PS3 SLIM Connection Issue: Black Screen on TOSHIBA CT-8035 TV with Sound Working
_kuba331_ 9027 11
Why does my PS3 Slim show a black screen with sound on my TV, and what should I check first?
If the same black-screen-with-sound problem happens on two different TVs and with two HDMI cables, the PS3 is damaged, most likely its HDMI input/port [#16530012] Before concluding that, try another HDMI cable because a bad cable is a common cause of sound with no picture [#16498596][#16501127] To verify whether the console’s video output still works, connect it with an analog AV-chinch or RGB cable and see if the picture returns [#16530012]
  • #1 16496990
    _kuba331_
    Hello, well, about 5 days ago, after the next connection of the PS3 SLIM to the TV, the TV has no picture and the voice is there, I tried and restarted the ps3 and turned off and turned on the TV and ps and then nothing, I don't know what's going on and what is the fault, I connected to the second TV that works normally, suddenly the same screen problem happened. My TV is TOSHIBA CT-8035. I will add that the console worked fine for a while.
  • #2 16497020
    bydlak
    Help: 52
    Rate: 36
    Please try to switch to PAL / NTSC system on your TV or vice versa.
  • #3 16497033
    _kuba331_
    Does anyone know how to change it? Because I am green when it comes to televisions.
  • #4 16498596
    Sirius27
    Level 19  
    Help: 28
    Rate: 47
    Do not move anything, just check the console on a different cable because if you have sound and you do not have a picture, the first suspect is the cable you connect the console to the TV.
  • #5 16499263
    _kuba331_
    This cable is not original, I will borrow someone else, check it and write it. HDMI
  • #6 16500966
    _kuba331_
    And what could be the fault of the black screen on TV? Because only the voice is there. And I did not try another cable.
  • #7 16501127
    Sirius27
    Level 19  
    Help: 28
    Rate: 47
    Most likely a damaged HDMI cable or, in a worse case, a damaged HDMI port in the console.
  • #8 16501226
    _kuba331_
    Possible, and I will not save the TV? Because even without connecting to the console, the screen is still black. But everything works, you can switch and so on, only the screen is gone.
    Sirius27
    Level 19  
    Help: 28
    Rate: 47
    If the TV has no picture without connecting the console, it means that the TV is damaged and only a rather professional service can fix it.
  • #10 16529280
    _kuba331_
    Probably the console is broken because I connected to the second TV and there was a black screen, only the voice was. I also changed the HDMI cable and then the same as with the TV, I do not know what could have happened and the console probably goes to the trash. :(
  • #11 16530012
    Sirius27
    Level 19  
    Help: 28
    Rate: 47
    If the effect is the same on 2 different TV sets and 2 HDMI cables, i.e. there is sound and no image, the console is damaged.
    And most likely the HDMI input on the console is broken.
    Try to connect the console with an analog AV-chinch or RGB cable (such as for a playstation 2) and check if the picture is normal.
The discussion revolves around a PS3 SLIM experiencing a black screen issue when connected to a TOSHIBA CT-8035 TV, with sound functioning normally. Users suggest troubleshooting steps, including switching between PAL and NTSC settings, checking the HDMI cable, and testing the console with different cables. The consensus indicates that if the problem persists across multiple TVs and cables, the HDMI port on the console may be damaged. One user notes that the TV also displays a black screen without the console connected, leading to concerns about potential damage to the TV itself. Recommendations include using analog AV or RGB cables for further testing.
