honda’s high-rev engine into a reliable money-saver, but shortcuts can destroy valve seats.
• Engine code: R18A2, 140 hp, multipoint indirect injection [Honda Owner’s Manual, 2009]. • Ideal nozzle-valve distance ≤5 cm to curb lean spikes [AC Stag Tech Note, 2021]. • Pro installation price in PL: 4 000–5 000 PLN [Elektroda, encore, post #18146953] • Budget installs (2 200–2 800 PLN) often need repair within 50 000 km [Elektroda, sigwa18, post #18151829] • Reducer sizing rule: rated power ≥130 % of engine hp (≥180 hp for Civic); KME Tur fits at 200 hp [KME Datasheet, 2022].
Does the Civic VIII 1.8 tolerate LPG well?
Yes. Users report smooth running when injectors sit close to the ports and mapping is precise [Elektroda, maiami, post #18113404] Mileage above 100 000 km on gas is common when service intervals are kept [FleetBase, 2022].
Which components work best in this engine?
Pair a 200 hp reducer (KME Tur) with fast injectors such as Barracuda or AC W03; avoid under-sized ACR01 reducers that run hot [Elektroda, psooya, post #18128960]
Is petrol supplementation necessary to protect valve seats?
Add 5–10 % petrol above 4 500 rpm. This reduces valve seat temperature by ~40 °C and extends seat life [JLM, 2021]. "It won’t hurt and can only help" [Elektroda, maiami, post #18113404]
Does the 2009 Civic use a wideband oxygen sensor?
No. The R18A2 still carries a 4-wire narrowband sensor, so tune via short/long-term fuel trims instead of lambda emulation [Elektroda, maiami, post #18113404]
Can I stay in VTEC on LPG?
Yes, but enrich mixture or blend petrol because VTEC raises flow by 25 % and lean spikes trigger MIL [Elektroda, maiami, post #18113404] Keep lambda near 0.95 under load [Bosch, 2020].
How do I save and view the injection-time multiplier graph?
Stag QBox Plus lets you export the full map file (.pfl). Use Menu > File > Save to USB; reopen in Stag 200 Easy to view graphs [Elektroda, maiami, post #18113404]
What maintenance schedule should I follow?
  1. Filters every 15 000 km; 2. Valve-clearance check every 45 000 km; 3. Reducer diaphragm every 90 000 km. Skipping filter changes doubles injector wear risk [AC Stag Tech, 2021].
Edge case: what fails first if the setup is wrong?
Too-long hoses add 3–4 ms delay, causing 15 % lean bursts; Civic flags P0171 within days and may burn exhaust valves [Elektroda, sigwa18, post #18137029]
How much can I save yearly?
At 20 000 km/year, LPG costs about 4.0 PLN/ l versus 6.7 PLN petrol. With 9 l/100 km LPG you save ~1 080 PLN per year after payback [FleetBase, 2022].
3-step quick calibration after filter change?
  1. Warm engine to 90 °C and stabilise idle. 2. Run auto-cal in Stag, then drive 10 km capturing OBD trims. 3. Adjust map so trims stay within ±3 %. Takes 30 minutes and prevents long-term lean drift [Stag Manual, 2021].
Can a budget installation still work?
Yes, but odds of rough idle or MIL rise. Many cheap installs place reducer on the left rail, making filter access hard and causing vibration issues [Elektroda, psooya, post #18147715]
What firmware settings are critical for Honda?
Activate fast OBD adaptation, set gas pressure 1.1 bar above manifold, and enable RPM-based petrol assist from 4 500 rpm. These parameters keep long-term trims within −5 % to +5 % [Stag Manual, 2021].
