Generating Bibliography from Pre-existing Footnotes in MS Word
zbyszek100 110364 16
Can I generate a bibliography in Microsoft Word from already existing footnotes without re-entering the sources manually?
Yes — you can do it with a VBA macro that reads the existing footnotes and creates a bibliography list from them [#13549773][#13551564] Add a new macro to the document, paste the provided code into it, and save the file in a macro-enabled format such as .docm [#13551632][#13551689] Then place the cursor where you want the bibliography to appear and run the macro [#13551689] In the thread, this was confirmed to work after using the second code snippet, so the problem was solved that way [#13552069][#13552095] The result is a simple plain-text list, without numbering or special formatting [#13551689]
  • #1 13549482
    zbyszek100
    Rate: 207
    Hello, I want to make my life easier, I have footnotes, I want to generate bibliographies from it. I know that there is such an option, but for this to happen I have to re-enter everything through references / insert a quote / add a new source, and then it will generate it where I want.
    As I already wrote, I have footnotes ready, is it possible to generate a bibliography without entering it manually?
  • #2 13549530
    c4r0
    Level 36  
    Help: 155
    Rate: 565
    I suspect not, but I am not sure. If you really want to do such things -> LaTeX.
  • #3 13549537
    zbyszek100
    Rate: 207
    something more about it? he writes a thesis and wants to somehow skip these details.
  • #4 13549551
    c4r0
    Level 36  
    Help: 155
    Rate: 565
    http://en.wikipedia.org/wiki/LaTeX
    Latex is a scripting language for writing books, publications, manuals, and any kind of work. Once you've got everything done, there's no point in switching to another system. Latex has to be learned, and writing the first few pages can take most of your writing time :P But worth. I wrote my MA (2 years ago) in Latex and I don't regret it a bit. The big advantage is that if you write such a work correctly, then any formatting can be changed with one simple command - for example, change the appearance of chapter headings, the format of the table of contents, the format of captions under the pictures, etc. This is a great thing. The easiest way for me to compare it to HTML (possibly with CSS). But as I wrote, when you have everything done in the word, I don't know if it makes sense to rewrite in something else. You are already cooked and things like what you are asking here have to be found in forums, and you probably can't do it anyway.
  • #5 13549561
    zbyszek100
    Rate: 207
    well, I have about 40 books, etc. and I don't want to introduce it too much to the Word base again, it will work for me if I will start copying to the end of the page and just format it in the right way.
  • #6 13549580
    c4r0
    Level 36  
    Help: 155
    Rate: 565
    Exactly, so probably do it on foot as conveniently and that's it. Because if you look for your trick to do it automatically, before you find a solution (which is not at all certain) you would probably have rewritten it on foot two times. 40 books is not that much. In Latex, the entire bibliography is saved in a separate file in a simple, clear text format (http://en.wikipedia.org/wiki/BibTeX) and if you want, you can even use various programs to manage such a file, such as JabRef. In my work, we use one common source file in a group, where thousands of publications are already saved. In your text, it is enough to provide a conventional name (we have the author's name plus the year of publication) and the rest of the information appears automatically.
  • #7 13549773
    mickpr
    Help: 579
    Rate: 295
    Theoretically, it is possible - you just need to write the appropriate code in VBA, which will do it (based on the structure of the document). However, "HOW?" - don't ask me anymore :)
  • #8 13549792
    zen3x
    Help: 231
    Rate: 291
    There is a bibliography option in the word, but a small change in the footnotes is enough and the whole thing can get very confusing. The simplest form is described here Link . There is a small caveat to the bibliography so generated. Word has 10 bibliographic styles by default, not all of them are compliant with the Polish ISO-690 bibliographic standard. What can be manifested, for example, by changing the word p. On a page. A style is an xml file that can be properly refined. From the bibword website you can get an additional 5,000 compatible styles. There are many of them in professional bibliographic managers.
    After installing a bibliography manager, eg Citavi, which is in Polish, you can get a bibliography relatively easily.
    Writing a job in the Latex system, when you have everything in it, is pointless. Because it's a completely different world. it is a serious typesetting system where aspects of the bibliography, footnotes, citations and other typesetting elements are very fine-tuned.
  • #9 13551086
    zbyszek100
    Rate: 207
    But in order to do biblographs in this way, I have to enter the sources manually, i.e. these 40 books.
  • #10 13551564
    mickpr
    Help: 579
    Rate: 295
    Maybe I can propose something. I don't know if it works everywhere (I tested Word 2007), but here is the VBA code displaying MSGBOX footnotes from Word.
    Code: text
    On the basis of this code, you can create a macro that creates a list that someone likes.
  • #11 13551584
    zbyszek100
    Rate: 207
    what should i do with this code? :)
  • #12 13551632
    mickpr
    Help: 579
    Rate: 295
    If you don't know what VBA and macros are - you won't do anything, but it looks like you don't know.
    If you know what macros are - paste the contents of this procedure into the document with footnotes into the content of the new macro and check the operation (run the macro), is it what you mean?
    The document must be saved in a form that allows you to run macros (in Word 2007 * .docm).
    If they are displayed one by one, we will think about how to create a macro that will insert a biography at the current cursor location.
  • #13 13551660
    zbyszek100
    Rate: 207
    unfortunately I am green. My knowledge ends with Widok / Makra :D
  • #14 13551689
    mickpr
    Help: 579
    Rate: 295
    Just to a document with existing footnotes:
    1.add a new macro,
    2. enter its edition,
    3. Paste this code, save the document.
    Code: text
    4. Place the cursor where you want the list to appear
    5. Run the macro.
    This is obviously a fairly simple method, with no numbering (you can think about that later) and no formatting (plain text).
  • #15 13551829
    zbyszek100
    Rate: 207
    Only messages for approval with the OK button appear. One book at a time in the communication
    mickpr
    Help: 579
    Rate: 295
    Did you paste the second code I provided? Probably not.
  • #17 13552095
    zbyszek100
    Rate: 207
    it works! Thanks. It made it easy for me
✨ The discussion revolves around generating a bibliography from existing footnotes in Microsoft Word. The user seeks a method to automate this process without manually entering each source. Responses suggest that while Word has a bibliography feature, it may require manual adjustments and is limited in style compliance. Alternatives like LaTeX are mentioned for their efficiency in managing bibliographies, but transitioning to LaTeX is deemed impractical for users already invested in Word. A potential solution involves using VBA (Visual Basic for Applications) to create a macro that extracts footnotes and compiles them into a list, although the user initially lacks familiarity with VBA. Eventually, the user successfully implements a provided macro code to automate the extraction of footnotes into a bibliography format.
