PS3 Audio Issue: No Sound in Games, Unsupported Audio Format - Solutions for Device Output
wolf455pl 49587 7
  • #1 13498677
    wolf455pl
    Hi, I have a little problem, my ps3 works fine until today. When I turn on the consoles, there is sound, but when I turn on the game, it is gone. Only writes on the TV "unsupported audio format, check connection at device output"
    What is it and how to fix it ?? On YT, there is sound in the movies, too, and in the menu.
  • #2 13503743
    2konrafal1993
    Help: 581
    Rate: 746
    What kind of cable do you send the sound and directly to the TV or receiver? it is possible that in
    sound settings, you can have formats set that are not supported by the TV or ampltuner, e.g. dts or dolby digital, etc.
  • #3 13504273
    wolf455pl
    I don't know much about it, but I will say that I have 2 cables, power supply and hdmi.
    Everything has been hooked up for 2 years and only overnight sound is not only in games.
    The cables are directly attached:
    Power supply for console and socket
    HDMI on one side a TV and an expensive console.
  • #4 13505973
    2konrafal1993
    Help: 581
    Rate: 746
    Enter sound settings and set HDMI output to stereo only.
  • #5 13573319
    hebis
    Level 19  
    Help: 9
    Rate: 48
    Did you connect any additional device under hdmi? TV tuner or something else?
    Sometimes the tv switches signals wrong and there is a conflict myself, I had it.
  • #6 13581091
    Wutekk
    Rate: 13
    Try to replace the HDMI cable, if that doesn't help, find the original AV cable from the console and fire up the console on it, without using HDMI.
  • #7 20950987
    emiliawronowska1991
    Maybe the sound file has not been downloaded, so there is no sound and you have to uninstall and install the game, that's what happened to me.
  • #8 20973885
    habinka
    Congratulations
    • PS3 Audio Issue: No Sound in Games, Unsupported Audio Format - Solutions for Device Output comment_BDYCX8YqKUl6GOv1gz3nq3oVtHHYW1U9.jpg (64.76 KB) You must be logged in to download this attachment.
The discussion revolves around a PS3 audio issue where sound is present in the console's menu and YouTube but disappears during gameplay, displaying an "unsupported audio format" message on the TV. Suggested solutions include checking the audio output settings, specifically setting HDMI output to stereo only, and ensuring that the correct audio formats are selected. Users also recommend checking for conflicts with additional HDMI devices, replacing the HDMI cable, or using the original AV cable. Another potential solution mentioned is reinstalling the game if the sound file is missing.
