Office Word 2010 - table of contents - automatic numbering does not work
sickape 27302 8
  • #1 11193577
    sickape
    Rate: 15
    Office Word 2010 table of contents problem
    I'm trying to make a table of contents.
    I Chapter
    1.1
    1.2
    1.3
    II Chapter
    2.1
    2.2
    e.t.c.
    I use the heading style for chapters and heading 2 for subsections.
    My problem is that in the second chapter, the numbering of the subsections starts with 1.4. It is not possible to manually set 2.1 and from what I see in various instructions, it should be done automatically.
    What should I do to make the list look like in the given example?
    best regards
  • #3 11193720
    sickape
    Rate: 15
    I know how to make a table of contents. Only why from the machine in the second chapter does not start subsections from 2.1 and not 1.x !!!
  • #5 11193817
    sickape
    Rate: 15
    division of sections does not help, there is a continuous numbering next.
  • #7 11196249
    sickape
    Rate: 15
    now something more specific. I did test and it works. However, only in the case when I give the numbering, i.e.:
    1.
    1.1
    1.2
    2.
    2.1
    2.2
    However, I want it to be Chapter I, Chapter II instead of 1 and 2
    marek003
    Level 40  
    Help: 801
    Rate: 488
    But I don't know what your problem is?
    You select multi-level numbering
    there definition... and set accordingly what you want. (in your case for the second level you turn on Arabic and that's it).
    • Cośta cośtam.zip (12.23 KB) You must be logged in to download this attachment.
  • #9 11198284
    sickape
    Rate: 15
    Managed to. For nothing I could do so that the chapters were Roman numerals. When I wanted to do this, the subsections automatically did the following: I.1 etc.
    Your file helped.
    THANKS!!!
The discussion revolves around an issue with creating a table of contents in Office Word 2010, where the automatic numbering for subsections in the second chapter incorrectly starts at 1.4 instead of 2.1. Users suggest various solutions, including ensuring proper section breaks and using multi-level numbering settings. The author expresses a desire to use Roman numerals for chapters while maintaining correct subsection numbering. Ultimately, the author finds a solution that allows for the desired formatting, indicating that the provided resources were helpful.
