Creating a PDF With Clickable Table of Contents and Bookmarks From Word 2007
TechnicalMarcin 22154 2
  • #1 10469106
    TechnicalMarcin
    I am struggling with the following problem. I have my work written in MS Word 2007 - I made a nice table of contents and table of illustrations. The problem, however, is that - not knowing why - the list of illustrations does not work (even though Word flashes nicely).
    I also have a question: how to make the table of contents so that it is on the right in the pdf file in a separate frame? I have provided an example of such a list as an attachment. With what program is it possible to add such something, as well as links, footnotes directly in a pdf file?
    Thank you in advance for the answers and best regards,
    Marcin
    PS.
    What is this fee for a file (0.01-4.00)? I deselect it by default, but maybe it will be better for you (users) if I set a value there?
    • instrukcja.pdf (288.79 KB) You must be logged in to download this attachment.
  • #2 10472028
    paweliw
    IT specialist
    Help: 710
    Rate: 230
    In Word, this can be done using Bookmarks. In the pdf file saving options you have to choose the option Create bookmarks using: and mark Word bookmarks .
    Hyperlinks inserted in the document also work.
    I am enclosing an example.
    Advanced editing of the pdf file is possible with eg Adobe Acrobat (commercial version, expensive).
    You can check if there are free versions to support this type of option, e.g. on PC WORD Computer-PDF Creation and Editing .
    However, I am concerned that the free versions will not handle most of the options you require.
    • proba.pdf (35.7 KB) You must be logged in to download this attachment.
  • #3 13468273
    TechnicalMarcin
    It took a year, but finally the company bought the Adobe suite and I can make such a table of contents. ;)
